after ton of research in the internet , there is no correct way to let the wifi work again , so I want othe share my solution to the community .
System info
➜ ~ inxi -N
Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi
Device-2: Intel Ethernet I225-V driver: igc
How to fix
sudo systemctl stop NetworkManager
sudo modprobe -rv iwlmvm
sudo modprobe iwlmvm
sudo systemctl start NetworkManager
if you share wifi network to the lan
this might crash the lan share network. which cause the loop error, which underhood using dnsmasq to serve the dhcp and dns service.
How to fix
sudo lsof -i :53
sudo kill <the pid running in 53 port>
If this solve your problem please leave comment ~ Thanks
