Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
As you might have seen some of our team were able to attend FOSDEM 2023 and the conference proved to be incredibly productive for us. See our blog post for more.
You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.12.so.
Rebuild them all at once:*
checkrebuild
Info about AUR packages
AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcements topics are off-topic and will be flagged, moved or removed without warning.
For help with AUR packages, please create a new topic in AUR and a helpful volunteer may be able to assist you.
Kernel 6.11 and 4.19 has been marked End Of Life (EOL) on kernel.org
2024-11-27
Partial Cinnamon 6.4 updates
Linux Mint is currently preparing Cinnamon 6.4. The Arch Maintainers went ahead and released some Cinnamon packages which got already tagged 6.4. However, it seems this will break your installation of your Cinnamon desktop. We will monitor the situation and might downgrade to 6.2 packages if needed, before we do a stable branch update. Your feedback regarding Cinnamon overall is highly appreciated.
If pamac GUI options Enable AUR support and Check for updates are enabled, users should check the package list before agreeing to update and un-check AUR packages
2024-11-01
KVM default behavior change on module loading in kernel 6.12
In kernel 6.12, KVM initializes virtualization on module loading by default. This prevents VirtualBox VMs from starting. In order to avoid this, either add kvm.enable_virt_at_load=0 parameter into kernel command line or unload the corresponding kvm_XXX module. Initial support for 6.12 kernel series was added with Virtualbox 7.1.4.
@cges30901, I think qemu-common has been upgraded too early by Archlinux (there is the same issue). I personally would downgrade it for the moment to 9.1.2-1.
qemu-system-cris still depends on qemu-common=9.1.2-1.
P.S.: Don’t use -Rdd here, it could break your system. Use -Rsn instead
