[Testing Update] 2024-12-04 - Systemd, Mesa, Qt 6.8.1, Wireplumber
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: Get 4 months extra
Recent News
Previous News
Notable Package Updates
  • Kernels
    • Rebuilds of RT kernels
    • 6.13-rc1 with Nvidia drivers
  • Systemd 256.9
  • Mesa 24.2.8
  • More updates to Deepin
  • Qt 6.8.1
  • Wireplumber 0.5.7
Additional Info
Nvidia driver downgrade
Nvidia drivers got downgraded to 550.100, therefore update with sudo pacman -Syuu. If you want to stay on the 555 driver series you may either switch to unstable or install nvidia-dkms via: sudo pacman -U https://mirror.easyname.at/manjaro/pool/overlay/nvidia-dkms-555.58.02-1-x86_64.pkg.tar.zst. More info about Nvidia drivers here:
555 release feedback & discussion - Linux - NVIDIA Developer Forums
550.78 release feedback & discussion thread - Linux - NVIDIA Developer Forums
Python 3.12 info
:information_source: You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.11.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.11/ :
pacman -Qoq /usr/lib/python3.11/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.11)
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
Info about AUR packages
Our current supported kernels
  • linux419 4.19.324
  • linux54 5.4.286
  • linux510 5.10.230
  • linux515 5.15.173
  • linux61 6.1.119
  • linux66 6.6.63
  • linux611 6.11.10
  • linux612 6.12.1
  • linux613 6.13-rc1
  • linux61-rt 6.1.119_rt45
  • linux66-rt 6.6.63_rt46
Package Changes (Wed Dec 4 04:24:09 CET 2024)
  • testing core x86_64: 15 new and 15 removed package(s)
  • testing extra x86_64: 514 new and 519 removed package(s)
  • testing multilib x86_64: 6 new and 7 removed package(s)
Overlay Changes
  • testing core x86_64: 12 new and 12 removed package(s)
  • testing multilib x86_64: 11 new and 2 removed package(s)
  • testing extra x86_64: 92 new and 84 removed package(s)
A list of all package changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2024-12-04
2024-11-27
Partial Cinnamon 6.4 updates
Linux Mint is currently preparing Cinnamon 6.4. The Arch Maintainers went ahead and released some Cinnamon packages which got already tagged 6.4. However, it seems this will break your installation of your Cinnamon desktop. We will monitor the situation and might downgrade to 6.2 packages if needed, before we do a stable branch update. Your feedback regarding Cinnamon overall is highly appreciated.
Known issues so far:
What you can do:
  • Ignore all cinnamon updates when updating.
  • You can try the newly added cinnamon-git package to see if it improves the situation.
  • Update: The issues are resolved with cinnamon >= 6.4.0-1. If you manually installed cinnamon-git, you may now install cinnamon again.
2024-11-13
v86d has been dropped from Manjaro repositories and is no longer required for mhwd
Re: Unstable Update MHWD disussion
If pamac GUI options Enable AUR support and Check for updates are enabled, users should check the package list before agreeing to update and un-check AUR packages
2024-11-01
KVM default behavior change on module loading in kernel 6.12
In kernel 6.12, KVM initializes virtualization on module loading by default. This prevents VirtualBox VMs from starting. In order to avoid this, either add kvm.enable_virt_at_load=0 parameter into kernel command line or unload the corresponding kvm_XXX module. Initial support for 6.12 kernel series was added with Virtualbox 7.1.4.
More info about that in the Linux mailing list
2024-10-20
Kernel 6.10 has been marked [EOL] on kernel.org
sddm login problems with multiple monitors
  • bug report
  • login only works on secondary monitor
  • switching sddm theme to maldives works around the issue
Previous testing threads:
