The same errors after reinstalling Manjaro KDE with unsupported AUR packages
Hello there!
Finally, I have reinstalled my Manjaro KDE because of the recommendation in this post: manjaro-looks-strange
And I have got the same warnings and errors after my boot:
journalctl --boot=0 --priority=4 --no-pager
сен 24 13:55:00 poh9shka-pc kernel: Speculative Return Stack Overflow: IBPB-extending microcode not applied!
сен 24 13:55:00 poh9shka-pc kernel: Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
сен 24 13:55:01 poh9shka-pc kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
сен 24 13:55:01 poh9shka-pc kernel: iwlwifi 0000:29:00.0: WRT: Invalid buffer destination
сен 24 13:55:01 poh9shka-pc kernel: nvidia: loading out-of-tree module taints kernel.
сен 24 13:55:01 poh9shka-pc kernel: nvidia: module license 'NVIDIA' taints kernel.
сен 24 13:55:01 poh9shka-pc kernel: Disabling lock debugging due to kernel taint
сен 24 13:55:01 poh9shka-pc kernel: nvidia: module license taints kernel.
сен 24 13:55:01 poh9shka-pc kernel: Bluetooth: hci0: No support for _PRR ACPI method
сен 24 13:55:01 poh9shka-pc kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  550.107.02  Wed Jul 24 23:53:00 UTC 2024
сен 24 13:55:03 poh9shka-pc kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
сен 24 13:55:03 poh9shka-pc bluetoothd[778]: src/plugin.c:init_plugin() System does not support bap plugin
сен 24 13:55:03 poh9shka-pc bluetoothd[778]: src/plugin.c:init_plugin() System does not support bass plugin
сен 24 13:55:03 poh9shka-pc bluetoothd[778]: src/plugin.c:init_plugin() System does not support mcp plugin
сен 24 13:55:03 poh9shka-pc bluetoothd[778]: src/plugin.c:init_plugin() System does not support vcp plugin
сен 24 13:55:03 poh9shka-pc bluetoothd[778]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
сен 24 13:55:03 poh9shka-pc bluetoothd[778]: src/plugin.c:init_plugin() System does not support micp plugin
сен 24 13:55:03 poh9shka-pc bluetoothd[778]: src/plugin.c:init_plugin() System does not support ccp plugin
сен 24 13:55:03 poh9shka-pc bluetoothd[778]: src/plugin.c:init_plugin() System does not support csip plugin
сен 24 13:55:03 poh9shka-pc bluetoothd[778]: src/plugin.c:init_plugin() System does not support asha plugin
сен 24 13:55:08 poh9shka-pc dbus-broker-launch[764]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
сен 24 13:55:08 poh9shka-pc dbus-broker-launch[764]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
сен 24 13:55:08 poh9shka-pc dbus-broker-launch[918]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
сен 24 13:55:08 poh9shka-pc dbus-broker-launch[918]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
сен 24 13:55:08 poh9shka-pc dbus-broker-launch[918]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
сен 24 13:55:10 poh9shka-pc sddm-greeter-qt6[914]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.20'
сен 24 13:55:10 poh9shka-pc sddm-greeter-qt6[914]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.21'
сен 24 13:55:15 poh9shka-pc upowerd[936]: g_udev_device_get_sysfs_path: assertion 'G_UDEV_IS_DEVICE (device)' failed
сен 24 13:55:15 poh9shka-pc upowerd[936]: g_udev_client_query_by_sysfs_path: assertion 'sysfs_path != NULL' failed
сен 24 13:55:17 poh9shka-pc sddm-greeter-qt6[914]: file:///usr/share/sddm/themes/breath/Main.qml:241:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
сен 24 13:55:17 poh9shka-pc dbus-broker-launch[998]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
сен 24 13:55:17 poh9shka-pc dbus-broker-launch[998]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
сен 24 13:55:17 poh9shka-pc dbus-broker-launch[998]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
сен 24 13:55:18 poh9shka-pc kded6[1065]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
сен 24 13:55:18 poh9shka-pc kded6[1065]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
сен 24 13:55:19 poh9shka-pc kded6[1065]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
сен 24 13:55:19 poh9shka-pc kconf_update[1142]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
сен 24 13:55:19 poh9shka-pc kconf_update[1142]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
сен 24 13:55:19 poh9shka-pc kconf_update[1142]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
сен 24 13:55:19 poh9shka-pc kconf_update[1142]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
сен 24 13:55:19 poh9shka-pc kconf_update[1142]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
сен 24 13:55:19 poh9shka-pc kconf_update[1142]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
сен 24 13:55:19 poh9shka-pc kconf_update[1142]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
сен 24 13:55:19 poh9shka-pc kded6[1065]: kf.bluezqt: PendingCall Error: "The name is not activatable"
сен 24 13:55:19 poh9shka-pc kded6[1065]: kscreen.kded: PowerDevil SuspendSession action not available!
сен 24 13:55:20 poh9shka-pc plasmashell[1083]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
сен 24 13:55:20 poh9shka-pc plasmashell[1083]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
сен 24 13:55:20 poh9shka-pc xdg-desktop-por[1030]: Choosing kwallet.portal for org.freedesktop.impl.portal.Secret via the deprecated UseIn key
сен 24 13:55:20 poh9shka-pc xdg-desktop-por[1030]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
сен 24 13:55:20 poh9shka-pc backlighthelper[1235]: org.kde.powerdevil: no kernel backlight interface found
сен 24 13:55:20 poh9shka-pc org_kde_powerdevil[1157]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
сен 24 13:55:20 poh9shka-pc org_kde_powerdevil[1157]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
сен 24 13:55:20 poh9shka-pc kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00002b00] Failed to grab modeset ownership
сен 24 13:55:20 poh9shka-pc org_kde_powerdevil[1157]: busno=6, sleep-multiplier =  1,30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
сен 24 13:55:20 poh9shka-pc org_kde_powerdevil[1157]: busno=8, sleep-multiplier =  1,30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
сен 24 13:55:20 poh9shka-pc plasmashell[1083]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
сен 24 13:55:21 poh9shka-pc plasmashell[1083]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
сен 24 13:55:21 poh9shka-pc org_kde_powerdevil[1157]: org.kde.powerdevil: Handle button events action could not check for screen configuration
сен 24 13:55:21 poh9shka-pc org_kde_powerdevil[1157]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
сен 24 13:55:22 poh9shka-pc kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
сен 24 13:55:22 poh9shka-pc plasmashell[1083]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:162:21: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
сен 24 13:55:22 poh9shka-pc plasmashell[1083]: qml: SystemTray ItemLoader: Invalid state, cannot determine source!
сен 24 13:55:22 poh9shka-pc plasmashell[1083]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
сен 24 13:55:22 poh9shka-pc plasmashell[1083]: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml:201:9: QML QQuickImage: Error decoding: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml?timestamp=1727175322889: Unsupported image format
сен 24 13:55:23 poh9shka-pc plasmashell[1083]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
You can see the same errors as in my previous topic that were mentioned by @linux-aarhus:
And so on (almost all errors are saved)…
So the reinstallation didn’t help me. And my system crashed like it was before:
stacktrace
сен 24 12:28:08 poh9shka-pc xembedsniproxy[63727]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
сен 24 12:28:08 poh9shka-pc xembedsniproxy[63727]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
                                                      Available platform plugins are: wayland, offscreen, linuxfb, wayland-egl, minimal, minimalegl, eglfs, vkkhrdisplay, vnc, xcb.
сен 24 12:28:08 poh9shka-pc bamfdaemon[63726]: cannot open display: :0
сен 24 12:28:08 poh9shka-pc systemd[963]: bamfdaemon.service: Failed with result 'exit-code'.
сен 24 12:28:08 poh9shka-pc systemd[963]: Failed to start BAMF Application Matcher Framework.
сен 24 12:28:08 poh9shka-pc gmenudbusmenuproxy[63738]: qt.qpa.xcb: could not connect to display :0
сен 24 12:28:08 poh9shka-pc gmenudbusmenuproxy[63738]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
сен 24 12:28:08 poh9shka-pc gmenudbusmenuproxy[63738]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
сен 24 12:28:08 poh9shka-pc systemd-coredump[63704]: [🡕] Process 1055 (ksmserver) of user 1000 dumped core.
                                                        Stack trace of thread 1055:
                                                        #0  0x0000759c9e63f52b _ZN10QXcbScreen23updateColorSpaceAndEdidEv (libQt6XcbQpa.so.6 + 0x6152b)
                                                        #1  0x0000759c9e619aa3 _ZN14QXcbConnection20createScreen_monitorEP18QXcbVirtualDesktopP24xcb_randr_monitor_info_tj (libQt6XcbQpa.so.6 + 0x3baa3)
                                                        #2  0x0000759c9e61a4bf _ZN14QXcbConnection28initializeScreensFromMonitorEP21xcb_screen_iterator_tiPP10QXcbScreenb (libQt6XcbQpa.so.6 + 0x3c4bf)
                                                        #3  0x0000759c9e61acd7 _ZN14QXcbConnection17initializeScreensEb (libQt6XcbQpa.so.6 + 0x3ccd7)
                                                        #4  0x0000759c9e60ed1d _ZN14QXcbConnection14handleXcbEventEP19xcb_generic_event_t (libQt6XcbQpa.so.6 + 0x30d1d)
                                                        #5  0x0000759c9e615c32 _ZN14QXcbConnection16processXcbEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6XcbQpa.so.6 + 0x37c32)
                                                        #6  0x0000759c9e62fb7f n/a (libQt6XcbQpa.so.6 + 0x51b7f)
                                                        #7  0x0000759ca37caab9 n/a (libglib-2.0.so.0 + 0x5cab9)
                                                        #8  0x0000759ca382c9e7 n/a (libglib-2.0.so.0 + 0xbe9e7)
                                                        #9  0x0000759ca37c9fc5 g_main_context_iteration (libglib-2.0.so.0 + 0x5bfc5)
                                                        #10 0x0000759ca45a82bd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a82bd)
                                                        #11 0x0000759ca434ff66 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14ff66)
                                                        #12 0x0000759ca434a11d _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x14a11d)
                                                        #13 0x000061809e7f235e n/a (ksmserver + 0xb35e)
                                                        #14 0x0000759ca4834e08 n/a (libc.so.6 + 0x25e08)
                                                        #15 0x0000759ca4834ecc __libc_start_main (libc.so.6 + 0x25ecc)
                                                        #16 0x000061809e7f2ce5 n/a (ksmserver + 0xbce5)
                                                        Stack trace of thread 1065:
                                                        #0  0x0000759ca491a63d __poll (libc.so.6 + 0x10b63d)
                                                        #1  0x0000759ca382c92d n/a (libglib-2.0.so.0 + 0xbe92d)
                                                        #2  0x0000759ca37c9fc5 g_main_context_iteration (libglib-2.0.so.0 + 0x5bfc5)
                                                        #3  0x0000759ca45a82bd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a82bd)
                                                        #4  0x0000759ca434ff66 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14ff66)
                                                        #5  0x0000759ca443d650 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23d650)
                                                        #6  0x0000759ca531ff0e n/a (libQt6DBus.so.6 + 0x2df0e)
                                                        #7  0x0000759ca44cd237 n/a (libQt6Core.so.6 + 0x2cd237)
                                                        #8  0x0000759ca48a339d n/a (libc.so.6 + 0x9439d)
                                                        #9  0x0000759ca492849c n/a (libc.so.6 + 0x11949c)
сен 24 12:28:08 poh9shka-pc systemd[963]: plasma-ksmserver.service: Main process exited, code=dumped, status=11/SEGV
сен 24 12:28:08 poh9shka-pc systemd[963]: plasma-ksmserver.service: Failed with result 'core-dump'.
