Hello Everyone!
After updating to Plasma 5.22, I got the message from S.M.A.R.T about my main drive (ssd) to have a problem which I couldn’t identify.
Kernel: 5.13.1-3-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b77cecec-354e-4c95-a418-4564a748bbe7 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 info: plank wm: kwin_x11 vt: 1
Type: Laptop System: HP product: HP ProBook 450 G6 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: HP model: 8538 v: KBC Version 51.27.00 serial: <filter> UEFI: HP
v: R71 Ver. 01.10.00 date: 01/03/2020
ID-1: BAT0 charge: 30.1 Wh (73.6%) condition: 40.9/40.9 Wh (100.0%)
volts: 11.6 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: Discharging
RAM: total: 7.64 GiB used: 4.76 GiB (62.3%)
Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: EA cache: L2: 6 MiB bogomips: 28808
Speed: 800 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 812 7: 901 8: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Chicony HP HD Camera type: USB driver: uvcvideo bus-ID: 1-2:2
chip-ID: 04f2:b669 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.1.4
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.13.1-3-MANJARO running: yes
Sound Server-3: JACK v: 0.125.0 running: no
Sound Server-4: PulseAudio v: 14.2 running: yes
Sound Server-5: PipeWire v: 0.3.31 running: yes
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
port: 4000 bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
vendor: Hewlett-Packard driver: r8168 v: 8.049.02-NAPI modules: r8169
port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 704.24 GiB used: 400.23 GiB (56.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC501 HFM256GDJTNG-8310A size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 rotation: SSD serial: <filter>
rev: 80002C00 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS545050A7E380
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: A6C0 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 168.47 GiB (72.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: b77cecec-354e-4c95-a418-4564a748bbe7
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 48A0-CD7B
ID-3: /home/HDD raw-size: 449.76 GiB size: 441.7 GiB (98.21%)
used: 231.76 GiB (52.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: HDD
uuid: 635ed0e1-a4bb-45b3-9f05-017afc78542f
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: Swap Partition
uuid: 9ec883ab-fcb1-4675-80a4-2645653fee89
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-2:2 info: Chicony HP HD Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b669
Device-2: 1-7:3 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00b7
class-ID: ff00 serial: <filter>
Device-3: 1-10:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 45.0 C mobo: 0.0 C
Processes: 366 Uptime: 3m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 2351 note: see --pkg
pacman: 2346 lib: 538 flatpak: 0 snap: 5 Shell: Bash v: 5.1.8
running-in: konsole inxi: 3.3.05
here are some journal logs
journalctl --catalog --priority=3 --boot=-1
-- Journal begins at Fri 2021-06-04 10:21:35 +04, ends at Wed 2021-07-14 12:15:56 +04. --
Jul 14 11:58:25 lj-hpprobook450g6 kernel: x86/cpu: SGX disabled by BIOS.
Jul 14 11:58:26 lj-hpprobook450g6 systemd-modules-load[258]: Failed to find module 'vmmon'
Jul 14 11:58:29 lj-hpprobook450g6 vmnet-dhcpd[1035]: exiting.
Jul 14 11:58:29 lj-hpprobook450g6 vmnet-dhcpd[1048]: exiting.
Jul 14 11:58:29 lj-hpprobook450g6 systemd[1]: Failed to start VMware Networks.
░░ Subject: A start job for unit vmware-networks.service has failed
░░ Defined-By: systemd
░░ A start job for unit vmware-networks.service has finished with a failure.
░░ The job identifier is 100 and the job result is failed.
Jul 14 11:58:29 lj-hpprobook450g6 pulseaudio[1013]: module-rescue-stream is obsolete and should no longer be loaded>
Jul 14 11:58:29 lj-hpprobook450g6 pulseaudio[1013]: Can't cancel echo between a sink and its monitor
Jul 14 11:58:29 lj-hpprobook450g6 pulseaudio[1013]: Failed to load module "module-echo-cancel" (argument: "use_mast>
Jul 14 11:58:29 lj-hpprobook450g6 pulseaudio[1013]: Source echoCancel_source does not exist.
Jul 14 11:58:29 lj-hpprobook450g6 pulseaudio[1013]: Sink echoCancel_sink does not exist.
Jul 14 11:58:29 lj-hpprobook450g6 wpa_supplicant[1064]: nl80211: kernel reports: Attribute failed policy validation
Jul 14 11:58:29 lj-hpprobook450g6 wpa_supplicant[1064]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid >
Jul 14 11:58:29 lj-hpprobook450g6 wpa_supplicant[1064]: nl80211: Failed to create a P2P Device interface p2p-dev-wl>
Jul 14 11:58:29 lj-hpprobook450g6 systemd[1]: Failed to start MariaDB 10.5.11 database server.
░░ Subject: A start job for unit mariadb.service has failed
lines 1-23...skipping...
░░ A start job for unit mariadb.service has finished with a failure.
░░ The job identifier is 107 and the job result is failed.
