i have a issue with steam or ubisoft. so i tried running assassin’s blackflag.
it ran without a problem. Then i tried ac unity and i can’t run via uplay i don’t know why it says “there is a problem connecting to a Uplay Service.” and i tried somethings like using a vpn (did with USA and Japan) but it didn’t worked. So my question is how do I make it work?
i downloaded steam via the Terminal code: flatpak install com.valvesoftware.Steam`
my kernel version is 6.1.31-2-MANJARO (64-bit) and i run manjaro linux KDE Plasma version 5.27.55
i enabled steam Play for all other titles and run them with proton experimental. There is also a guy that said disable steam client beta, but i can’t seem to find out.
specs (desktop):
cpu ==> amd ryzen 5 1600AF
gpu ==> nvidia rtx 3060 12gb from Gigabyte
ram ==> 24gb
PS: Also keep in mind I am kinda new to linux (wanted to switch it up a bit) so if you can explain in detail i will greetly appreciate it, thanks
i have another question do you know why it always reuse uplay when i restart the game? when i check the folder (gamelauncher) i still see ubisoftconnectinstaller.exe even the vdf file has the line correct (“process 1” “%INSTALLDIR%\Support\Software\GameLauncher\UbisoftConnectInstaller.exe”)
EDIT: i got it i just have to start ubisoft first then launch the game