сен 24 12:28:08 poh9shka-pc startplasma-x11[980]: org.kde.startup: "kdeinit5_shutdown" QList() exited with code 255
сен 24 12:28:08 poh9shka-pc sddm-helper[957]: Signal received: SIGTERM
сен 24 12:28:08 poh9shka-pc systemd-coredump[63736]: [🡕] Process 63727 (xembedsniproxy) of user 1000 dumped core.
                                                        Stack trace of thread 63727:
                                                        #0  0x000077c2b0ea53f4 n/a (libc.so.6 + 0x963f4)
                                                        #1  0x000077c2b0e4c120 raise (libc.so.6 + 0x3d120)
                                                        #2  0x000077c2b0e334c3 abort (libc.so.6 + 0x244c3)
                                                        #3  0x000077c2b088c663 n/a (libQt6Core.so.6 + 0x8c663)
                                                        #4  0x000077c2b088ce07 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8ce07)
                                                        #5  0x000077c2b10daa65 n/a (libQt6Gui.so.6 + 0xdaa65)
                                                        #6  0x000077c2b117c3a8 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17c3a8)
                                                        #7  0x000077c2b0949a2d _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x149a2d)
                                                        #8  0x000077c2b117c43e _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17c43e)
                                                        #9  0x000077c2b1174fad _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x174fad)
                                                        #10 0x00005b5ae7bd024e n/a (xembedsniproxy + 0x624e)
                                                        #11 0x000077c2b0e34e08 n/a (libc.so.6 + 0x25e08)
                                                        #12 0x000077c2b0e34ecc __libc_start_main (libc.so.6 + 0x25ecc)
                                                        #13 0x00005b5ae7bd05b5 n/a (xembedsniproxy + 0x65b5)
                                                        Stack trace of thread 63731:
                                                        #0  0x000077c2b0f1a63d __poll (libc.so.6 + 0x10b63d)
                                                        #1  0x000077c2b02cf92d n/a (libglib-2.0.so.0 + 0xbe92d)
                                                        #2  0x000077c2b026cfc5 g_main_context_iteration (libglib-2.0.so.0 + 0x5bfc5)
                                                        #3  0x000077c2b0ba82bd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a82bd)
                                                        #4  0x000077c2b094ff66 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14ff66)
                                                        #5  0x000077c2b0a3d650 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23d650)
                                                        #6  0x000077c2b19cbf0e n/a (libQt6DBus.so.6 + 0x2df0e)
                                                        #7  0x000077c2b0acd237 n/a (libQt6Core.so.6 + 0x2cd237)
                                                        #8  0x000077c2b0ea339d n/a (libc.so.6 + 0x9439d)
                                                        #9  0x000077c2b0f2849c n/a (libc.so.6 + 0x11949c)
сен 24 12:28:08 poh9shka-pc systemd[963]: plasma-xembedsniproxy.service: Main process exited, code=dumped, status=6/ABRT
сен 24 12:28:08 poh9shka-pc systemd[963]: plasma-xembedsniproxy.service: Failed with result 'core-dump'.
сен 24 12:28:08 poh9shka-pc systemd-coredump[63745]: [🡕] Process 63738 (gmenudbusmenupr) of user 1000 dumped core.
                                                        Stack trace of thread 63738:
                                                        #0  0x00007f06512a53f4 n/a (libc.so.6 + 0x963f4)
                                                        #1  0x00007f065124c120 raise (libc.so.6 + 0x3d120)
                                                        #2  0x00007f06512334c3 abort (libc.so.6 + 0x244c3)
                                                        #3  0x00007f0650c8c663 n/a (libQt6Core.so.6 + 0x8c663)
                                                        #4  0x00007f0650c8ce07 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8ce07)
                                                        #5  0x00007f06514daa65 n/a (libQt6Gui.so.6 + 0xdaa65)
                                                        #6  0x00007f065157c3a8 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17c3a8)
                                                        #7  0x00007f0650d49a2d _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x149a2d)
                                                        #8  0x00007f065157c43e _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17c43e)
                                                        #9  0x00007f0651574fad _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x174fad)
                                                        #10 0x000057a4212adc6e n/a (gmenudbusmenuproxy + 0x9c6e)
                                                        #11 0x00007f0651234e08 n/a (libc.so.6 + 0x25e08)
                                                        #12 0x00007f0651234ecc __libc_start_main (libc.so.6 + 0x25ecc)
                                                        #13 0x000057a4212adf45 n/a (gmenudbusmenuproxy + 0x9f45)
                                                        Stack trace of thread 63739:
                                                        #0  0x00007f065131a63d __poll (libc.so.6 + 0x10b63d)
                                                        #1  0x00007f065062f92d n/a (libglib-2.0.so.0 + 0xbe92d)
                                                        #2  0x00007f06505ccfc5 g_main_context_iteration (libglib-2.0.so.0 + 0x5bfc5)
                                                        #3  0x00007f0650fa82bd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a82bd)
                                                        #4  0x00007f0650d4ff66 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14ff66)
                                                        #5  0x00007f0650e3d650 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23d650)
                                                        #6  0x00007f0651da0f0e n/a (libQt6DBus.so.6 + 0x2df0e)
                                                        #7  0x00007f0650ecd237 n/a (libQt6Core.so.6 + 0x2cd237)
                                                        #8  0x00007f06512a339d n/a (libc.so.6 + 0x9439d)
                                                        #9  0x00007f065132849c n/a (libc.so.6 + 0x11949c)
I think the reason is the AUR package that depends on qt5-tools. I suppose that this package raises conflict with qt6. So I have removed it.
I want to highlight that I didn’t install custom themes and didn’t add some widgets to my desktop. I installed the necessary packages and that’s all.
I will be monitoring my system. If I know something new, I will add a post here.
title corrected by moderator
What happens when you download the latest ISO, install the system, boot and update the system, reboot, and don’t mess with it with external packages from AUR or wherever? Just the plain base installation of Manjaro.
The AUR is unsupported in Manjaro (and Arch). This means that no support will be offered – if you install something from the AUR and it breaks your system, then the fault is yours (and yours alone).
Your issues are likely a result of installing from the AUR. It’s also possible you had remnants of your previous install remaining in your /home directory. Did you clean your caches, etc., before reinstalling?
Additionally;
Did you reinstall with the latest full Manjaro ISO? The Minimal ISO may be missing packages that you might normally rely on.
As a final note; I (and others) don’t experience the issues you claim, so whatever the problem is must therefore be limited to your machine, your environment, or something you’re just not doing right.
I would highly recommend avoiding whatever packages you install from AUR, and installing only from the official repositories.
Yes, I absolutely agree with you if we are talking about the problem with system crashing, but if I am not wrong I had the warnings on the clean system too.
Yes, I used the latest full Manjaro KDE ISO.
What if some software is missing in official repositories? :smiling_face_with_tear:
It seems that the warnings I had in the first boot too:
journalctl
сен 23 15:29:36 poh9shka-pc kernel: Speculative Return Stack Overflow: IBPB-extending microcode not applied!
сен 23 15:29:36 poh9shka-pc kernel: Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
сен 23 15:29:37 poh9shka-pc kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
сен 23 15:29:37 poh9shka-pc kernel: iwlwifi 0000:29:00.0: WRT: Invalid buffer destination
сен 23 15:29:37 poh9shka-pc kernel: nvidia: loading out-of-tree module taints kernel.
сен 23 15:29:37 poh9shka-pc kernel: nvidia: module license 'NVIDIA' taints kernel.
сен 23 15:29:37 poh9shka-pc kernel: Disabling lock debugging due to kernel taint
сен 23 15:29:37 poh9shka-pc kernel: nvidia: module license taints kernel.
