After the update, the screen on my pinephone stopped locking when I pressed the power button. Without this, it becomes impossible to use the phone normally. How to fix it?
I rolled back “phosh” package to version 0.8.1. Now everything is all right.
As mentioned in the [ARM Stable Update] 2021-03-09 update thread, I also have this issue. Rolling back is not an option for me. I leave the journalctl log hereso as to motivate further investigation of this problem
Mar 10 20:05:59 manjaro-arm systemd-logind[3681]: Power key pressed.
Mar 10 20:05:59 manjaro-arm phoc[3750]: [backend/drm/drm.c:971] Skipping pageflip on output 'DSI-1'
Mar 10 20:05:59 manjaro-arm gnome-session[3834]: gnome-session-binary[3834]: WARNING: Could not get session path for session. Check that logind is properly installed and pam_systemd i>
Mar 10 20:05:59 manjaro-arm gnome-session-binary[3834]: WARNING: Could not get session path for session. Check that logind is properly installed and pam_systemd is getting used at log>
Mar 10 20:06:00 manjaro-arm gsd-color[4007]: unable to get EDID for xrandr-DSI-1: unable to get EDID for output
Mar 10 20:06:00 manjaro-arm phoc[3750]: event2 - Goodix Capacitive TouchScreen: client bug: event processing lagging behind by 13ms, your system is too slow
Mar 10 20:06:05 manjaro-arm gnome-calls[4144]: gtk_application_uninhibit: assertion 'cookie > 0' failed
Mar 10 20:06:05 manjaro-arm gsd-usb-protect[4020]: Error calling USBGuard DBus to change the protection after a screensaver event: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknow>
Mar 10 20:06:06 manjaro-arm systemd-logind[3681]: Power key pressed.
Mar 10 20:06:06 manjaro-arm gsd-color[4007]: unable to get EDID for xrandr-DSI-1: unable to get EDID for output
Mar 10 20:06:08 manjaro-arm systemd-logind[3681]: Power key pressed.
Mar 10 20:06:08 manjaro-arm phoc[3750]: [backend/drm/drm.c:971] Skipping pageflip on output 'DSI-1'
Mar 10 20:06:08 manjaro-arm gsd-color[4007]: unable to get EDID for xrandr-DSI-1: unable to get EDID for output
I would also like to remind anyone coming here that you can lock the screen from the top right power menu. It’s the first option above shutdown/restart/etc. That way you can just use this until the power button is fixed.
Yes, but it’s very inconvenient. So far, I’m using the old version of phosh.
Would just like to say that the update - 11/04/2021 - has ameliorated this issue
Yes, the issue was fixed after the update. Thank you.
