The microphone on my HyperX Cloud Alpha is not being recognized
The microphone on my HyperX Cloud Alpha is not being recognized on my Manjaro Gnome laptop. The audio output works perfectly, but the microphone isn’t detected.
I’ve tried installing pavucontrol, but it only detects the laptop’s built-in microphone. I also installed alsamixer, but I don’t really know how to use it.
How can I get Manjaro to recognize my headset’s microphone?
Laptop:
Samsung NP370E4K-KWABR
Headset:
HyperX Cloud Alpha
Connector: 3.5mm TRRS
Removable microphone
Manjaro Info:
inxi -A:
  Device-1: Intel Broadwell-U Audio driver: snd_hda_intel
  Device-2: Intel Wildcat Point-LP High Definition Audio driver: snd_hda_intel
  API: ALSA v: k6.12.21-4-MANJARO status: kernel-api
  Server-1: PipeWire v: 1.4.1 status: active
pactl info:
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 875
Tile Size: 65472
User Name: xxxxxx
Host Name: xxxxx
Server Name: PulseAudio (on PipeWire 1.4.1)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1b.0.analog-stereo
Default Source: alsa_input.pci-0000_00_1b.0.analog-stereo
Cookie: ac37:06c0
arecord -l:
**** List of CAPTURE Hardware Devices ****
card 1: PCH [HDA Intel PCH], device 0: ALC282 Analog [ALC282 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
Are you sure it supports TRRS and not only TRS? I can barely find any information about that laptop. Does it support a combo of headphone and microphone?
Note the difference:
yes, there is!
just looking at the image, I forgot to turn off the mute button
