Thanks for your reply and help.
And the folow text is the output of my device that you need.
-> lspci -v
00:00.0 Host bridge: Intel Corporation Comet Lake-U v1 4c Host Bridge/DRAM Controller (rev 0c)
Subsystem: Intel Corporation Comet Lake-U v1 4c Host Bridge/DRAM Controller
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: skl_uncore
00:02.0 VGA compatible controller: Intel Corporation CometLake-U GT2 [UHD Graphics] (rev 02) (prog-if 00 [VGA controller])
DeviceName: VGA compatible controller
Subsystem: Intel Corporation CometLake-U GT2 [UHD Graphics]
Flags: bus master, fast devsel, latency 0, IRQ 148
Memory at b0000000 (64-bit, non-prefetchable) [size=16M]
Memory at a0000000 (64-bit, prefetchable) [size=256M]
I/O ports at 1000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: i915
Kernel modules: i915
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 0c)
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at 25e800000 (64-bit, non-prefetchable) [size=32K]
Kernel driver in use: proc_thermal
Kernel modules: processor_thermal_device
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
Flags: bus master, fast devsel, latency 0, IRQ 255
Memory at 9fa1c000 (64-bit, non-prefetchable) [size=4K]
00:12.0 Signal processing controller: Intel Corporation Comet Lake Thermal Subsytem
Subsystem: Intel Corporation Comet Lake Thermal Subsytem
Memory at 9fa1d000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:14.0 USB controller: Intel Corporation Comet Lake PCH-LP USB 3.1 xHCI Host Controller (prog-if 30 [XHCI])
Subsystem: Intel Corporation Device 7270
Flags: bus master, medium devsel, latency 0, IRQ 133
Memory at 9fa00000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 RAM memory: Intel Corporation Comet Lake PCH-LP Shared SRAM
Memory at 9fa18000 (64-bit, non-prefetchable) [size=8K]
Memory at 9fa1e000 (64-bit, non-prefetchable) [size=4K]
00:14.3 Network controller: Intel Corporation Comet Lake PCH-LP CNVi WiFi
Subsystem: Intel Corporation Wi-Fi 6 AX201 160MHz
Memory at 9fa10000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
00:14.5 SD Host controller: Intel Corporation Comet Lake PCH-LP SCS3 (prog-if 01)
Subsystem: Intel Corporation Comet Lake PCH-LP SCS3
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at 9fa1f000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: sdhci-pci
Kernel modules: sdhci_pci
00:15.0 Serial bus controller [0c80]: Intel Corporation Serial IO I2C Host Controller
Subsystem: Intel Corporation Serial IO I2C Host Controller
Memory at 9fa20000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.1 Serial bus controller [0c80]: Intel Corporation Comet Lake Serial IO I2C Host Controller
Subsystem: Intel Corporation Comet Lake Serial IO I2C Host Controller
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at 9fa21000 (64-bit, non-prefetchable) [size=4K]
00:17.0 SATA controller: Intel Corporation Comet Lake SATA AHCI Controller (prog-if 01 [AHCI 1.0])
DeviceName: SATA controller
Subsystem: Intel Corporation Comet Lake SATA AHCI Controller
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 123
Memory at 9fa1a000 (32-bit, non-prefetchable) [size=8K]
Memory at 9fa27000 (32-bit, non-prefetchable) [size=256]
I/O ports at 1060 [size=8]
I/O ports at 1068 [size=4]
I/O ports at 1040 [size=32]
Memory at 9fa26000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:19.0 Serial bus controller [0c80]: Intel Corporation Comet Lake Serial IO I2C Host Controller
Flags: bus master, fast devsel, latency 0, IRQ 32
Memory at 9fa22000 (64-bit, non-prefetchable) [size=4K]
00:1d.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #9 (rev f0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: 9f800000-9f8fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
Kernel driver in use: pcieport
00:1e.0 Communication controller: Intel Corporation Device 02a8
Subsystem: Intel Corporation Device 02a8
Flags: bus master, fast devsel, latency 0, IRQ 20
