i am use the manjaro 21.0.4 kde. the nextcloud desktop client 3.2.0-1 can not start. any ideas? i have try so many ver of nextcloud, whatever appimage, the snap or flatpak, all of them can not start, i can not see the gui about it.
Can you start the nextcloud client on console and post the output here ?
I use the repo package and it works just fine on Plasma on stable branch.
Same for me
EDIT: I mean “Same for me, I use the repo package and it works just fine on Plasma on stable branch.”
no,Core Dump。
but i find the solution,use the old nextcloud appimage like2.6. open it .after that,every ver will work.but i do not know why?
follow my way.
Maybe you guys are using an old server version? They might be incompatible with the new client.
