Hello dear friends
Peace be upon you
Unfortunately my English is not good
My system is X541UJ DM651
I connected the keyboard and mouse from the usb port
Unfortunately, the mouse screen and laptop keyboard no longer work
I always have to take my keyboard and mouse with me everywhere
Thank you for your help
How to reactivate the laptop keyboard and mouse
tell me
Hello! You are going to explain a lot better if you want people to understand and be able to help you
thanks for your attention
If you disconnect the USB peripherals (keyboard, mouse), does it start working again?
No
Inactive
Install evtest, and then start it, what does it print? Can you see the built-in keyboard?
I installed
But unfortunately it does not open
evtest
What do you mean? What happens if you open a terminal, enter “evtest”, then press enter?
No device specified, trying to scan all of /dev/input/event*
Not running as root, no devices may be available.
Available devices:
Select the device event number [0-0]:
Run sudo usermod -a -G input $(whoami) and try again.
USAGE:
Capture mode:
evtest [–grab] /dev/input/eventX
–grab grab the device for exclusive access
Query mode: (check exit code)
evtest --query /dev/input/eventX
is one of: EV_KEY, EV_SW, EV_LED, EV_SND
can either be a numerical value, or the textual name of the
key/switch/LED/sound being queried (e.g. SW_DOCK).
How did you run it? If you simply run evtest, you should see something like this:
Available devices:
Select the device event number [...]:
How can I
Divas scan the system
I don’t understand what you mean.
See a list of system-owned devices
Sorry, my English is bad
sudo pacman -Syu procinfo
sudo pacman -Syu lsscsi
My attempt was unsuccessful
We’re only concerned about input devices, please run evtest and send the output. Or just send a screenshot if you encounter an error.
[kian@kian-x541uj Desktop]$ evtest
Available devices:
I see, then please run it as root: sudo evtest
Available devices:
/dev/input/event0: Lid Switch
/dev/input/event1: Sleep Button
/dev/input/event2: Power Button
/dev/input/event3: Power Button
/dev/input/event4: AT Translated Set 2 keyboard
/dev/input/event5: SiliconWin mouse
/dev/input/event6: SEM USB Keyboard
/dev/input/event7: SEM USB Keyboard Consumer Control
/dev/input/event8: SEM USB Keyboard System Control
/dev/input/event9: Asus Wireless Radio Control
/dev/input/event10: PC Speaker
/dev/input/event11: ELAN1200:00 04F3:3045 Mouse
/dev/input/event12: ELAN1200:00 04F3:3045 Touchpad
/dev/input/event13: Asus WMI hotkeys
/dev/input/event14: Video Bus
/dev/input/event15: Video Bus
/dev/input/event16: HDA Intel PCH Headphone
/dev/input/event17: HDA Intel PCH HDMI/DP,pcm=3
/dev/input/event18: HDA Intel PCH HDMI/DP,pcm=7
/dev/input/event19: HDA Intel PCH HDMI/DP,pcm=8
/dev/input/event20: HDA Intel PCH HDMI/DP,pcm=9
/dev/input/event21: HDA Intel PCH HDMI/DP,pcm=10
/dev/input/event22: USB2.0 VGA UVC WebCam: USB2.0 V
Select the device event number [0-22]:
