[Testing Update] 2025-02-07 - KDE Gear, InptutPlumber, OGUI, Nginx, Curl
This also marks the first update of the year of the Snake.
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: Get 4 months extra
Recent News
Previous News
Notable Package Updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
For help with AUR packages, please create a new topic in AUR and a helpful volunteer may be able to assist you.
Our current supported kernels
  • linux54 5.4.290
  • linux510 5.10.234
  • linux515 5.15.178
  • linux61 6.1.127
  • linux66 6.6.75
  • linux612 6.12.12
  • linux613 6.13.1
  • linux614 6.14.0-rc1
  • linux66-rt 6.6.74_rt48
  • linux612-rt 6.12.8_rt8
  • linux613-rt 6.13_rt5
Package Changes (Fri Feb 7 08:16:17 CET 2025)
  • testing core x86_64: 5 new and 6 removed package(s)
  • testing extra x86_64: 516 new and 517 removed package(s)
  • testing multilib x86_64: 5 new and 5 removed package(s)
Overlay Changes
  • testing extra x86_64: 8 new and 12 removed package(s)
A list of all changes can be found here
0 voters
Known issues and solutions
:arrow_right: 2025-02-07
2025-01-15
Critical rsync security release 3.4.0
2025-01-16 - Robin Candau
We’d like to raise awareness about the rsync security release version 3.4.0-1 as described in our advisory ASA-202501-1.
An attacker only requires anonymous read access to a vulnerable rsync server, such as a public mirror, to execute arbitrary code on the machine the server is running on. Additionally, attackers can take control of an affected server and read/write arbitrary files of any connected client. Sensitive data can be extracted, such as OpenPGP and SSH keys, and malicious code can be executed by overwriting files such as ~/.bashrc or ~/.popt.
We highly advise anyone who runs an rsync daemon or client prior to version 3.4.0-1 to upgrade and reboot their systems immediately. As Arch Linux mirrors are mostly synchronized using rsync, we highly advise any mirror administrator to act immediately, even though the hosted package files themselves are cryptographically signed.
All infrastructure servers and mirrors maintained by Arch Linux have already been updated.
Arch Linux - News: Critical rsync security release 3.4.0
2024-12-11
Kernel 6.11 and 4.19 has been marked End Of Life (EOL) on kernel.org
2024-11-27
Partial Cinnamon 6.4 updates
Linux Mint is currently preparing Cinnamon 6.4. The Arch Maintainers went ahead and released some Cinnamon packages which got already tagged 6.4. However, it seems this will break your installation of your Cinnamon desktop. We will monitor the situation and might downgrade to 6.2 packages if needed, before we do a stable branch update. Your feedback regarding Cinnamon overall is highly appreciated.
Known issues so far:
What you can do:
  • Ignore all cinnamon updates when updating.
  • You can try the newly added cinnamon-git package to see if it improves the situation.
  • Update: The issues are resolved with cinnamon >= 6.4.0-1. If you manually installed cinnamon-git, you may now install cinnamon again.
2024-11-13
v86d has been dropped from Manjaro repositories and is no longer required for mhwd
Re: Unstable Update MHWD disussion
If pamac GUI options Enable AUR support and Check for updates are enabled, users should check the package list before agreeing to update and un-check AUR packages
2024-11-01
KVM default behavior change on module loading in kernel 6.12
In kernel 6.12, KVM initializes virtualization on module loading by default. This prevents VirtualBox VMs from starting. In order to avoid this, either add kvm.enable_virt_at_load=0 parameter into kernel command line or unload the corresponding kvm_XXX module. Initial support for 6.12 kernel series was added with Virtualbox 7.1.4.
More info about that in the Linux mailing list
Previous testing threads:
The keyboard layout was set to US at startup after the upgrade, even though I had always the layout German. In the System Settings, there was only the US keyboard layout available, hence I had to reload the German keybord layout again and make it the default. This can become critical when at startup a password is required with special characters, which are at different places in the US keyboard layout. I found this only out by making the password visible.
I had a similar issue on KDE Plasma a few days ago and I think it was because of a piece of software that somehow invited itself on my system (fcitx5). I removed it and it was fine after that. AFAIK it’s not something that is essential anyway, my system is working just fine without it.
Just FYI for Kodi users: some issues with Curl have been reported upstream.