сен 23 15:29:38 poh9shka-pc kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  550.107.02  Wed Jul 24 23:53:00 UTC 2024
сен 23 15:29:38 poh9shka-pc kernel: Bluetooth: hci0: No support for _PRR ACPI method
сен 23 15:29:38 poh9shka-pc kernel: sd 7:0:0:0: [sdc] No Caching mode page found
сен 23 15:29:38 poh9shka-pc kernel: sd 7:0:0:0: [sdc] Assuming drive cache: write through
сен 23 15:29:39 poh9shka-pc kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
сен 23 15:29:39 poh9shka-pc bluetoothd[792]: src/plugin.c:init_plugin() System does not support bap plugin
сен 23 15:29:39 poh9shka-pc bluetoothd[792]: src/plugin.c:init_plugin() System does not support bass plugin
сен 23 15:29:39 poh9shka-pc bluetoothd[792]: src/plugin.c:init_plugin() System does not support mcp plugin
сен 23 15:29:39 poh9shka-pc bluetoothd[792]: src/plugin.c:init_plugin() System does not support vcp plugin
сен 23 15:29:39 poh9shka-pc bluetoothd[792]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
сен 23 15:29:39 poh9shka-pc bluetoothd[792]: src/plugin.c:init_plugin() System does not support micp plugin
сен 23 15:29:39 poh9shka-pc bluetoothd[792]: src/plugin.c:init_plugin() System does not support ccp plugin
сен 23 15:29:39 poh9shka-pc bluetoothd[792]: src/plugin.c:init_plugin() System does not support csip plugin
сен 23 15:29:39 poh9shka-pc bluetoothd[792]: src/plugin.c:init_plugin() System does not support asha plugin
сен 23 15:29:39 poh9shka-pc kernel: iwlwifi 0000:29:00.0: WRT: Invalid buffer destination
сен 23 15:29:40 poh9shka-pc kernel: iwlwifi 0000:29:00.0: WRT: Invalid buffer destination
сен 23 15:29:44 poh9shka-pc dbus-broker-launch[788]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
сен 23 15:29:44 poh9shka-pc dbus-broker-launch[788]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
сен 23 15:29:45 poh9shka-pc dbus-broker-launch[908]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
сен 23 15:29:45 poh9shka-pc dbus-broker-launch[908]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
сен 23 15:29:45 poh9shka-pc dbus-broker-launch[908]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
сен 23 15:29:46 poh9shka-pc sddm-greeter-qt6[904]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.20'
сен 23 15:29:46 poh9shka-pc sddm-greeter-qt6[904]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.21'
сен 23 15:29:51 poh9shka-pc upowerd[926]: g_udev_device_get_sysfs_path: assertion 'G_UDEV_IS_DEVICE (device)' failed
сен 23 15:29:51 poh9shka-pc upowerd[926]: g_udev_client_query_by_sysfs_path: assertion 'sysfs_path != NULL' failed
сен 23 15:29:52 poh9shka-pc sddm-greeter-qt6[904]: file:///usr/share/sddm/themes/breath/Main.qml:241:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
сен 23 15:29:52 poh9shka-pc dbus-broker-launch[989]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
сен 23 15:29:52 poh9shka-pc dbus-broker-launch[989]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
сен 23 15:29:52 poh9shka-pc dbus-broker-launch[989]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
сен 23 15:29:52 poh9shka-pc startplasma-x11[979]: QIODevice::readLine (QFile, "/home/poh9shka/.config/kdedefaults/package"): device not open
сен 23 15:29:52 poh9shka-pc startplasma-x11[979]: QPixmap: QGuiApplication must be created before calling defaultDepth().
сен 23 15:29:53 poh9shka-pc ksplashqml[993]: Texture 0x641ab58acbb0 () used with different accesses within the same pass, this is not allowed.
сен 23 15:29:53 poh9shka-pc ksplashqml[993]: Texture 0x641ab58348a0 () used with different accesses within the same pass, this is not allowed.
сен 23 15:29:53 poh9shka-pc ksplashqml[993]: Texture 0x7a13506113f0 () used with different accesses within the same pass, this is not allowed.
сен 23 15:29:53 poh9shka-pc kded6[1054]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
сен 23 15:29:53 poh9shka-pc kded6[1054]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
сен 23 15:29:54 poh9shka-pc kded6[1054]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
сен 23 15:29:54 poh9shka-pc kconf_update[1127]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
сен 23 15:29:54 poh9shka-pc kconf_update[1127]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
сен 23 15:29:54 poh9shka-pc kconf_update[1127]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
сен 23 15:29:54 poh9shka-pc kconf_update[1127]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
сен 23 15:29:54 poh9shka-pc kconf_update[1127]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
сен 23 15:29:54 poh9shka-pc kconf_update[1127]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
сен 23 15:29:54 poh9shka-pc kconf_update[1127]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
сен 23 15:29:54 poh9shka-pc plasmashell[1085]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
сен 23 15:29:54 poh9shka-pc plasmashell[1085]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
сен 23 15:29:56 poh9shka-pc backlighthelper[1220]: org.kde.powerdevil: no kernel backlight interface found
сен 23 15:29:56 poh9shka-pc org_kde_powerdevil[1150]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
сен 23 15:29:56 poh9shka-pc org_kde_powerdevil[1150]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
сен 23 15:29:56 poh9shka-pc kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00002b00] Failed to grab modeset ownership
сен 23 15:29:56 poh9shka-pc kded6[1054]: kf.bluezqt: PendingCall Error: "The name is not activatable"
сен 23 15:29:56 poh9shka-pc plasmashell[1085]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
сен 23 15:29:56 poh9shka-pc plasmashell[1085]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
сен 23 15:29:56 poh9shka-pc xdg-desktop-por[1023]: Choosing kwallet.portal for org.freedesktop.impl.portal.Secret via the deprecated UseIn key
сен 23 15:29:56 poh9shka-pc xdg-desktop-por[1023]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
сен 23 15:29:56 poh9shka-pc org_kde_powerdevil[1150]: busno=6, sleep-multiplier =  1,30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
сен 23 15:29:56 poh9shka-pc org_kde_powerdevil[1150]: busno=8, sleep-multiplier =  1,30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
сен 23 15:29:56 poh9shka-pc kded6[1054]: kscreen.kded: PowerDevil SuspendSession action not available!
сен 23 15:29:56 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
сен 23 15:29:56 poh9shka-pc org_kde_powerdevil[1150]: org.kde.powerdevil: Handle button events action could not check for screen configuration
сен 23 15:29:57 poh9shka-pc org_kde_powerdevil[1150]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
сен 23 15:29:57 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
сен 23 15:29:58 poh9shka-pc kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
сен 23 15:29:58 poh9shka-pc plasmashell[1085]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" 0x5791450a56d0
сен 23 15:29:58 poh9shka-pc plasmashell[1085]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" 0x5791450b1a60
сен 23 15:29:58 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:162:21: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
сен 23 15:29:58 poh9shka-pc plasmashell[1085]: qml: SystemTray ItemLoader: Invalid state, cannot determine source!
сен 23 15:29:58 poh9shka-pc plasmashell[1085]: org.kde.klipper: Failed to load history resource. Clipboard history cannot be read. :  History file does not exist
сен 23 15:29:58 poh9shka-pc plasmashell[1085]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
сен 23 15:29:58 poh9shka-pc plasmashell[1085]: kde.plasmashell: Activity added twice "9b2d6e87-bbc4-40b4-aa74-cca7e4424784"
сен 23 15:30:01 poh9shka-pc plasmashell[1085]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
сен 23 15:30:02 poh9shka-pc plasmashell[1085]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" 0x5791457afbc0
сен 23 15:30:02 poh9shka-pc plasmashell[1085]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" 0x5791456abd80
сен 23 15:30:02 poh9shka-pc plasmashell[1085]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" 0x5791456abd80
сен 23 15:30:02 poh9shka-pc plasmashell[1085]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" 0x579145ca6eb0
сен 23 15:30:23 poh9shka-pc dolphin[1482]: QFile::rename: Empty or null file name
сен 23 15:30:23 poh9shka-pc dolphin[1482]: kf.config.core: Failed to migrate "" -> "/home/poh9shka/.local/state/dolphinstaterc"
сен 23 15:30:24 poh9shka-pc dolphin[1482]: org.kde.dolphin: Unknown class  ""  in session saved data!
сен 23 15:30:24 poh9shka-pc dolphin[1482]: kf.kio.gui: Cannot read information about filesystem under path "/home/poh9shka/.cache/thumbnails/"
сен 23 15:30:26 poh9shka-pc dolphin[1482]: kf.kio.gui: Cannot read information about filesystem under path "/home/poh9shka/.cache/thumbnails/"
сен 23 15:30:43 poh9shka-pc kioworker[1507]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
сен 23 15:30:43 poh9shka-pc kioworker[1507]: kf.kio.core: An error occurred during write. The worker terminates now.
сен 23 15:30:48 poh9shka-pc plasmashell[1085]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
сен 23 15:30:49 poh9shka-pc plasmashell[1085]: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml:201:9: QML QQuickImage: Error decoding: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml?timestamp=1727094649195: Unsupported image format
сен 23 15:30:56 poh9shka-pc plasmashell[1085]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
сен 23 15:30:57 poh9shka-pc plasmashell[1085]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
сен 23 15:30:58 poh9shka-pc konsole[1596]: QFile::rename: Empty or null file name
сен 23 15:30:58 poh9shka-pc konsole[1596]: kf.config.core: Failed to migrate "" -> "/home/poh9shka/.local/state/konsolestaterc"
сен 23 15:32:12 poh9shka-pc plasmashell[1085]: qrc:/qt/qml/org/kde/plasma/components/ScrollView.qml:53:29: QML ScrollBar: Binding loop detected for property "visible"
сен 23 15:32:15 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/PanelConfiguration.qml:519:9: QML SpinBox: Binding loop detected for property "implicitWidth"
сен 23 15:32:15 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:326:17: QML SpinBox: Binding loop detected for property "implicitWidth"
сен 23 15:32:15 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:288: TypeError: Cannot read property 'applet' of null
сен 23 15:32:15 poh9shka-pc plasmashell[1085]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
сен 23 15:32:17 poh9shka-pc plasmashell[1085]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
сен 23 15:32:19 poh9shka-pc plasmashell[1085]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:344:18: QML ScrollView: Binding loop detected for property "calculatedImplicitHeight"
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:401:33: QML Binding: Binding loop detected for property "value"
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml:16:1: QML ConfigAppearance: Created graphical object was not placed in the graphics scene.
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_fillDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_forceStripesDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_groupPopups
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_groupPopupsDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_groupedTaskVisualization
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_groupedTaskVisualizationDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_groupingAppIdBlacklist
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_groupingAppIdBlacklistDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_groupingLauncherUrlBlacklist
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_groupingLauncherUrlBlacklistDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_groupingStrategy
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_groupingStrategyDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_highlightWindowsDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_iconSpacingDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_indicateAudioStreamsDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_launchers
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_launchersDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_length
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_maxStripesDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_maxTextLines
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_maxTextLinesDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_middleClickAction
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_middleClickActionDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_minimizeActiveTaskOnClick
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_minimizeActiveTaskOnClickDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_onlyGroupWhenFull
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_onlyGroupWhenFullDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_reverseMode
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_reverseModeDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_separateLaunchers
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_separateLaunchersDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_showOnlyCurrentActivity
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_showOnlyCurrentActivityDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_showOnlyCurrentDesktop
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_showOnlyCurrentDesktopDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_showOnlyCurrentScreen
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_showOnlyCurrentScreenDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_showOnlyMinimized
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_showOnlyMinimizedDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_showToolTipsDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_sortingStrategy
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_sortingStrategyDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_taskHoverEffect
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_taskHoverEffectDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_unhideOnAttention
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_unhideOnAttentionDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_wheelEnabled
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_wheelEnabledDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_wheelSkipMinimized
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ConfigAppearance.qml: Setting initial properties failed: ConfigAppearance does not have a property called cfg_wheelSkipMinimizedDefault
сен 23 15:32:26 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/AppletConfiguration.qml:142:5: QML Connections: Detected function "onSettingValueChanged" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
сен 23 15:32:29 poh9shka-pc plasmashell[1085]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
сен 23 15:32:52 poh9shka-pc systemsettings[1853]: QFile::rename: Empty or null file name
сен 23 15:32:52 poh9shka-pc systemsettings[1853]: kf.config.core: Failed to migrate "" -> "/home/poh9shka/.local/state/systemsettingsstaterc"
сен 23 15:32:52 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:344:18: QML ScrollView: Binding loop detected for property "calculatedImplicitWidth"
сен 23 15:32:52 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 15:32:52 poh9shka-pc systemsettings[1853]: qml: Pushed pages do not conform to the rules. Please check the documentation.
