Hello everyone! I recently bought an HP computer (model 15s-eq2008nl). After installing Manjaro, I noticed that the audio is not working. In the settings, the input device appears to be nonexistent, and the only detected output device is “dummy audio”. Do you have any advice? Thank you very much!
Please post
inxi -Fxxxz
paste the output of:
$ aplay -l
if ALSA cannot detect it, then nothing above it will. Anyway, since this laptop is Netherlands specific (from the last two letter code in the product name), specifications may vary. Please also paste the output of:
$ inxi -A
Kernel: 6.1.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: HP product: HP Laptop 15s-eq2xxx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 887A v: 59.21 serial: <filter> UEFI: AMI v: F.27
date: 10/20/2022
ID-1: BAT0 charge: 27.7 Wh (68.1%) condition: 40.7/40.7 Wh (100.0%)
volts: 11.8 min: 11.3 model: HP Primary type: Li-ion serial: <filter>
status: discharging
Info: 6-core model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64
type: MT MCP smt: enabled arch: Zen 2 rev: 1 cache: L1: 384 KiB L2: 3 MiB
L3: 8 MiB
Speed (MHz): avg: 1458 high: 2100 min/max: 1400/4056 boost: enabled
volts: 1.2 V ext-clock: 100 MHz cores: 1: 2100 2: 1400 3: 1400 4: 1400
5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
bogomips: 50323
Device-1: AMD Lucienne vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5 pcie: speed: 8 GT/s lanes: 16 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c class-ID: 0300
temp: 39.0 C
Device-2: Chicony HP TrueVision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-3:2 chip-ID: 04f2:b6f1
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x153b res: 1920x1080 dpi: 142
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.38-1-MANJARO) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.38-1-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.74 status: off
Server-3: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A pcie: speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 bus-ID: 1-4:3 chip-ID: 0bda:b00e class-ID: e001
serial: <filter>
Local Storage: total: 476.94 GiB used: 16.03 GiB (3.4%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNU512GZH size: 476.94 GiB
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: HPS1
temp: 30.9 C scheme: GPT
ID-1: / size: 347.37 GiB used: 15.96 GiB (4.6%) fs: ext4 dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 256 MiB used: 68.8 MiB (26.9%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 44.2 C mobo: N/A gpu: amdgpu temp: 40.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 309 Uptime: 17m wakeups: 1507 Memory: total: 8 GiB note: est.
available: 7.09 GiB used: 2.93 GiB (41.3%) Init: systemd v: 253
default: graphical Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1201 Shell: Bash (su) v: 5.1.16 running-in: gnome-terminal
inxi: 3.3.28
The “aplay -l” command returns an error.
The “inxi -A” command returns this:
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_rn_pci_acp3x
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel
Server-1: PulseAudio v: 16.1 status: active (root, process)
That should help:
pamac install sof-firmware
Manjaro ISOs includes sof-firmware
for Intel laptops with internal digital microphone array
But AMD Audio Coprocessor uses ACP drivers for internal digital microphone array
(currently snd_rn_pci_acp3x
Dummy Output is created by PulseAudio module-always-sink if there are no audio sinks available for audio playback
If ALSA was detecting audio devices correctly, aplay -l
response should look like this:
linux-hardware.org - HP 15s-eq2xxx:aplay
**** List of PLAYBACK Hardware Devices **** card 0: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: Generic_1 [HD-Audio Generic], device 0: ALC236 Analog [ALC236 Analog] Subdevices: 1/1 Subdevice #0: subdevice #0
Most other hardware scans that share ALSA information show the same devices detected
Error response from aplay -l
is probably advising no playback devices detected
Please post more information about ALSA
sudo alsa-info.sh --upload
This is the output of sudo alsa-info.sh --upload
cat: '/sys/module/snd_acp3x_rn/parameters/*': No such file or directory
/usr/bin/alsa-info.sh: line 659: tree: command not found
alsa-lib conf.c:2008:(_snd_config_load_with_include) _toplevel_:3:0:Unexpected end of file
alsa-lib conf.c:4097:(config_file_open) /etc/asound.conf may be old or corrupted: consider to remove or fix it
alsa-lib conf.c:4019:(snd_config_hooks_call) function snd_config_hook_load returned error: Invalid argument
alsa-lib conf.c:4626:(snd_config_update_r) hooks failed, removing configuration
alsactl: get_controls:566: snd_ctl_open error: Invalid argument
cat: /tmp/alsa-info.nzhtpeQbFR/alsactl.tmp: No such file or directory
Uploading information to www.alsa-project.org ... Done!
Your ALSA information is located at http://alsa-project.org/db/?f=ee7c6aa91e772af7e92d05f4e42c15b19bd00c09
Please inform the person helping you.
Please sudo pacman -S tree
and rerun the command.
I suggest:
Delete misconfigured and unnecessary ALSA configuration file /etc/asound.conf
sudo rm /etc/asound.conf
install package
tree
sudo pacman -S tree
reboot system
If audio devices are still not detected in PulseAudio, run alsa-info diagnostic again
Audio devices are still not detected…
Your ALSA information is located at http://alsa-project.org/db/?f=7f9e6c707e1f165356bf33af296c865bdce72aae
you’ve installed the firmware as @ManLuxer adviced ?
Yes, I installed them, but it didn’t work.
it doesn’t solve your problem. THAT’s a difference. but it made sure that your firmware is up-to-date and that’s one of the steps that you need.
next step, try to use pipewire (the more actual sound-server and remove alsa)
run
sudo pacman -Ru --nodeps pulseaudio pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-rtp pulseaudio-zeroconf pulseaudio-bluetooth pulseaudio-pa pulseaudio-alsa pulseaudio-ctl manjaro-pulse && sudo pacman -S manjaro-pipewire
reboot and report
Thank you all for your help! With the latest update, the problem has been resolved!
https://gitlab.freedesktop.org/pipewire/pipewire/-/wikis/FAQ#does-pipewire-replace-alsa
Does PipeWire Replace ALSA?
No, ALSA is an essential part of the Linux audio stack, it provides the interface to the kernel audio drivers.
