The KDE desktop does not load properly
Hi
I am on the LTS version and instead of my normal desktop with icons I got an empty desktop.
Bottom line is that after a minute or so the icons are showing up for a brief moment it switches to a black screen and back to the image.
The F12 button also not working
Edit: I somehow managed to start the console and my web browser, but the issue stands
TL4 edit; removed unnecessary image
This is possibly a damaged configuration file.
Using CtrlAltF4 you can switch to a TTY
  • enter your username and press
  • enter your password and press
Clone the plasma reset script
git clone https://gitlab.manjaro.org/applications/manjaro-plasma-reset.git
After cloning - run the script
bash manjaro-plasma-reset/manjaro-plasma-reset.sh
Thanks, kind of worked, I need to restore my configs manually