сен 23 15:32:53 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 15:33:18 poh9shka-pc systemsettings[1853]: qrc:/kcm/kcm_kscreen/main.qml:39:5: QML OverlaySheet: Binding loop detected for property "implicitHeight"
сен 23 15:37:53 poh9shka-pc baloo_file[1019]: kf.solid.backends.udisks2: Error getting props: "org.freedesktop.DBus.Error.UnknownMethod" "Object does not exist at path “/org/freedesktop/UDisks2/drives/WDC_WD20SPZX_22UA7T0_WD_WX82E900XCSD”" for "/org/freedesktop/UDisks2/drives/WDC_WD20SPZX_22UA7T0_WD_WX82E900XCSD"
сен 23 15:37:53 poh9shka-pc plasmashell[1085]: kf.solid.backends.udisks2: Error getting props: "org.freedesktop.DBus.Error.UnknownMethod" "Object does not exist at path “/org/freedesktop/UDisks2/drives/WDC_WD20SPZX_22UA7T0_WD_WX82E900XCSD”" for "/org/freedesktop/UDisks2/drives/WDC_WD20SPZX_22UA7T0_WD_WX82E900XCSD"
сен 23 15:38:27 poh9shka-pc pamac-manager[2090]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
сен 23 15:43:36 poh9shka-pc kscreenlocker_greet[2131]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_GB". Search paths QList("/usr/share/qt6/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
сен 23 15:53:30 poh9shka-pc kded6[1054]: org.kde.plasma.nm.kded: Unhandled active connection state change:  3
сен 23 16:04:09 poh9shka-pc kernel: xhci_hcd 0000:02:00.0: xHC error in resume, USBSTS 0x401, Reinit
сен 23 16:04:09 poh9shka-pc kernel: iwlwifi 0000:29:00.0: WRT: Invalid buffer destination
сен 23 16:04:09 poh9shka-pc dbus-broker[789]: A security policy denied :1.4 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.53.
сен 23 16:04:09 poh9shka-pc kernel: Bluetooth: hci0: No support for _PRR ACPI method
сен 23 16:04:09 poh9shka-pc kdeconnectd[1290]: 2024-09-23T16:04:09 default: Error sending UDP packet: QAbstractSocket::NetworkError
сен 23 16:04:09 poh9shka-pc kdeconnectd[1290]: 2024-09-23T16:04:09 kdeconnect.core: Failed to open any MDNS client sockets
сен 23 16:04:10 poh9shka-pc kdeconnectd[1290]: 2024-09-23T16:04:10 kdeconnect.core: Failed to open any MDNS server sockets
сен 23 16:04:10 poh9shka-pc kernel: iwlwifi 0000:29:00.0: WRT: Invalid buffer destination
сен 23 16:04:10 poh9shka-pc systemsettings[1853]: QRhiGles2: Context is lost.
сен 23 16:04:10 poh9shka-pc systemsettings[1853]: Rhi backingstore: graphics device lost, attempting to reinitialize
сен 23 16:04:10 poh9shka-pc plasmashell[1085]: QRhiGles2: Context is lost.
сен 23 16:04:10 poh9shka-pc plasmashell[1085]: Graphics device lost, cleaning up scenegraph and releasing RHI
сен 23 16:04:10 poh9shka-pc kscreenlocker_greet[2131]: QRhiGles2: Context is lost.
сен 23 16:04:10 poh9shka-pc kscreenlocker_greet[2131]: Graphics device lost, cleaning up scenegraph and releasing RHI
сен 23 16:09:25 poh9shka-pc kscreenlocker_greet[2402]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_GB". Search paths QList("/usr/share/qt6/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
сен 23 16:19:20 poh9shka-pc kded6[1054]: org.kde.plasma.nm.kded: Unhandled active connection state change:  3
сен 23 16:41:28 poh9shka-pc kernel: xhci_hcd 0000:02:00.0: xHC error in resume, USBSTS 0x401, Reinit
сен 23 16:41:28 poh9shka-pc kernel: iwlwifi 0000:29:00.0: WRT: Invalid buffer destination
сен 23 16:41:28 poh9shka-pc rtkit-daemon[1051]: The canary thread is apparently starving. Taking action.
сен 23 16:41:28 poh9shka-pc dbus-broker[789]: A security policy denied :1.4 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.53.
сен 23 16:41:28 poh9shka-pc kernel: Bluetooth: hci0: No support for _PRR ACPI method
сен 23 16:41:28 poh9shka-pc kdeconnectd[1290]: 2024-09-23T16:41:28 default: Error sending UDP packet: QAbstractSocket::NetworkError
сен 23 16:41:28 poh9shka-pc kdeconnectd[1290]: 2024-09-23T16:41:28 kdeconnect.core: Failed to open any MDNS client sockets
сен 23 16:41:29 poh9shka-pc kdeconnectd[1290]: 2024-09-23T16:41:29 kdeconnect.core: Failed to open any MDNS server sockets
сен 23 16:41:29 poh9shka-pc kernel: iwlwifi 0000:29:00.0: WRT: Invalid buffer destination
сен 23 16:41:29 poh9shka-pc systemsettings[1853]: QRhiGles2: Context is lost.
сен 23 16:41:29 poh9shka-pc systemsettings[1853]: Rhi backingstore: graphics device lost, attempting to reinitialize
сен 23 16:41:29 poh9shka-pc plasmashell[1085]: QRhiGles2: Context is lost.
сен 23 16:41:29 poh9shka-pc plasmashell[1085]: Graphics device lost, cleaning up scenegraph and releasing RHI
сен 23 16:41:29 poh9shka-pc kscreenlocker_greet[2402]: QRhiGles2: Context is lost.
сен 23 16:41:29 poh9shka-pc kscreenlocker_greet[2402]: Graphics device lost, cleaning up scenegraph and releasing RHI
сен 23 16:41:30 poh9shka-pc plasmashell[1085]: QRhiGles2: Context is lost.
сен 23 16:41:30 poh9shka-pc plasmashell[1085]: Graphics device lost, cleaning up scenegraph and releasing RHI
сен 23 16:41:48 poh9shka-pc rtkit-daemon[1051]: Recovering from system lockup, not allowing further RT threads.
сен 23 16:41:56 poh9shka-pc plasmashell[1085]: QRhiGles2: Context is lost.
сен 23 16:41:56 poh9shka-pc plasmashell[1085]: Graphics device lost, cleaning up scenegraph and releasing RHI
сен 23 16:42:01 poh9shka-pc plasmashell[1085]: QRhiGles2: Context is lost.
сен 23 16:42:01 poh9shka-pc plasmashell[1085]: Graphics device lost, cleaning up scenegraph and releasing RHI
сен 23 16:42:07 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 16:42:08 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 16:42:09 poh9shka-pc systemsettings[1853]: kf.configwidgets: A widget named "kcfg_osdKbdLayoutChangedEnabled" was found but there is no setting named "osdKbdLayoutChangedEnabled"
сен 23 16:42:09 poh9shka-pc systemsettings[1853]: kf.configwidgets: A widget named "kcfg_repeatRate" was found but there is no setting named "repeatRate"
сен 23 16:42:09 poh9shka-pc systemsettings[1853]: kf.configwidgets: A widget named "kcfg_repeatDelay" was found but there is no setting named "repeatDelay"
сен 23 16:42:09 poh9shka-pc systemsettings[1853]: kf.configwidgets: A widget named "kcfg_resetOldXkbOptions" was found but there is no setting named "resetOldXkbOptions"
сен 23 16:42:09 poh9shka-pc systemsettings[1853]: kf.configwidgets: A widget named "kcfg_configureLayouts" was found but there is no setting named "configureLayouts"
сен 23 16:42:09 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 16:42:09 poh9shka-pc systemsettings[1853]: qml: Pushed pages do not conform to the rules. Please check the documentation.
сен 23 16:42:25 poh9shka-pc systemsettings[1853]: qrc:/kcm/kcm_keys/main.qml:421:9: QML ColumnLayout: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
сен 23 16:42:25 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:344:18: QML ScrollView: Binding loop detected for property "calculatedImplicitHeight"
сен 23 16:42:25 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:401:33: QML Binding: Binding loop detected for property "value"
сен 23 16:42:25 poh9shka-pc systemsettings[1853]: qml: Pushed pages do not conform to the rules. Please check the documentation.
