The emulator process for AVD Pixel_4_API_30 has terminated
hi all i get that error when i work on android studio all time i try to solve it but not know what it exactly the problem i just get that error after update manjaro
Not enough disk space? https://stackoverflow.com/questions/67346232/android-emulator-issues-in-new-versions-the-emulator-process-has-terminated
i run that
* Locate your Sdk/emulator directory
* Run ./emulator -list-avds
* Note the AVD name form output eg. 'Pixel_2_API_30'
* Run ./emulator @Pixel_2_API_30
and get that
 ./emulator @Pixel_4_API_30
INFO    | Android emulator version 32.1.12.0 (build_id 9751036) (CL:N/A)
INFO    | Found systemPath /home/kssm/Android/Sdk/system-images/android-30/google_apis_playstore/x86/
INFO    | Storing crashdata in: /tmp/android-kssm/emu-crash.db, detection is enabled
INFO    | Duplicate loglines will be removed, if you wish to see each indiviudal line launch with the -log-nofilter flag.
WARNING | Please update the emulator to one that supports the feature(s): Vulkan
WARNING | Failed to process .ini file /home/kssm/.android/avd/Pixel_4_API_30.avd/quickbootChoice.ini for reading.
Fontconfig warning: "/usr/share/fontconfig/conf.avail/05-reset-dirs-sample.conf", line 6: unknown element "reset-dirs"
WARNING | cannot add library /home/kssm/Android/Sdk/emulator/qemu/linux-x86_64/lib64/vulkan/libvulkan.so: failed
INFO    | added library /home/kssm/Android/Sdk/emulator/lib64/vulkan/libvulkan.so
MESA-INTEL: warning: Haswell Vulkan support is incomplete
pulseaudio: pa_context_connect() failed
pulseaudio: Reason: Connection refused
pulseaudio: Failed to initialize PA contextCould not init `pa' audio driver
WARNING | *** No gRPC protection active, consider launching with the -grpc-use-jwt flag.***
INFO    | Started GRPC server at 127.0.0.1:8554, security: Local, auth: none
INFO    | Advertising in: /run/user/1000/avd/running/pid_2275.ini
INFO    | Setting display: 0 configuration to: 1080x2280, dpi: 440x440
ERROR   | Unable to connect to adb daemon on port: 5037
INFO    | Boot completed in 31547 ms
INFO    | Increasing screen off timeout, logcat buffer size to 2M.
INFO    | Revoking microphone permissions for Google App.
zsh: segmentation fault (core dumped)  ./emulator @Pixel_4_API_30
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