Jul 14 11:58:46 lj-hpprobook450g6 fingerprint-polkit-agent[2049]: Could not register listener "/fingerprintgui/Poli>
Jul 14 12:03:05 lj-hpprobook450g6 kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=1>
Jul 14 12:05:22 lj-hpprobook450g6 sudo[7158]: lj : a password is required ; TTY=pts/7 ; PWD=/home/lj ; USER=r>
Jul 14 12:09:37 lj-hpprobook450g6 systemd[8716]: plasma-baloorunner.service: Failed at step EXEC spawning /usr/lib/>
░░ Subject: Process /usr/lib/baloorunner could not be executed
░░ The process /usr/lib/baloorunner could not be executed and failed.
░░ The error number returned by this process is ERRNO.
Jul 14 12:09:37 lj-hpprobook450g6 systemd[904]: Failed to start KRunner provider for baloo file indexer.
░░ Subject: A start job for unit UNIT has failed
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 362 and the job result is failed.
Jul 14 12:10:40 lj-hpprobook450g6 systemd[904]: Failed to start BAMF Application Matcher Framework.
░░ The job identifier is 389 and the job result is failed.
Jul 14 12:10:40 lj-hpprobook450g6 pulseaudio[9501]: module-rescue-stream is obsolete and should no longer be loaded>
Jul 14 12:10:40 lj-hpprobook450g6 pulseaudio[9501]: GetManagedObjects() failed: org.freedesktop.systemd1.ShuttingDo>
Jul 14 12:10:40 lj-hpprobook450g6 pulseaudio[9501]: Doing resync
Jul 14 12:10:40 lj-hpprobook450g6 pulseaudio[9501]: Playback too far ahead (39960), drop source 10224
Jul 14 12:10:40 lj-hpprobook450g6 systemd-coredump[9658]: Failed to connect to coredump service: Connection refused
░░ The job identifier is 425 and the job result is failed.
Jul 14 12:10:41 lj-hpprobook450g6 systemd[904]: Failed to start BAMF Application Matcher Framework.
░░ The job identifier is 443 and the job result is failed.
Jul 14 12:10:44 lj-hpprobook450g6 kernel: watchdog: watchdog0: watchdog did not stop!
I tried SMART scan on both partitions of ssd:
/boot/efi
sudo smartctl /dev/nvme0n1p1 -a
[sudo] password for lj:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.13.1-3-MANJARO] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number: SK hynix BC501 HFM256GDJTNG-8310A
Serial Number: NN96N72171310732N
Firmware Version: 80002C00
PCI Vendor/Subsystem ID: 0x1c5c
IEEE OUI Identifier: 0xace42e
Controller ID: 1
NVMe Version: 1.2.1
Number of Namespaces: 1
Namespace 1 Size/Capacity: 256,060,514,304 [256 GB]
Namespace 1 Formatted LBA Size: 512
Namespace 1 IEEE EUI-64: ace42e 00953b6368
Local Time is: Wed Jul 14 12:17:51 2021 +04
Firmware Updates (0x16): 3 Slots, no Reset required
Optional Admin Commands (0x0017): Security Format Frmw_DL Self_Test
Optional NVM Commands (0x0016): Wr_Unc DS_Mngmt Sav/Sel_Feat
Log Page Attributes (0x02): Cmd_Eff_Lg
Maximum Data Transfer Size: 64 Pages
Warning Comp. Temp. Threshold: 81 Celsius
Critical Comp. Temp. Threshold: 82 Celsius
Namespace 1 Features (0x02): NA_Fields
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 3.5000W - - 0 0 0 0 5 5
1 + 2.4000W - - 1 1 1 1 30 30
2 + 1.9000W - - 2 2 2 2 100 100
3 - 0.0350W - - 3 3 3 3 1000 1000
4 - 0.0050W - - 3 3 3 3 1000 5000
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 0
1 - 4096 0 0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: FAILED!
- NVM subsystem reliability has been degraded
SMART/Health Information (NVMe Log 0x02)
Critical Warning: 0x04
Temperature: 51 Celsius
Available Spare: 100%
Available Spare Threshold: 5%
Percentage Used: 104%
Data Units Read: 43,905,927 [22.4 TB]
Data Units Written: 34,331,275 [17.5 TB]
Host Read Commands: 594,419,015
Host Write Commands: 421,551,017
Controller Busy Time: 14,431
Power Cycles: 2,369
Power On Hours: 1,285
Unsafe Shutdowns: 34
Media and Data Integrity Errors: 0
Error Information Log Entries: 0
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Temperature Sensor 1: 51 Celsius
Temperature Sensor 2: 55 Celsius
Error Information (NVMe Log 0x01, 16 of 256 entries)
No Errors Logged
sudo smartctl /dev/nvme0n1p2 -a
Controller ID: 1
NVMe Version: 1.2.1
Local Time is: Wed Jul 14 12:17:56 2021 +04
0 + 512 0 0
1 - 4096 0 0
Temperature: 50 Celsius
Data Units Written: 34,331,279 [17.5 TB]
Host Write Commands: 421,551,216
Power Cycles: 2,369
Temperature Sensor 1: 50 Celsius
Temperature Sensor 2: 53 Celsius
No Errors Logged
Changing Kernels doesnt change the result.
Hope someone will help, I am really starting to worry