сен 23 16:42:33 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 16:42:34 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 16:42:36 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 16:42:50 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 16:42:51 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 16:42:55 poh9shka-pc systemsettings[1853]: qrc:/kcm/kcm_regionandlang/AdvancedLanguageSelectPage.qml:164:9: QML ListView: Binding loop detected for property "cacheBuffer"
сен 23 16:42:55 poh9shka-pc systemsettings[1853]: qrc:/kcm/kcm_regionandlang/AdvancedLanguageSelectPage.qml:148:5: QML OverlaySheet: Binding loop detected for property "implicitHeight"
сен 23 16:42:57 poh9shka-pc systemsettings[1853]: qrc:/kcm/kcm_regionandlang/AdvancedLanguageSelectPage.qml:148:5: QML OverlaySheet: Binding loop detected for property "implicitHeight"
сен 23 16:42:57 poh9shka-pc systemsettings[1853]: qrc:/kcm/kcm_regionandlang/AdvancedLanguageSelectPage.qml:164:9: QML ListView: Binding loop detected for property "cacheBuffer"
сен 23 16:42:57 poh9shka-pc systemsettings[1853]:   OpenType support missing for "Noto Sans", script 19
сен 23 16:42:57 poh9shka-pc systemsettings[1853]:   OpenType support missing for "Noto Sans", script 13
сен 23 16:42:57 poh9shka-pc systemsettings[1853]:   OpenType support missing for "Noto Sans", script 16
сен 23 16:42:57 poh9shka-pc systemsettings[1853]:   OpenType support missing for "Droid Sans", script 16
сен 23 16:42:57 poh9shka-pc systemsettings[1853]:   OpenType support missing for "DejaVu Sans", script 16
сен 23 16:42:57 poh9shka-pc systemsettings[1853]:   OpenType support missing for "Nimbus Sans", script 16
сен 23 16:42:57 poh9shka-pc systemsettings[1853]:   OpenType support missing for "Mukti Narrow", script 16
сен 23 16:42:57 poh9shka-pc systemsettings[1853]:   OpenType support missing for "malayalam", script 16
сен 23 16:42:57 poh9shka-pc systemsettings[1853]:   OpenType support missing for "Sampige", script 16
сен 23 16:42:57 poh9shka-pc systemsettings[1853]:   OpenType support missing for "padmaa", script 16
сен 23 16:43:05 poh9shka-pc systemsettings[1853]: qrc:/kcm/kcm_regionandlang/AdvancedLanguageSelectPage.qml:148:5: QML OverlaySheet: Binding loop detected for property "implicitHeight"
сен 23 16:43:05 poh9shka-pc systemsettings[1853]: qrc:/kcm/kcm_regionandlang/AdvancedLanguageSelectPage.qml:148:5: QML OverlaySheet: Binding loop detected for property "y"
сен 23 16:43:05 poh9shka-pc systemsettings[1853]: qrc:/kcm/kcm_regionandlang/AdvancedLanguageSelectPage.qml:164:9: QML ListView: Binding loop detected for property "cacheBuffer"
сен 23 16:44:12 poh9shka-pc kwin_x11[1055]: kwin_tabbox: Could not load window switcher package "org.kde.breeze.desktop" . Falling back to default
сен 23 16:44:12 poh9shka-pc kwin_x11[1055]: kwin_core: XCB error: 152 (BadDamage), sequence: 5858, resource id: 20987849, major code: 143 (DAMAGE), minor code: 3 (Subtract)
сен 23 16:44:15 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 16:44:15 poh9shka-pc systemsettings[1853]: qml: Pushed pages do not conform to the rules. Please check the documentation.
сен 23 16:44:17 poh9shka-pc systemsettings[1853]: qrc:/libinput/touchpad.qml:691: TypeError: Cannot read property 'supportsScrollFactor' of null
сен 23 16:44:17 poh9shka-pc systemsettings[1853]: qml: Pushed pages do not conform to the rules. Please check the documentation.
сен 23 16:44:19 poh9shka-pc systemsettings[1853]: kf.configwidgets: A widget named "kcfg_osdKbdLayoutChangedEnabled" was found but there is no setting named "osdKbdLayoutChangedEnabled"
сен 23 16:44:19 poh9shka-pc systemsettings[1853]: kf.configwidgets: A widget named "kcfg_repeatRate" was found but there is no setting named "repeatRate"
сен 23 16:44:19 poh9shka-pc systemsettings[1853]: kf.configwidgets: A widget named "kcfg_repeatDelay" was found but there is no setting named "repeatDelay"
сен 23 16:44:19 poh9shka-pc systemsettings[1853]: kf.configwidgets: A widget named "kcfg_resetOldXkbOptions" was found but there is no setting named "resetOldXkbOptions"
сен 23 16:44:19 poh9shka-pc systemsettings[1853]: kf.configwidgets: A widget named "kcfg_configureLayouts" was found but there is no setting named "configureLayouts"
сен 23 16:44:19 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 16:44:19 poh9shka-pc systemsettings[1853]: qml: Pushed pages do not conform to the rules. Please check the documentation.
сен 23 16:45:24 poh9shka-pc plasmashell[1085]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
сен 23 16:47:24 poh9shka-pc krunner[3424]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
сен 23 16:47:26 poh9shka-pc kwin_x11[1055]: kwin_core: XCB error: 152 (BadDamage), sequence: 62549, resource id: 20993051, major code: 143 (DAMAGE), minor code: 3 (Subtract)
сен 23 16:48:40 poh9shka-pc kwin_x11[1055]: kwin_core: XCB error: 152 (BadDamage), sequence: 12891, resource id: 20994376, major code: 143 (DAMAGE), minor code: 3 (Subtract)
сен 23 16:50:39 poh9shka-pc plasmashell[1085]: qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:344:18: QML ScrollView: Binding loop detected for property "calculatedImplicitHeight"
сен 23 16:50:39 poh9shka-pc plasmashell[1085]: qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:401:33: QML Binding: Binding loop detected for property "value"
сен 23 16:50:39 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.keyboardlayout/contents/ui/configGeneral.qml:17:1: QML SimpleKCM: Created graphical object was not placed in the graphics scene.
сен 23 16:50:39 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.keyboardlayout/contents/ui/configGeneral.qml: Setting initial properties failed: SimpleKCM does not have a property called cfg_displayStyleDefault
сен 23 16:50:39 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.keyboardlayout/contents/ui/configGeneral.qml:80:26: QML QQuickItem: Binding loop detected for property "implicitWidth"
сен 23 16:50:39 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.keyboardlayout/contents/ui/configGeneral.qml:80:26: QML QQuickItem: Binding loop detected for property "implicitHeight"
сен 23 16:50:39 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.keyboardlayout/contents/ui/configGeneral.qml:41:26: QML QQuickItem: Binding loop detected for property "implicitWidth"
сен 23 16:50:39 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/plasmoids/org.kde.plasma.keyboardlayout/contents/ui/configGeneral.qml:41:26: QML QQuickItem: Binding loop detected for property "implicitHeight"
сен 23 16:50:39 poh9shka-pc plasmashell[1085]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/AppletConfiguration.qml:142:5: QML Connections: Detected function "onSettingValueChanged" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
сен 23 16:59:51 poh9shka-pc kscreenlocker_greet[4173]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_GB". Search paths QList("/usr/share/qt6/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
сен 23 17:03:30 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 17:03:31 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 17:03:33 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 17:03:35 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 17:03:36 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 17:03:37 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 17:03:38 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
сен 23 17:03:39 poh9shka-pc systemsettings[1853]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_81 to IconPropertiesGroup_QMLTYPE_81
I think it’s time to provide some sytem information. The output from this command may help others have a better understanding of your system:
inxi --admin --verbosity=8 --filter --no-host --width
That’s an easy one.
You must accept responsibility for all software installed from the AUR. If an AUR sourced package breaks, or if it breaks your system, then no support will be offered.
The obvious workaround is to look for alternatives to software you installed from the AUR. Or, at the very least, avoid those that list system-related dependencies also sourced from the AUR. This is generally good strategy.
Don’t get me wrong. I mean, I use a few AUR packages myself; but I always do my homework to see if something might potentially break.
I find that looking at the dependency list at the AUR page is always a good place to start.
Without knowing exactly what those warnings were, it’s difficult to know where to point you. And were they warnings or errors? We don’t know with any certainty, because you have only told us:
And from what I can tell, those were addressed it the previous thread.
The better strategy is to remove the package (grom the AUR) that depend on it, as qt5-tools might be needed for other software that has not as yet transitioned to Qt6. This might also be true of other such dependencies.
At this time all I can offer is a big :man_shrugging:
inxi --admin --verbosity=8 --filter --no-host --width         INT ✘
  Kernel: 6.6.52-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=00fd5d9f-03e3-4285-aa15-246a36fc0ef0 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.5.0
    wm: kwin_x11 with: plank vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop System: Micro-Star product: MS-7C90 v: 1.0
    serial: <superuser required>
  Mobo: Micro-Star model: MPG B550 GAMING CARBON WIFI (MS-7C90) v: 1.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: 1.70 date: 06/25/2021
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M525
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K270
    status: discharging
  System RAM: total: 16 GiB available: 15.54 GiB used: 4.34 GiB (27.9%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF3200C16D4/8GX serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
    desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2200 min/max: 2200/4950 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
    4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
    13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2200 20: 2200
    21: 2200 22: 2200 23: 2200 24: 2200 bogomips: 177681
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    affected
  Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Micro-Star MSI
    driver: nvidia v: 550.120 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-09; EOL~2026-12-xx) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-2019 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none off: DVI-D-1,DVI-I-1,HDMI-A-1 empty: DP-1
