I’m using Manjaro Gnome for a while now as daily driver. I just want to say that it is a perfect OS and thanks to developers for maintaining one of the best operating systems ever. There was one drawback with double letters on search, but, switching from dash to dock to dash to panel solve the problem. Thank You.
I’ve done a bit of DE hopping, but I’ve found that Manjaro works too well for me to even consider switching distros at this point. I appreciate all of the hard work that goes into keeping things running so smoothly. Thank you and Happy Holidays all!
I’m kind of a racecar johnny, and even for me Manjaro is the best
Got the same problem.
I like your message !
I switcthed from a macbook pro to the http://frame.work laptop with Manjaro 9 months ago. And I can say I’ll never switch back to macOS ! Thank you Manjaro ![]()
