If you see it, I just read the file from the ZFS storage pool and copy it to the / tmp folder, but why do you have written operations? I didn’t write any files to this Seagate HDD.
And I use the Manjaro default ZFS configuration and join the SSD to enable L2ARC and set up to 16G memory using ARC.
ARC should have already hit the file I read, but why is there a strange write behavior?
This makes it impossible for me to sleep my HDD, resulting in additional hard disk life consumption and energy waste.
mount
kate on /home/test/d type zfs (rw,xattr,noacl)
sudo hdparm -y /dev/disk/by-id/ata-ST1000LM024_HN-M101MBB_S31LJ9DFB19087
/dev/disk/by-id/ata-ST1000LM024_HN-M101MBB_S31LJ9DFB19087:
issuing standby command
sudo smartctl -i -n standby /dev/disk/by-id/ata-ST1000LM024_HN-M101MBB_S31LJ9DFB19087
doas (test@test-HomePC) password:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.13.15-1-MANJARO] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
Device is in STANDBY mode, exit(2)
cat ./loopcp.sh
#!/bin/bash
while true
do
cp /home/test/d/manjaro-kde-21.1.2-210904-linux513.iso /tmp
done
screen -dmS loopcp ./loopcp.sh
lsof ~/d
lsof: WARNING: can't stat() tracefs file system /sys/kernel/debug/tracing
Output information may be incomplete.
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
cp 106407 test 3r REG 0,75 3456624640 128 /home/test/d/manjaro-kde-21.1.2-210904-linux513.iso
sudo zpool iostat -v kate 1
capacity operations bandwidth
pool alloc free read write read write
kate 3.22G 925G 0 12 689 8.74M
ata-ST1000LM024_HN-M101MBB_S31LJ9DFB19087 3.22G 925G 0 12 689 8.74M
cache - - - - - -
ata-INTEL_SSDSCKHB340G4M_118000041_BTWM7AK02UHC 3.17G 314G 0 64 712 7.92M
kate 3.22G 925G 0 48 0 300K
ata-ST1000LM024_HN-M101MBB_S31LJ9DFB19087 3.22G 925G 0 48 0 300K
cache - - - - - -
ata-INTEL_SSDSCKHB340G4M_118000041_BTWM7AK02UHC 3.17G 314G 0 1 0 7.99K
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.13.16-1-MANJARO] (local build)
=== START OF INFORMATION SECTION ===
Model Family: Seagate Samsung SpinPoint M8 (AF)
Device Model: ST1000LM024 HN-M101MBB
Serial Number: S31LJ9DFB19087
LU WWN Device Id: 5 0004cf 20eb028c2
Firmware Version: 2BA30001
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Form Factor: 2.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 6
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Sep 14 20:28:37 2021 CST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Power mode is: ACTIVE or IDLE
cat /etc/modprobe.d/zfs.conf
options zfs zfs_arc_max=17179869184
options zfs zfs_arc_min=8589934592