    bus-ID: 2b:00.0 chip-ID: 10de:13c2 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4480x1080 s-dpi: 81 s-size: 1405x343mm (55.31x13.50")
    s-diag: 1446mm (56.94") monitors: <missing: xrandr>
  Monitor-1: DVI-D-1 model: LG (GoldStar) L1952HQ serial: <filter>
    built: 2006 res: 1280x1024 dpi: 86 gamma: 1.2 chroma: red: x: 0.647 y: 0.345
    green: x: 0.290 y: 0.604 blue: x: 0.149 y: 0.129 white: x: 0.314 y: 0.329
    size: 376x301mm (14.8x11.85") diag: 482mm (19") ratio: 5:4 modes: 1280x1024,
    1024x768, 800x600, 640x480
  Monitor-2: DVI-I-1 model: BenQ ZOWIE XL LCD serial: <filter> built: 2016
    res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.647 y: 0.345 green:
    x: 0.322 y: 0.635 blue: x: 0.149 y: 0.047 white: x: 0.314 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 1920x1080, 1280x1024, 1440x900, 1024x768, 800x600, 640x480
  Monitor-3: HDMI-A-1 model: LG (GoldStar) L1952HQ serial: <filter>
  Monitor-4: Unknown-1 size-res: N/A modes: 1024x768
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: gbm,wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 970/PCIe/SSE2
    memory: 3.91 GiB
  API: Vulkan v: 1.3.295 layers: 1 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 970 driver: nvidia v: 550.120 device-ID: 10de:13c2
    surfaces: xcb,xlib
  Device-1: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 2b:00.1 chip-ID: 10de:0fbb class-ID: 0403
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: BEHRINGER GmbH UMC404 96k driver: snd-usb-audio type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 1397:0502
    class-ID: fe01
  API: ALSA v: k6.6.52-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 29:00.0
    chip-ID: 8086:2725 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
  IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: Mihomo state: unknown speed: 10000 Mbps duplex: full mac: N/A
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5 chip-ID: 8087:0032
    class-ID: e001
  Local Storage: total: 2.73 TiB used: 93.38 GiB (3.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 38.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX001-1CM164
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
  ID-1: / raw-size: 301 GiB size: 295.21 GiB (98.08%) used: 93.38 GiB (31.6%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 00fd5d9f-03e3-4285-aa15-246a36fc0ef0
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: BOOT
    uuid: 1210-704C
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 8c187444-6fd2-42cd-8c23-4f8d88747ddc
  ID-1: /dev/nvme0n1p10 maj-min: 259:10 size: 68.98 GiB fs: swap label: swap
    uuid: 218e6836-d981-4e47-9bed-e1654c8916de
  ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 100 MiB fs: vfat label: N/A
    uuid: DC86-CD80
  ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-4: /dev/nvme0n1p6 maj-min: 259:6 size: 100.36 GiB fs: ntfs label: N/A
    uuid: B2F6972FF696F2B9
  ID-5: /dev/nvme0n1p7 maj-min: 259:7 size: 540 MiB fs: ntfs label: N/A
    uuid: 1E16056F160548EB
  ID-6: /dev/nvme0n1p8 maj-min: 259:8 size: 300 GiB fs: ntfs label: Other
    uuid: E88E01258E00EDBE
  ID-7: /dev/nvme0n1p9 maj-min: 259:9 size: 152.04 GiB fs: ext4 label: N/A
    uuid: 62cb3507-ef84-4154-a7b1-10b86a7386cf
  ID-8: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: ntfs
    label: \xd0\x92\xd0\xbe\xd1\x81\xd1\x81\xd1\x82\xd0\xb0\xd0\xbd\xd0\xbe\xd0\xb2\xd0\xb8\xd1\x82\xd1\x8c
    uuid: 2E108E45108E144D
  ID-9: /dev/sda10 maj-min: 8:10 size: 548 MiB fs: ntfs label: N/A
    uuid: 28CEB5DBCEB5A20C
  ID-10: /dev/sda11 maj-min: 8:11 size: 199.65 GiB fs: ntfs label: Other HDD
    uuid: 7046C69146C6580C
  ID-11: /dev/sda12 maj-min: 8:12 size: 300.35 GiB fs: ext4 label: N/A
    uuid: b5a79365-7a17-4dfe-aa28-010ce2494461
  ID-12: /dev/sda13 maj-min: 8:13 size: 450 MiB fs: ntfs label: N/A
    uuid: E0F8A0E6F8A0BC62
  ID-13: /dev/sda2 maj-min: 8:2 size: 99 MiB fs: vfat label: N/A
    uuid: 8A90-5087
  ID-14: /dev/sda3 maj-min: 8:3 size: 128 MiB fs: <superuser required>
  ID-15: /dev/sda4 maj-min: 8:4 size: 1.23 TiB fs: ntfs label: Windows HDD
    uuid: F0AC9949AC990B6C
  ID-16: /dev/sda5 maj-min: 8:5 size: 8 GiB fs: swap label: N/A
    uuid: b7dc5edd-5da8-4da2-9a55-7b2e7c325d59
  ID-17: /dev/sda6 maj-min: 8:6 size: 512 MiB fs: vfat label: NO_LABEL
    uuid: CF51-3D2B
  ID-18: /dev/sda7 maj-min: 8:7 size: 100 MiB fs: vfat label: N/A
    uuid: 7A48-E9F9
  ID-19: /dev/sda8 maj-min: 8:8 size: 100 MiB fs: vfat label: N/A
    uuid: 80E5-C4DA
  ID-20: /dev/sda9 maj-min: 8:9 size: 100 MiB fs: vfat label: N/A
    uuid: 9094-1261
  Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-6:3 info: BEHRINGER GmbH UMC404 96k type: audio
    driver: snd-usb-audio interfaces: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 1397:0502 class-ID: fe01
  Device-2: 1-7:4 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c90 class-ID: 0300
    serial: <filter>
  Device-3: 1-9:5 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0032 class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-5: 3-1:2 info: Genesys Logic Hub ports: 3 rev: 2.0
  Device-1: 3-1.2:3 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 50.9 C mobo: N/A gpu: nvidia temp: 48 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 32%
  Packages: pm: pacman pkgs: 1286 libs: 338 tools: pamac pm: flatpak pkgs: 0
    1: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    2: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    3: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    4: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    6: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 447
  1: cpu: 4.7% command: chrome pid: 4988 mem: 202.5 MiB (1.2%)
  2: cpu: 2.8% command: chrome pid: 4257 mem: 311.5 MiB (1.9%)
  3: cpu: 2.3% command: chrome pid: 4014 mem: 316.6 MiB (1.9%)
  4: cpu: 1.7% command: chrome pid: 49320 mem: 250.9 MiB (1.5%)
  5: cpu: 1.6% command: chrome pid: 49351 mem: 269.9 MiB (1.6%)
  Memory top: 5 of 447
  1: mem: 742.9 MiB (4.6%) command: plasmashell pid: 3542 cpu: 0.5%
  2: mem: 575.2 MiB (3.6%) command: chrome pid: 3966 cpu: 1.0%
  3: mem: 318.9 MiB (2.0%) command: chrome pid: 4251 cpu: 0.7%
  4: mem: 316.6 MiB (1.9%) command: chrome pid: 4014 cpu: 2.3%
  5: mem: 312.7 MiB (1.9%) command: kwin_x11 pid: 3512 cpu: 1.1%
  Processes: 447 Power: uptime: 1h 44m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.32 running-in: konsole inxi: 3.3.36
pactree -r qt5-base
pactree -r qt5-base         ✔
qt5-base
├─karchive5
│ └─kiconthemes5
│   └─kxmlgui5
│     ├─kbookmarks5
│     │ └─kio5
│     │   └─skanlite
│     └─skanlite
├─kcodecs5
│ └─kconfigwidgets5
│   ├─kiconthemes5
│   ├─ktextwidgets5
│   │ ├─kio5
│   │ └─libksane5
│   │   └─skanlite
│   ├─kwallet5
│   │ ├─kio5
│   │ └─libksane5
│   └─skanlite
├─kconfig5
│ ├─kcompletion5
│ │ └─ktextwidgets5
│ ├─kconfigwidgets5
│ ├─kglobalaccel5
│ │ └─kxmlgui5
│ ├─knotifications5
│ │ ├─kwallet5
│ │ └─manjaro-settings-manager-knotifier
│ ├─kservice5
│ │ ├─kded5
│ │ │ └─kio5
│ │ └─kwallet5
│ └─skanlite
├─kcoreaddons5
│ ├─kauth5
│ │ ├─kconfigwidgets5
│ ├─kcrash5
│ │ └─kded5
│ ├─kglobalaccel5
│ ├─kjobwidgets5
│ │ ├─kio5
│ │ └─skanlite
│ ├─knotifications5
│ ├─kservice5
│ ├─manjaro-settings-manager
│ └─skanlite
├─kitemmodels5
├─kitemviews5
│ └─kxmlgui5
├─ksanecore5
│ └─libksane5
├─kwayland-integration
├─kwidgetsaddons5
│ ├─kcompletion5
│ ├─kconfigwidgets5
│ ├─kjobwidgets5
│ ├─libksane5
│ └─skanlite
├─libdbusmenu-qt5
│ └─knotifications5
├─libksane5
├─polkit-qt5
│ └─kauth5
├─python-pyqt5
│ └─torbrowser-launcher
├─qca-qt5
│ └─kwallet5
├─qt5-declarative
│ ├─ki18n5
│ │ ├─ksanecore5
│ │ ├─kservice5
│ │ ├─libksane5
│ │ └─skanlite
│ └─qt5-wayland
│   ├─kguiaddons5
│   │ └─kconfigwidgets5
│   ├─kwayland-integration
│   └─kwayland5
│     └─kwayland-integration
├─qt5-multimedia
│ └─qt5-speech
│   ├─knotifications5
│   └─ktextwidgets5
├─qt5-svg
│ ├─kiconthemes5
│ └─vlc
│   ├─elisa
│   └─phonon-qt6-vlc
│     └─phonon-qt6
│       ├─dolphin
│       │ └─dolphin-plugins
│       ├─gwenview
│       ├─kio-extras
│       │ ├─dolphin
│       │ └─plasma-workspace
│       │   ├─kdeplasma-addons
│       │   ├─plasma-browser-integration
│       │   ├─plasma-desktop
│       │   ├─plasma-nm
│       │   ├─plasma-pa
│       │   ├─powerdevil
│       │   │ └─plasma-desktop
│       │   ├─sddm-breath-theme
│       │   │ └─manjaro-kde-settings
│       │   └─xdg-desktop-portal-kde
│       │     └─plasma-integration
│       ├─libkcompactdisc
│       │ └─audiocd-kio
│       ├─okular
│       ├─phonon-qt6-vlc
├─qt5-x11extras
│ ├─kdbusaddons5
│ │ └─kservice5
│ ├─kguiaddons5
│ ├─kjobwidgets5
│ ├─kwindowsystem5
│ │ ├─kcrash5
│ │ ├─kglobalaccel5
│ │ ├─knotifications5
│ │ └─kwayland-integration
│ └─vlc
├─skanlite
├─solid5
│ └─kio5
├─sonnet5
│ └─ktextwidgets5
└─vlc
Maybe do I need to delete the vlc package? But elisa depends on it. And I installed it without using AUR:
extra/phonon-qt6-vlc 0.12.0-2 [installed]
    Phonon VLC backend for Qt6
extra/vlc 3.0.21-3 [installed]
    Multi-platform MPEG, VCD/DVD, and DivX player
I can see that many manjaro packages depend on qt5…
I don’t have a lot of AUR packages:
pacman -Qm
anki-bin 24.06.3-1
clash-verge-rev-bin 1.7.7-3
google-chrome 129.0.6668.70-1
postgresql15 15.8-1
postgresql15-libs 15.8-1
postman-bin 11.14.0-1
telegram-desktop-bin 5.5.5-1
visual-studio-code-bin 1.93.1-1
And when I was working on plasma5 there was no this problem.
And so do others. I can’t think which, at the moment, but I do know VLC is being used as a backend to support a few applications. Someone else can better explain the reasons why.
Many Linux packages depend on Qt5, and more recently, Qt6. The general transition from Qt5 to Qt6 is ongoing, and occasional difficulties are to be expected. At the moment, there are a mixture of Qt6 and Qt5 dependencies, I notice, but it’s not a good idea to go randomly removing Qt5 support yet.
Dependency wise you cannot easily remove vlc because plasma-workspace depend on phonon-qt6 which will pull in vlc as backend with phonon-qt6-vlc.
Technically you can remove vlc - by providing another phonon backend - from the package phonon-qt6-mpv (AUR). This did not have any negative impact on my system.
It is also possible to remove vlc without regard for dependency - using the -Rdd option to pacman. I cannot deduce whether this will have an negative effect on the system.
