The processor runs at a frequency of 400 MHz, Linux kernel > 5.15
The laptop is a Dell Latitude 5430, i5-1235u. I bought this laptop cheaply, replaced the SSD, and upgraded the RAM to 64GB. So far, everything works as expected. I’ve been using it for a year and a half and decided to replace the screen’s matrix, swapping the stock 250 cd/m² panel for a 400 cd/m² one.
I bought the new screen and replaced it, but after powering on, everything was very slow. The Btop shows the processor frequency at 400 MHz. I thought the issue might be with my Manjaro distribution, but after testing live USBs of Ubuntu, Fedora, and Manjaro with kernel version 6 and above, the issue persists with the new screen across all distributions.
However, if I boot any live USB distribution with kernel 5.15 or lower, the issue disappears. On my installed Manjaro system, I also downgraded to kernel 5.15 so I could continue working.
Out of curiosity, I put the old screen back in, and the problem disappears. The issue also doesn’t occur when using an external monitor without the laptop’s built-in screen. However, the old screen is quite dim, and it’s uncomfortable to work outside or near a window on bright days.
Changing power profiles doesn’t resolve the issue.
inxi --admin --verbosity=8 --filter --no-host --width
Log result
inxi --admin --verbosity=8 --filter --no-host --width                                              ─╯
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=8772a129-9dcd-48a2-9220-a4fb1ba1ff09 rw intel_pstate=enable
    quiet splash udev.log_priority=3 acpi_sleep=deep
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Laptop System: Dell product: Latitude 5430 v: N/A
  Mobo: Dell model: 01Y2TP v: A00 serial: <superuser required> part-nu: 0B04
    uuid: <superuser required> UEFI: Dell v: 1.22.1 date: 04/26/2024
  ID-1: BAT0 charge: 16.4 Wh (35.7%) condition: 46.0/58.0 Wh (79.3%)
    volts: 15.7 min: 15.2 model: BYD DELL H4PVC25 type: Li-poly serial: <filter>
    status: charging
  System RAM: total: 64 GiB available: 62.49 GiB used: 2.3 GiB (3.7%)
  Device-1: DIMM A type: DDR4 detail: synchronous size: 32 GiB
    speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: 04CD000080AD part-no: F4-3200C22-32GRS serial: <filter>
  Device-2: DIMM B type: DDR4 detail: synchronous size: 32 GiB
    manufacturer: 04CB000002B5 part-no: N/A serial: <filter>
  Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
    arch: Alder Lake level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
    microcode: 0x435
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 10 threads: 12 mt: 2 tpc: 2
    st: 8 smt: enabled cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32
    KiB, 8x64 KiB L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 400 min/max: 400/4400:3300 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 59916
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
    sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
    xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Dell
    driver: i915 v: kernel alternate: xe arch: Gen-12.2 process: Intel 10nm
    built: 2021-22+ ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:46a8 class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
    device-ID: 8086:46a8 memory: 30.51 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.303 layers: 4 device: 0 type: integrated-gpu name: Intel
    Graphics (ADL GT2) driver: N/A device-ID: 8086:46a8
    surfaces: xcb,xlib,wayland
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
  Device-2: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1e class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 1.82 TiB used: 928.38 GiB (49.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: GOODRAM model: SSDPR-PX600-2K0-80
    lanes: 4 tech: SSD serial: <filter> fw-rev: ELFMC1.0 temp: 30.9 C
    scheme: GPT
  ID-1: / raw-size: 1.75 TiB size: 1.73 TiB (98.37%) used: 928.35 GiB (52.5%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 8772a129-9dcd-48a2-9220-a4fb1ba1ff09
    used: 27.2 MiB (5.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 4E16-7528
  ID-1: swap-1 type: partition size: 66.41 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 9364b7ee-b828-4189-a878-dd07808ed678
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-3:2 info: Trust Wireless Mouse type: mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 145f:02e5 class-ID: 0301
  Device-2: 3-8:3 info: Broadcom BCM58200 ControlVault 3 (FingerPrint sensor
    + Contacted SmartCard) type: smart card driver: N/A interfaces: 2 rev: 2.0
    chip-ID: 0a5c:5843 class-ID: 0b00 serial: <filter>
  Device-3: 3-10:4 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  System Temperatures: cpu: 36.0 C mobo: 36.0 C sodimm: Mem C
  Fan Speeds (rpm): cpu: 2177
  Packages: 1781 pm: pacman pkgs: 1663 libs: 402 tools: pamac,yay pm: flatpak
    pkgs: 118
    1: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    2: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    3: https://manjaro.kurdy.org/stable/$repo/$arch
    4: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirrors2.manjaro.org/stable/$repo/$arch
    7: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    9: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    10: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    11: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    12: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    13: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    14: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    15: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    16: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    17: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    18: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    19: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    20: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://manjaro.ynh.ovh/stable/$repo/$arch
