I think it’s an easily fixed problem, but my poor English doesn’t let me find the answer. I want to remove the blue shadow line when I hover hidden bottom panel. I’m sorry if there are also such topic.
Disable Touch Screen from Workspace Behavior, and Touch Points effect from Desktop Effects.
It’s already disabled
Restart session.
Didn’t help
Clean ~/.cache, reboot.
Just delete the folder?
The content of it.
Did you also disabled Screen Edge effect?
The last one helped. Thank you so much!