That said I don’t think you issue is caused be a specific media player package.
I have a lot of messages even a few coredumps in my log - none of this is a deal breaker by any measure → https://0x0.st/Xghe.txt.
You cannot have a system without errors in your log - no software is that perfect - and chasing them is a rabbit hole I don’t want to enter.
I did a search for a keyword in your log - gmenudbusmenuproxy - did you try such a search?
It seems to point to Plasma’s global menu - Is it what I think? The type of menu which provides the active application’s menu in an Apple macOS fashion at the top of the screen?
Yes, I understand it. Warnings are not bothering me. My system crashes sometimes. That’s really frustrating. And I cannot see some regularity of these crashes. It just happens. It may not happen for a while, then it will happen more.
Yes, I googled it but found nothing helpful. Perhaps, I need to be more attentive. But after I removed my qt5-tools library. The error message when my system crashes changed:
stacktrace
окт 03 09:17:53 poh9shka-pc plasmashell[1115]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:334:17: QML SpinBox: Binding loop detected for property "implicitWidth"
окт 03 09:17:53 poh9shka-pc plasmashell[1115]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
окт 03 09:18:12 poh9shka-pc plasmashell[1115]: kf.kio.core: Url QUrl("file:///home/poh9shka/.local/share/plasma_icons/164845.desktop") already represents a local file, cancelling job.
окт 03 09:18:24 poh9shka-pc systemd[980]: dbus-:1.2-org.kde.KSplash@0.service: Failed with result 'exit-code'.
окт 03 09:23:33 poh9shka-pc plasmashell[1115]: file:///usr/share/plasma/plasmoids/org.kde.plasma.keyboardindicator/contents/ui/main.qml:61:13: Unable to assign [undefined] to bool
окт 03 09:37:47 poh9shka-pc kdeconnectd[1317]: 2024-10-03T09:37:47 default: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
окт 03 09:37:47 poh9shka-pc kdeconnectd[1317]: 2024-10-03T09:37:47 kdeconnect.plugin.battery: No Primary Battery detected on this system. This may be a bug.
окт 03 09:37:47 poh9shka-pc kdeconnectd[1317]: 2024-10-03T09:37:47 kdeconnect.plugin.battery: Total quantity of batteries found:  2
окт 03 09:37:47 poh9shka-pc kdeconnectd[1317]: 2024-10-03T09:37:47 kdeconnect.plugin.battery: Primary Battery seems to have been removed. Suspending packets until it is reconnected.
окт 03 09:37:47 poh9shka-pc kdeconnectd[1317]: 2024-10-03T09:37:47 org.kde.pulseaudio: No object for name "alsa_output.pci-0000_2d_00.4.analog-stereo.monitor"
окт 03 09:37:47 poh9shka-pc plasmashell[1115]: qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:344:18: QML ScrollView: Binding loop detected for property "calculatedImplicitHeight"
окт 03 09:37:47 poh9shka-pc plasmashell[1115]: qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:401:33: QML Binding: Binding loop detected for property "value"
окт 03 09:37:48 poh9shka-pc kdeconnectd[1317]: 2024-10-03T09:37:48 kdeconnect.plugin.clipboard: Ignoring clipboard without timestamp
окт 03 09:44:17 poh9shka-pc kscreenlocker_greet[3040]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US". Search paths QList("/usr/share/qt6/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
окт 03 09:48:34 poh9shka-pc org_kde_powerdevil[1198]: dh=Display_Handle[i2c-3: fd=38], Keeping adjusted sleep multiplier 1,00 for SE_POST_WRITE or SE_POST_SAVE_SETTINGS
окт 03 09:49:21 poh9shka-pc kded6[1084]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_2d_00.4.analog-stereo.monitor"
окт 03 09:49:21 poh9shka-pc kded6[1084]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_2d_00.4.analog-stereo"
окт 03 09:49:21 poh9shka-pc plasmashell[1115]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_2d_00.4.analog-stereo.monitor"
окт 03 09:49:21 poh9shka-pc kdeconnectd[1317]: 2024-10-03T09:49:21 org.kde.pulseaudio: No object for name "alsa_output.pci-0000_2d_00.4.analog-stereo.monitor"
окт 03 09:49:21 poh9shka-pc kdeconnectd[1317]: 2024-10-03T09:49:21 org.kde.pulseaudio: No object for name "alsa_output.pci-0000_2d_00.4.analog-stereo"
окт 03 09:49:21 poh9shka-pc kded6[1084]: org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
окт 03 09:49:21 poh9shka-pc plasmashell[1115]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:76: TypeError: Cannot read property 'pulseProperties' of undefined
окт 03 09:49:21 poh9shka-pc kded6[1084]: org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
окт 03 09:49:21 poh9shka-pc kdeconnectd[1317]: 2024-10-03T09:49:21 org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
окт 03 09:49:21 poh9shka-pc kdeconnectd[1317]: 2024-10-03T09:49:21 org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
окт 03 09:49:21 poh9shka-pc kded6[1084]: org.kde.pulseaudio: No object for name "auto_null.monitor"
окт 03 09:49:21 poh9shka-pc kdeconnectd[1317]: 2024-10-03T09:49:21 org.kde.pulseaudio: No object for name "auto_null.monitor"
окт 03 09:49:21 poh9shka-pc systemd-coredump[3299]: [🡕] Process 920 (Xorg) of user 0 dumped core.
                                                       Stack trace of thread 920:
                                                       #0  0x00007f7531d4d3f4 n/a (libc.so.6 + 0x963f4)
                                                       #1  0x00007f7531cf4120 raise (libc.so.6 + 0x3d120)
                                                       #2  0x00007f7531cdb4c3 abort (libc.so.6 + 0x244c3)
                                                       #3  0x000055fb751ca12e OsAbort (Xorg + 0x14b12e)
                                                       #4  0x000055fb751cb5e7 FatalError (Xorg + 0x14c5e7)
                                                       #5  0x000055fb751d2268 n/a (Xorg + 0x153268)
                                                       #6  0x00007f7531cf41d0 n/a (libc.so.6 + 0x3d1d0)
                                                       #7  0x00007f7530eb0b35 n/a (nvidia_drv.so + 0x4b0b35)
окт 03 09:49:21 poh9shka-pc pamac-tray-plasma[1342]: The X11 connection broke (error 1). Did the X11 server die?
окт 03 09:49:21 poh9shka-pc msm_kde_notifier[1316]: The X11 connection broke (error 1). Did the X11 server die?
окт 03 09:49:21 poh9shka-pc kdeconnectd[1317]: 2024-10-03T09:49:21 default: The X11 connection broke (error 1). Did the X11 server die?
окт 03 09:49:21 poh9shka-pc kaccess[1337]: The X11 connection broke (error 1). Did the X11 server die?
окт 03 09:49:21 poh9shka-pc polkit-kde-authentication-agent-1[1197]: The X11 connection broke (error 1). Did the X11 server die?
окт 03 09:49:21 poh9shka-pc xdg-desktop-portal-kde[1199]: The X11 connection broke (error 1). Did the X11 server die?
окт 03 09:49:21 poh9shka-pc org_kde_powerdevil[1198]: The X11 connection broke (error 1). Did the X11 server die?
окт 03 09:49:21 poh9shka-pc xembedsniproxy[1200]: The X11 connection broke (error 1). Did the X11 server die?
окт 03 09:49:21 poh9shka-pc kded6[1084]: The X11 connection broke: I/O error (code 1)
окт 03 09:49:21 poh9shka-pc kscreen_backend_launcher[1195]: The X11 connection broke (error 1). Did the X11 server die?
окт 03 09:49:21 poh9shka-pc gmenudbusmenuproxy[1196]: The X11 connection broke (error 1). Did the X11 server die?
окт 03 09:49:21 poh9shka-pc ksmserver[1082]: The X11 connection broke (error 1). Did the X11 server die?
окт 03 09:49:21 poh9shka-pc kactivitymanagerd[1192]: The X11 connection broke (error 1). Did the X11 server die?
окт 03 09:49:21 poh9shka-pc kglobalacceld[1033]: The X11 connection broke (error 1). Did the X11 server die?
окт 03 09:49:21 poh9shka-pc plasmashell[1115]: kf.plasma.quick: Couldn't create KWindowShadow for Osd_QMLTYPE_5(0x555862d75df0)
окт 03 09:49:21 poh9shka-pc kwalletd6[997]: The X11 connection broke (error 1). Did the X11 server die?
окт 03 09:49:21 poh9shka-pc kwin_x11[1085]: The X11 connection broke: I/O error (code 1)
окт 03 09:49:21 poh9shka-pc systemd[980]: dbus-:1.48-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
окт 03 09:49:21 poh9shka-pc kglobalacceld[1033]: The X11 connection broke: I/O error (code 1)
окт 03 09:49:21 poh9shka-pc plasmashell[1115]: The X11 connection broke (error 1). Did the X11 server die?
окт 03 09:49:21 poh9shka-pc kdeconnectd[1317]: 2024-10-03T09:49:21 org.kde.pulseaudio: No object for name "auto_null"
окт 03 09:49:21 poh9shka-pc kded6[1084]: org.kde.pulseaudio: No object for name "auto_null"
окт 03 09:49:21 poh9shka-pc systemd[980]: plasma-xembedsniproxy.service: Failed with result 'exit-code'.
окт 03 09:49:21 poh9shka-pc startplasma-x11[998]: org.kde.startup: "kdeinit5_shutdown" QList() exited with code 255
окт 03 09:49:21 poh9shka-pc systemd[980]: bamfdaemon.service: Failed with result 'exit-code'.
окт 03 09:49:21 poh9shka-pc plasmashell[1115]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_2d_00.4.analog-stereo"
окт 03 09:49:21 poh9shka-pc systemd[980]: app-msm_kde_notifier@autostart.service: Failed with result 'exit-code'.
окт 03 09:49:21 poh9shka-pc systemd[980]: plasma-gmenudbusmenuproxy.service: Failed with result 'exit-code'.
окт 03 09:49:21 poh9shka-pc systemd[980]: app-plank@autostart.service: Failed with result 'exit-code'.
окт 03 09:49:21 poh9shka-pc systemd[980]: plasma-ksmserver.service: Failed with result 'exit-code'.
окт 03 09:49:21 poh9shka-pc systemd[980]: plasma-kded6.service: Failed with result 'exit-code'.
окт 03 09:49:21 poh9shka-pc systemd[980]: plasma-kwin_x11.service: Failed with result 'exit-code'.