    22: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    23: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    24: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    25: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    26: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    27: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    28: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    29: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    30: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    31: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    32: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    33: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    34: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    35: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    36: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    37: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    38: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    39: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    40: https://mirror.init7.net/manjaro/stable/$repo/$arch
    41: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    42: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    43: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    44: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    45: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    46: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    47: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    48: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    49: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    50: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    51: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    52: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 298
  1: cpu: 9.1% command: kwin_wayland pid: 985 mem: 226.6 MiB (0.3%)
  2: cpu: 8.3% command: plasmashell pid: 1209 mem: 378.1 MiB (0.5%)
  3: cpu: 6.6% command: baloo_file pid: 984 mem: 121.5 MiB (0.1%)
  4: cpu: 5.6% command: konsole pid: 2016 mem: 129.3 MiB (0.2%)
  5: cpu: 4.1% command: zsh pid: 2042 mem: 12.0 MiB (0.0%)
  Memory top: 5 of 298
  1: mem: 378.1 MiB (0.5%) command: plasmashell pid: 1209 cpu: 8.3%
  2: mem: 226.6 MiB (0.3%) command: kwin_wayland pid: 985 cpu: 9.1%
  3: mem: 143.6 MiB (0.2%) command: kate pid: 1965 cpu: 2.8%
  4: mem: 129.3 MiB (0.2%) command: konsole pid: 2016 cpu: 5.6%
  5: mem: 121.5 MiB (0.1%) command: baloo_file pid: 984 cpu: 6.6%
  Processes: 298 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
    image: 24.98 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13 Shell: Zsh v: 5.9
    running-in: konsole inxi: 3.3.36
Welcome to the Manjaro Community!
Have you checked the refresh rate, etc.? Is the new display a higher resolution? There’s also the possibility its greater power draw could be causing throttling to save power, assuming it’s happening on battery.
There’s an option on my laptop for a display “upgrade”, which I’m interested in as my display is certainly not the best. So I’d be interested to see what happens with yours, if settings can be adjusted to get it to work.
Also, to me, that looks like a 1st generation i5 so pretty old now, 3 years older than mine. Maybe it isn’t that well supported now with the newer kernels?
A bit more system information may go a long way to help people who may be able to assist:
Cheers!
Could it be that the 2nd screen isn’t as compatible as you believed? Either that, or perhaps it’s faulty.
In any case, some housekeeping:
Welcome to the Manjaro community.
As a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
Required Reading:
Update Announcements:
The Update Announcements contain update related information and a Known Issues and Solutions section that should generally be checked before posting a request for support.
System Information:
Output of the following command (formatted according to forum requirements) may be useful for those wishing to help:
Be prepared to provide more information and outputs from other commands when asked.
But the i5-1235u processor is not old, it was released 2 years ago, it’s part of the 12th generation Intel lineup from 2022.
It doesn’t matter whether I’m running on battery or from the outlet, on kernels newer than 5.15 (6 and above), the CPU frequency is limited to 400 MHz. On kernel 5.15 and below, the processor works as it should without issues. I’ve been using a laptop with a new display on kernel 5.15 for a month now, but older Linux kernels have issues with laptop hibernation, so I would like to return to version 6+.
Log
╭─    ~ ······································································ ✔  at 22:42:58  ─╮
╰─ inxi --admin --verbosity=8 --filter --no-host --width                                              ─╯
    status: charging
    microcode: 0x435
    desc: 1x12 MiB
    xtopology xtpr
    class-ID: e001
    scheme: GPT
    uuid: 4E16-7528
    pkgs: 118
Processes:
  CPU top: 5 of 298
I don’t think it’s incompatible, as I’ve been using this screen for over a month with kernel 5.15 and haven’t encountered any issues. The problems start when using kernels version 6 and above. Even Windows doesn’t have any issues with the processor during the installation process.
