Hi,
I have a problem with TeXStudio on one of the machines I use with Manjaro.
The problem is as follows. If I try to compile using xelatex (from TeXStudio), the following error is generated:
xdvipdfmx:fatal: Unrecognized paper format: # Simply write the paper name. See man 1 paper and "paper --no-size --all" for possible values
Process exited with error(s)
and the PDF is not generated
If I compile from the command line, I can generate the PDF without problems.
I have already tried deleting the TeXStudio configuration in my home directory. Any suggestions?