Memory at fe032000 (64-bit, non-prefetchable) [size=4K]
Memory at 9fa23000 (64-bit, non-prefetchable) [size=4K]
00:1e.2 Serial bus controller [0c80]: Intel Corporation Device 02aa
Subsystem: Intel Corporation Device 02aa
Flags: bus master, fast devsel, latency 0, IRQ 22
Memory at 9fa24000 (64-bit, non-prefetchable) [size=4K]
00:1f.0 ISA bridge: Intel Corporation Comet Lake PCH-LP LPC Premium Controller/eSPI Controller
Subsystem: Intel Corporation Comet Lake PCH-LP LPC Premium Controller/eSPI Controller
00:1f.3 Multimedia audio controller: Intel Corporation Comet Lake PCH-LP cAVS
DeviceName: Multimedia audio controller
Flags: bus master, fast devsel, latency 64, IRQ 16
Memory at 9fa14000 (64-bit, non-prefetchable) [size=16K]
Memory at 9f900000 (64-bit, non-prefetchable) [size=1M]
Kernel driver in use: sof-audio-pci-intel-cnl
Kernel modules: snd_hda_intel, snd_soc_skl, snd_sof_pci_intel_cnl
00:1f.4 SMBus: Intel Corporation Comet Lake PCH-LP SMBus Host Controller
Subsystem: Intel Corporation Comet Lake PCH-LP SMBus Host Controller
Flags: medium devsel, IRQ 16
Memory at 9fa28000 (64-bit, non-prefetchable) [size=256]
I/O ports at efa0 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Comet Lake SPI (flash) Controller
Subsystem: Intel Corporation Comet Lake SPI (flash) Controller
Flags: fast devsel
Memory at fe010000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel-spi
Kernel modules: intel_spi_pci
01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd Device a809 (prog-if 02 [NVM Express])
Subsystem: Samsung Electronics Co Ltd Device a801
Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0
Memory at 9f800000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: nvme
->inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6dcbdc24-48f6-41f8-b9b8-432fa825d788 rw quiet
resume=UUID=ee952072-18e2-4d78-aa5b-131f2311a3b6 udev.log_priority=3
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: Google product: Akemi v: rev1 serial: <filter> Chassis:
type: 9 serial: <filter>
Mobo: Google model: Akemi v: rev1 serial: <filter> UEFI: coreboot
v: MrChromebox-4.14 date: 07/25/2021
ID-1: BAT0 charge: 12.1 Wh (24.4%) condition: 49.5/51.0 Wh (97.0%)
volts: 8.0 min: 7.7 model: LGC LNV-5B1 type: Li-ion serial: <filter>
status: Charging cycles: 21
RAM: total: 7.64 GiB used: 1.51 GiB (19.7%)
Info: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: EA cache: L2: 6 MiB bogomips: 33615
Speed: 1000 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 1000 2: 1000
3: 1000 4: 1000 5: 1000 6: 1000 7: 1000 8: 1000
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics] driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-7:2
chip-ID: 04f2:b6d8 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0401
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: no
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
port: 1000 bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
bus-ID: 1-10:3 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 119.24 GiB used: 9.98 GiB (8.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ128HBHQ-000L2
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 3L1QFXV7 temp: 23.9 C scheme: GPT
ID-1: / raw-size: 110.15 GiB size: 107.86 GiB (97.92%) used: 9.98 GiB (9.3%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 6dcbdc24-48f6-41f8-b9b8-432fa825d788
label: NO_LABEL uuid: 52AB-4ED5
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: ee952072-18e2-4d78-aa5b-131f2311a3b6
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-7:2 info: Chicony Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b6d8
Device-2: 1-10:3 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 38.0 C mobo: N/A
Processes: 275 Uptime: 9m wakeups: 5300 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1030 lib: 281 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.06
->aplay -l
aplay: device_list:274: no soundcards found...
