The pop up menu in left bottom corner is oversized
The pop up menu in left bottom corner is oversized.
I reduced the height of the pop up menu.
As you’re using Plasma, you can change the menu type.
Right-click the icon and choose Show Alternatives and you should see:
  • Application Dashboard
  • Application Launcher
  • Application Menu :eyes:
I find Application Menu has a generally smaller footprint.
