Kernel: 5.15.185-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=7e180712-d0ad-439a-a53d-bcd4c3298aab rw quiet splash apparmor=1
Desktop: GNOME v: 48.2 tk: GTK v: 3.24.49 wm: gnome-shell
base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X515DA_M515DA
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X515DA v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: X515DA.308
date: 08/05/2022
ID-1: BAT0 charge: 29.5 Wh (100.0%) condition: 29.5/37.1 Wh (79.3%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 138
System RAM: total: 24 GiB available: 21.45 GiB used: 2.91 GiB (13.6%)
(unregistered) size: 8 GiB speed: spec: 3200 MT/s actual: 2400 MT/s volts:
note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: N/A part-no: N/A serial: N/A
(unregistered) size: 16 GiB speed: spec: 3200 MT/s actual: 2400 MT/s
volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M471A2K43DB1-CWE serial: <filter>
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108109
Topology: cpus: 1x dies: 1 cores: 4 threads: 8 tpc: 2 smt: enabled cache:
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2954 min/max: 1400/2100 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2954 2: 2954 3: 2954
4: 2954 5: 2954 6: 2954 7: 2954 8: 2954 bogomips: 33548
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spec_rstack_overflow mitigation: safe RET
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines; IBPB: disabled; STIBP: disabled;
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 62.0 C
Device-2: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.2:4 chip-ID: 322e:2103
class-ID: 0e02
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0903 built: 2019 res: 1920x1080
dpi: 142 gamma: 1.2 chroma: red: x: 0.573 y: 0.357 green: x: 0.349 y: 0.580
blue: x: 0.165 y: 0.125 white: x: 0.314 y: 0.329
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
1024x768, 800x600, 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics
(radeonsi raven ACO DRM 3.42 5.15.185-1-MANJARO) device-ID: 1002:15d8
memory: 1.95 GiB unified: no display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x,snd_pci_acp5x
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k5.15.185-1-MANJARO status: kernel-api with: aoss
Server-1: JACK v: 1.9.22 status: off tools: qjackctl
Server-2: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lite-On driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:c822
class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
Device-1: Lite-On Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.1:3 chip-ID: 04ca:4005
Report: rfkill ID: hci0 rfk-id: 5 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 131.09 GiB (27.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2400 MTFDKBA512QFM
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: V3MA003 temp: 32.9 C
scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
used: 131.09 GiB (27.5%) fs: f2fs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 7e180712-d0ad-439a-a53d-bcd4c3298aab
used: 320 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 0222-421A
Device-1: 1-2:3 info: TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS]
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 2357:010c class-ID: 0000 serial: <filter>
Device-2: 1-4:2 info: Logitech RX1000 Laser Mouse type: mouse
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 046d:c046 class-ID: 0301
Hub-4: 3-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 3-2.1:3 info: Lite-On Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 04ca:4005 class-ID: e001 serial: <filter>
Device-2: 3-2.2:4 info: Sonix USB2.0 HD UVC WebCam type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 322e:2103 class-ID: 0e02
Hub-5: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 52.4 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (rpm): cpu: 3400
Packages: 1536 pm: dpkg pkgs: 0 pm: pacman pkgs: 1521 libs: 492
tools: gnome-software,pamac,yay pm: flatpak pkgs: 0 pm: snap pkgs: 15
1: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
2: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
3: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
6: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
8: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 304
1: cpu: 50.0% command: ps pid: 16671 mem: 4.04 MiB (0.0%)
2: cpu: 6.0% command: firefox pid: 11578 mem: 481.8 MiB (2.1%)
3: cpu: 2.3% command: firefox pid: 11956 mem: 280.8 MiB (1.2%)
4: cpu: 1.2% command: firefox pid: 11774 mem: 469.7 MiB (2.1%)
5: cpu: 0.7% command: [irq/68-ELAN1200] pid: 705 mem: 0.00 MiB (0.0%)
Memory top: 5 of 304
1: mem: 481.8 MiB (2.1%) command: firefox pid: 11578 cpu: 6.0%
2: mem: 469.7 MiB (2.1%) command: firefox pid: 11774 cpu: 1.2%
3: mem: 316.5 MiB (1.4%) command: gnome-shell pid: 2249 cpu: 0.4%
4: mem: 280.8 MiB (1.2%) command: firefox pid: 11956 cpu: 2.3%
5: mem: 234.0 MiB (1.0%) command: firefox pid: 11957 cpu: 0.4%
Processes: 304 Power: uptime: 10h 13m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 8.56 GiB services: gsd-power,
tool: systemctl
Compilers: clang: 20.1.6 gcc: 15.1.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.38
The touchpad doesn’t work. I reinstalled the linux510 linux510-headers kernel to 612 and apparently after that the touchpad stopped working. I tried to figure it out myself and found some
июн 28 20:16:04 tor-vivobookasuslaptopx515dam515da touchegg[947]: libinput error: event10 - ELAN1200:00 04F3:309F Touchpad: kernel bug: Touch jump detected and discarded.
BG405
28 June 2025 19:32
2
Hi, could you post your current system info please?
inxi -zv8
… like you did in your previous topic; we can’t go on that one because things have changed.
In the meantime, have you tried other kernels e.g. linux66 (LTS)?
base: Arch Linux
date: 08/05/2022
desc: 1x4 MiB
xsaveerptr xsaveopt
prctl and seccomp
class-ID: 0e02
class-ID: 0480
class-ID: 0280
scheme: GPT
uuid: 0222-421A
Processes:
CPU top: 5 of 304
tool: systemctl
(I tried to revert it back but nothing changed)
Also, I did not try to use other kernels, taking into account that initially everything worked
Mod edit:- Your inxi out put has been moved to this post, where the incomplete attempt was originally. No charge.
Please post your full inxi output as previously requested.
Also, follow the link (below) to learn how to post command output.
Update Announcements
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly;
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Highly Recommended
Required Reading
Technical Resources
Possibly this problem? https://wiki.archlinux.org/title/Touchpad_Synaptics#Cursor_jump
Maybe add this to the kernel parameter:
i8042.nomux=1 i8042.reset
More info: modinfo i8042
@tor
There is no need to keep re-posting your inxi output – it has already been moved to post #3 where it was originally.
I have reduced the porameters
sudo nano /etc/default/grub
and
GRUB_CMDLINE_LINUX_DEFAULT='quiet splash apparmor=1 security=apparmor udev.log_priority=3 i8042.nomux=1 i8042.reset'
now pochimuto before entering the user works if I use 2 fingers but after entering it stops
ok you mean parameters… What did the parameters look like before?
Sorry, the sentence does not make sense. What is “pochimuto”?
tor
29 June 2025 10:15
11
Sorry I’m using a translator. For some reason
It looked like
Ok it is same as from your inxi:
So you did not reduce it, but expand it. How can a translator get it so wrong?
Use https://www.deepl.com/ which is much better.
