There are two Manjaro in the group
Two Manjaro options are available in the Group. I think OS-Prober perceives BTRFS Snapshot as a separate operating system and adds to the Group.
herzane@manjaro ~> sudo os-prober
/dev/nvme0n1p3:Manjaro Linux:Manjaro:linux:btrfs:UUID=7e8995e4-7cc4-46d4-8586-7448505971d7:subvol=timeshift-btrfs/snapshots/2025-05-13_14-37-39/@
/dev/nvme0n1p5@/efi/Microsoft/Boot/bootmgfw.efi:Windows Boot Manager:Windows:efi
herzane@manjaro ~>
I used translation, I was so sorry if I could not explain
Unlike many other Linux distributions, Manjaro allows several kernels to be installed concurrently. These appear on the GRUB menu as alternate options to boot with; consider them as fallbacks.
BTRFS snapshots seem to be clearly listed at the bottom.
It might be beneficial to translate the information given (below).
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Highly Recommended
Required Reading
Technical Resources
Ok, but is there a need for this? There is already a section for selecting the kernel. I don’t understand why it adds the kernel backup to the group.
I still use EXT4 partitions.
Someone else might be able to better explain it to you.
A Manjaro system always creates two entries for a given kernel.
One entry is booting a kernel which includes modules known to be required for the system
The second entry is a fallback entry - probing the system for modules to load
When you are using btrfs entries may be created to boot into a snapshot.
Hmm, so it’s necessary. Thanks for the explanation.