I just checked that and indeed, it’s a 12. I expected an extra digit on the number e.g. mine’s a 4300U and that’s 4th gen. :wink:
So, indeed an issue. I guess you have tried all of the current 6x series, including the latest linux613 (release candidate currently, as far as I’m aware)?
Well, first thing, some system information. This may help others find related information. Perhaps details of your replacement screen as well; one never knows what fresh eyes may discover.
I tried all stable versions of kernel 6, not the RC version. Latest 6.12
I added the result of the command to the top of the post. Thank you.
And about the screen model, I don’t know how I can check it.
I presumed you might still have the invoice and any accompanying documentation; either of these might have given some details.
inxi results are not helping much with that, either.
A quick Internet search has shown that the Dell Latitude 5430 is generally recommended as a solid base for Arch/Manjaro; but then again, you’ve made modifications outside the scope of those general reviews.
I noticed you’re running Wayland; it’s the obvious future of Linux; but have you tested under X11? Kernel 6.6 (LTS) and 6.12 should be sufficient to test.
Otherwise, nothing else comes to mind.
About X11 or Wayland doesn’t matter what I choose the result will be the same. About the matrix model, I bought this screen on eBay and all I have it’s a code LCD panel - P137G.
This laptop has several modifications including 400cd/m2 matrix screen
Well, according to the Internet, that seems like it should be the same as the original screen.
I found the following Service Manual (PDF) for the P137G listed on ManualsLib in case this is useful.
The best we can do for now is leave this open for other Members to comment; perhaps they may have a few thoughts.
I can recall a post about a machine stuck on lower frequencies but cannot locate it on the forum. This page might have some hints on what to try/test:
https://wiki.archlinux.org/title/CPU_frequency_scaling
maybe change the governor to performance.
i have a few threads regarding this in my posts history.
and also since quit some time the measurement commands are apparently not accurate anymore?
watch -n1 cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_cur_freq
i gave up on seeing as a result to this command all the cores show they’re at max cpu clock as it was before, i just set it to performance and leave it be.
Quoting from the OP for the benefit of those wishing to help:
The issue only exists with the new screen installed.
Command result. I think processor try to set more freq, but can’t. Change profile to performance doesn’t give any results
I can’t attach any images or screenshots. The result is 400000, and sometimes a little more for half a second.
your main problem is that the used frequency-governor is “intel-pstate”. this governor is designed for newer cpu’s and unfortunately overrides every other setting of frequency-control. you need to disable it by adding
intel_pstate=disable
to the existing parameters in
GRUB_CMDLINE_LINUX_DEFAULT="
run
sudo mkinitcpio -P && sudo update-grub
afterwards, reboot and report the given inxi-command. it should be acpi-cpu-governor
Is there a reason we think a 12th generation Alder Lake intel (circa ~2021) is ‘too old’ for intel_pstate?
Though I will mention
Does not seem like a valid option.
The options seem to be
  • disable
  • active
  • passive
  • force
  • no_hwp
  • hwp_only
  • support_acpi_ppc
  • per_cpu_perf_limits
https://www.kernel.org/doc/html/v6.12/admin-guide/pm/intel_pstate.html#kernel-command-line-options-for-intel-pstate
i did not wrote that the cpu is too old ! i wrote that this governor will deactivate any governor-setting by design ! @cscs read (!) before commenting !!!
This driver implements a scaling driver with an internal governor for Intel Core (Sandy Bridge and newer) processors. It is used automatically for these processors instead of the other drivers below. This driver takes priority over other drivers and is built-in as opposed to being a module. intel_pstate may run in “passive mode” via the intel_cpufreq driver for older CPUs. If you encounter a problem while using this driver, add intel_pstate=disable to your kernel line in order to revert to using the acpi_cpufreq driver
https://wiki.archlinux.org/title/Scaling_governor
I extrapolated from your suggestion to disable it along with the qualifying comment
that you meant that the cpu must be ‘too old’.
If that wasnt your intention then alright, but I dont think its an unfair reading of what was written.
Yup, I can read the wiki as well.
But my first suggestion would not be to disable intel pstate, as its generally desirable.
We should at least see how it functions when an acceptable value is used first, methinks.
