After I configure my settings and go to summary and click install the system freezes after a full 20 minutes it resets I disable fast boot and secure boot
The current installer’s slideshow may be causing this.
Ok I will try it
But can you the new Manjaro make it supported in my system
My system is
CPU Intel core I3. 7gen 7000u
Graphics card Nvidia GeForce Mx 130
Ram 4 Gb
Brand Acer
From 2018
When you run a full system update after install - your system will be current.
How to do that
Read this first
Then run the mirrorlist tool and update the system.
sudo pacman-mirrors --country all && sudo pacman -Syyu
Some links for system maintenance
Thanks for your help
If doesn’t work I will downgrade to an older version
It did not work There’s any other way to install an update
I’m using a laptop
Brand:acer
CPU:intel Core i3 7gen 7000U cpu
Gpu:Nvidia GeForce mx130
Ram 4gb
can you , from USB live iso or installed
open a terminal and return
inxi -Fza