окт 03 09:49:22 poh9shka-pc plasmashell[1115]: file:///usr/share/plasma/plasmoids/org.kde.plasma.clipboard/contents/ui/ClipboardPage.qml:131:9: QML KSortFilterProxyModel: Unable to assign [undefined] to "sourceModel"
окт 03 09:49:22 poh9shka-pc dbus-broker-launch[3395]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
окт 03 09:49:22 poh9shka-pc dbus-broker-launch[3395]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
окт 03 09:49:22 poh9shka-pc dbus-broker-launch[3395]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
окт 03 09:49:22 poh9shka-pc sddm-greeter-qt6[3391]: KeyStatesEngine is deprecated. Use KeyState from org.kde.plasma.private.keyboardindicator instead.
окт 03 09:49:24 poh9shka-pc systemd-coredump[3372]: [🡕] Process 1115 (plasmashell) of user 1000 dumped core.
                                                       Stack trace of thread 1115:
                                                       #0  0x00007f9da6a00e20 n/a (libQt6Core.so.6 + 0x600e20)
                                                       #1  0x00007f9da5630275 _ZN17QQmlDelegateModel22_q_modelAboutToBeResetEv (libQt6QmlModels.so.6 + 0x71275)
                                                       #2  0x00007f9da65a3397 n/a (libQt6Core.so.6 + 0x1a3397)
                                                       #3  0x00007f9da674ece0 _ZN18QAbstractItemModel15beginResetModelEv (libQt6Core.so.6 + 0x34ece0)
                                                       #4  0x00007f9da678f1a6 _ZN21QSortFilterProxyModel14setSourceModelEP18QAbstractItemModel (libQt6Core.so.6 + 0x38f1a6)
                                                       #5  0x00007f9d59355a5f n/a (libitemmodelsplugin.so + 0xea5f)
                                                       #6  0x00007f9da6772b4a n/a (libQt6Core.so.6 + 0x372b4a)
                                                       #7  0x00007f9da65a057d _ZN23QPropertyBindingPrivate17evaluateRecursiveER15QVarLengthArrayI19QBindingObserverPtrLx256EEP14QBindingStatus (libQt6Core.so.6 + 0x1a057d)
                                                       #8  0x00007f9da78ff4dd _ZN21QQmlPropertyBindingJS17expressionChangedEv (libQt6Qml.so.6 + 0x2ff4dd)
                                                       #9  0x00007f9da78dba4c _ZN12QQmlNotifier10emitNotifyEP20QQmlNotifierEndpointPPv (libQt6Qml.so.6 + 0x2dba4c)
                                                       #10 0x00007f9da65a30ea n/a (libQt6Core.so.6 + 0x1a30ea)
                                                       #11 0x00007f9da78f3ee1 _ZN18QQmlOpenMetaObject15checkedSetValueEiRK8QVariantb (libQt6Qml.so.6 + 0x2f3ee1)
                                                       #12 0x00007f9da797ef85 _ZN15QQmlPropertyMap5clearERK7QString (libQt6Qml.so.6 + 0x37ef85)
                                                       #13 0x00007f9da65a3397 n/a (libQt6Core.so.6 + 0x1a3397)
                                                       #14 0x00007f9da65926e6 _ZN7QObjectD1Ev (libQt6Core.so.6 + 0x1926e6)
                                                       #15 0x00007f9d58303b73 n/a (plasma_engine_clipboard.so + 0x3ab73)
                                                       #16 0x00007f9da658c60b _ZN14QObjectPrivate14deleteChildrenEv (libQt6Core.so.6 + 0x18c60b)
                                                       #17 0x00007f9da6592678 _ZN7QObjectD1Ev (libQt6Core.so.6 + 0x192678)
                                                       #18 0x00007f9d8812a796 _ZN14Plasma5Support13DataContainerD0Ev (libPlasma5Support.so.6 + 0xe796)
                                                       #19 0x00007f9da658c60b _ZN14QObjectPrivate14deleteChildrenEv (libQt6Core.so.6 + 0x18c60b)
                                                       #20 0x00007f9da6592678 _ZN7QObjectD1Ev (libQt6Core.so.6 + 0x192678)
                                                       #21 0x00007f9d582f1ec0 n/a (plasma_engine_clipboard.so + 0x28ec0)
                                                       #22 0x00007f9d88133770 n/a (libPlasma5Support.so.6 + 0x17770)
                                                       #23 0x00007f9d88133b0d n/a (libPlasma5Support.so.6 + 0x17b0d)
                                                       #24 0x00007f9da6a4e891 n/a (libc.so.6 + 0x3f891)
                                                       #25 0x00007f9da6a4e95e exit (libc.so.6 + 0x3f95e)
                                                       #26 0x00007f9da04137d5 n/a (libQt6XcbQpa.so.6 + 0x247d5)
                                                       #27 0x00007f9da0440b7f n/a (libQt6XcbQpa.so.6 + 0x51b7f)
                                                       #28 0x00007f9da5330299 n/a (libglib-2.0.so.0 + 0x5d299)
                                                       #29 0x00007f9da5392ec7 n/a (libglib-2.0.so.0 + 0xbfec7)
                                                       #30 0x00007f9da532f795 g_main_context_iteration (libglib-2.0.so.0 + 0x5c795)
                                                       #31 0x00007f9da67a82bd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a82bd)
                                                       #32 0x00007f9da654ff66 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14ff66)
                                                       #33 0x00007f9da654a11d _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x14a11d)
                                                       #34 0x0000555858f82d86 n/a (plasmashell + 0x26d86)
                                                       #35 0x00007f9da6a34e08 n/a (libc.so.6 + 0x25e08)
                                                       #36 0x00007f9da6a34ecc __libc_start_main (libc.so.6 + 0x25ecc)
                                                       #37 0x0000555858f83275 n/a (plasmashell + 0x27275)
                                                       Stack trace of thread 1144:
                                                       #0  0x00007f9da6b1a63d __poll (libc.so.6 + 0x10b63d)
                                                       #1  0x00007f9da5392e0d n/a (libglib-2.0.so.0 + 0xbfe0d)
                                                       #2  0x00007f9da532f795 g_main_context_iteration (libglib-2.0.so.0 + 0x5c795)
                                                       #3  0x00007f9da67a82bd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a82bd)
                                                       #4  0x00007f9da654ff66 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14ff66)
                                                       #5  0x00007f9da663d650 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23d650)
                                                       #6  0x00007f9da83bdf0e n/a (libQt6DBus.so.6 + 0x2df0e)
                                                       #7  0x00007f9da66cd237 n/a (libQt6Core.so.6 + 0x2cd237)
                                                       #8  0x00007f9da6aa339d n/a (libc.so.6 + 0x9439d)
                                                       #9  0x00007f9da6b2849c n/a (libc.so.6 + 0x11949c)
                                                       Stack trace of thread 1479:
                                                       #0  0x00007f9da6a9fa19 n/a (libc.so.6 + 0x90a19)
                                                       #1  0x00007f9da6aa2479 pthread_cond_wait (libc.so.6 + 0x93479)
                                                       #2  0x00007f9da66d1c60 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x2d1c60)
                                                       #3  0x00007f9da8019f3a n/a (libQt6Quick.so.6 + 0x419f3a)
                                                       #4  0x00007f9da66cd237 n/a (libQt6Core.so.6 + 0x2cd237)
                                                       #5  0x00007f9da6aa339d n/a (libc.so.6 + 0x9439d)
                                                       #6  0x00007f9da6b2849c n/a (libc.so.6 + 0x11949c)
                                                       Stack trace of thread 1279:
                                                       #1  0x00007f9d9d413fc7 n/a (libnvidia-glcore.so.550.120 + 0xa13fc7)
                                                       #2  0x00007f9d9d3f5754 n/a (libnvidia-glcore.so.550.120 + 0x9f5754)
                                                       #3  0x00007f9da6aa339d n/a (libc.so.6 + 0x9439d)
                                                       #4  0x00007f9da6b2849c n/a (libc.so.6 + 0x11949c)
                                                       Stack trace of thread 2093:
                                                       Stack trace of thread 1449:
                                                       #6  0x00007f9d4cf06750 _ZN15KCupsConnection3runEv (libkcupslib.so.6.1.5 + 0x2d750)
                                                       Stack trace of thread 1373:
                                                       Stack trace of thread 1429:
                                                       Stack trace of thread 1230:
                                                       #5  0x00007f9da663d7a0 _ZN7QThread3runEv (libQt6Core.so.6 + 0x23d7a0)
                                                       #6  0x00007f9da66cd237 n/a (libQt6Core.so.6 + 0x2cd237)
                                                       #7  0x00007f9da6aa339d n/a (libc.so.6 + 0x9439d)
                                                       #8  0x00007f9da6b2849c n/a (libc.so.6 + 0x11949c)
                                                       Stack trace of thread 1264:
                                                       Stack trace of thread 1439:
                                                       #6  0x00007f9da7f63bd8 n/a (libQt6Quick.so.6 + 0x363bd8)
                                                       Stack trace of thread 1457:
                                                       Stack trace of thread 1412:
                                                       Stack trace of thread 1519:
                                                       Stack trace of thread 1448:
                                                       #1  0x00007f9d586339b7 n/a (libpulse.so.0 + 0x339b7)
                                                       #2  0x00007f9d5861d45c pa_mainloop_poll (libpulse.so.0 + 0x1d45c)
                                                       #3  0x00007f9d5862761c pa_mainloop_iterate (libpulse.so.0 + 0x2761c)
                                                       #4  0x00007f9d586276d1 pa_mainloop_run (libpulse.so.0 + 0x276d1)
                                                       #5  0x00007f9d58637bf2 n/a (libpulse.so.0 + 0x37bf2)
                                                       #6  0x00007f9d585d52b7 n/a (libpulsecommon-17.0.so + 0x5c2b7)
окт 03 09:49:24 poh9shka-pc systemd[980]: plasma-plasmashell.service: Main process exited, code=dumped, status=11/SEGV
окт 03 09:49:24 poh9shka-pc systemd[980]: plasma-plasmashell.service: Failed with result 'core-dump'.
It seems that I don’t use it because my applications have their menus in their windows. If I correctly understood it used for popup notifications:
pactree -r libdbusmenu-qt5         ✔
libdbusmenu-qt5
└─knotifications5
  ├─kwallet5
  │ ├─kio5
  │ │ └─skanlite
  │ └─libksane5
  │   └─skanlite
It seems that the core of the problem is plasma_engine_clipboard.so.
And we can see some bugs with plasma crashes here: Bug List
I will try to open my own bug report.
