[Testing Update] 2024-07-05 - Nvidia, KDE Gear, Calamares, InputPlumber, OpenGamepadUI
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: Get 3 months extra
Recent News
  • Philip will be at Computex and show off the OrangePi Neo
  • Manjaro Team member @romangg has a new library project with a guest post on Phoronix.
Previous News
Notable Package Updates
Additional Info
Python 3.12 info
:information_source: You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.11.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.11/ :
pacman -Qoq /usr/lib/python3.11/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.11)
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
Info about AUR packages
Our current supported kernels
  • linux419 4.19.316
  • linux54 5.4.278
  • linux510 5.10.220
  • linux515 5.15.161
  • linux61 6.1.96
  • linux66 6.6.36
  • linux68 6.8.12 [EOL]
  • linux69 6.9.7
  • linux610 6.10-rc6
  • linux61-rt 6.1.83_rt28
  • linux66-rt 6.6.30_rt30
  • linux67-rt 6.7_rt6
Package changes (Fri Jul 5 11:33:52 CEST 2024)
  • testing core x86_64: 12 new and 12 removed package(s)
  • testing multilib x86_64: 4 new and 4 removed package(s)
  • testing extra x86_64: 959 new and 965 removed package(s)
Package Changes (Overlay)
  • testing core x86_64: 2 new and 3 removed package(s)
  • testing extra x86_64: 67 new and 66 removed package(s)
  • testing multilib x86_64: 2 new and 2 removed package(s)
A list of all package changes can be found here
0 voters
Known issues and solutions
:arrow_right: 2024-07-05
2024-07-01
The sshd service needs to be restarted after upgrading to openssh-9.8p1
2024-07-01 - Robin Candau
After upgrading to openssh-9.8p1, the existing SSH daemon will be unable to accept new connections (see Can't login after openssh 9.8p1-1 upgrade, MUST restart sshd (#5) · Issues · Arch Linux / Packaging / Packages / openssh · GitLab).
When upgrading remote hosts, please make sure to restart the sshd service using systemctl try-restart sshd right after upgrading.
We are evaluating the possibility to automatically apply a restart of the sshd service on upgrade in a future release of the openssh-9.8p1 package.
Arch Linux - News: The sshd service needs to be restarted after upgrading to openssh-9.8p1
2024-06-03
:warning: Linux 6.8 is EOL
Linux 6.8 is EOL and will - at some point - be removed from the repo.
:warning: Linux 6.7 is EOL
Linux 6.7 is EOL and will - at some point - be removed from the repo.
Suggestion is to install latest LTS to be sure
sudo mhwd-kernel -i linux66
2024-05-18
Shutdown Issues on some AMD systems (fixed in latest kernels)
  • Problem: Kernel updates 6.1.91-1 and 6.6.31-1 break shutdown and suspend/resume on the Framework 16 (Ryzen 7 7840HS, no GPU).
  • Solution: kernels were patched - please update to 6.1.92 / 6.6.32 / 6.8.11 / 6.9.2
  • Issue tracking: framework forums
2024-05-14
No plasma interface with kernel 6.9 + Nvidia gpu + Wayland
If you encouter a black screen with no inteface after login in, it’s probably a problem with simpledrm loading.
To solve it add nvidia_drm.fbdev=1 to /etc/default/grub
in the line begining with GRUB_CMDLINE_LINUX=" .
Verify that you also have nvidia_drm.modeset=1 in the same line.
Then exec sudo update-grub
Also, verify that you have nvidia_drm in /etc/mkinitcpio.conf in the MODULES= or HOOKS= line.
Exemple :
MODULES=(nvidia nvidia_modeset nvidia_uvm nvidia_drm)
If it was not present, then run sudo mkinitcpio -P after adding it.
2024-05-08
Qemu: MacOS is not bootable with 9.0
Due to a bug MacOS is not bootable with 9.0: [9.0.0] qemu breaks mac os vm (#2334) · Issues · QEMU / QEMU · GitLab
Workaround: remove virtio-serial and org.qemu.guest_agent.0 from libvirt XML until bug will be fixed.
2024-05-02
The default KDE Plasma session has been changed to X11
As of Plasma 6, KDE decided to make Wayland the default. However, since issues were discovered, we have reverted the default to X11. Users are free to choose whichever works best for them.
Previous testing threads:
Everything seems to be working as expected.
NVIDIA 555.58.02 fixes the issues from the previous version.
Plasma 6.0 still better than plasma 6.1.2
X11 VSYNC Test
Display (): 1920x1080 @ 144Hz *
NVIDIA 555.58.02
Kernel: 6.9.7
In GRUB: nvidia_drm.modeset=0 nvidia_drm.fbdev=0 nvidia.NVreg_EnableGpuFirmware=0
When will the update to plasma 6.1 come out, for the stable version?
Probably when most of the bugs have been fixed. Phil has already said it’s too buggy atm
in Cinnamon edition.
It’s been stable for a long time. Thank you for Team Manjaro.
  • The bug in Cinnamon nemo action is unavoidable.
Reason why it will not come out anytime soon: [Testing Update] 2024-07-01 - Kernels, Gstreamer, Thunderbird, Pipewire, Mesa, Firefox, Gnome, Phosh, Nvidia, Qt6 - #14 by philm
I have two pieces of news, one good and one bad… ok… first the bad one:
In X11 the GPU consumes more than 20% in IDLE, it doesn’t happen always, in the previous version it happened always with NVreg_EnableGpuFirmware=0. This doesn’t happen in Wayland.
The good… in both kenel 6.6 and 6.9 I have been able to run Walyand with these parameters:
cat /etc/default/grub | grep GRUB_CMDLINE_LINUX_DEFAULT=
GRUB_CMDLINE_LINUX_DEFAULT="nvidia_drm.modeset=1 nvidia_drm.fbdev=1 nvidia.NVreg_EnableGpuFirmware=0"
cat /etc/mkinitcpio.conf | grep -e MODULES= -e HOOKS=
MODULES=()
HOOKS=(base udev autodetect modconf block keyboard keymap consolefont filesystems fsck)
Update: I don’t know why, but after i downgraded/updated libvirt and libvirt-phyton serveral times, the problem is gone…strange
Since the update I have a problem with virt-manager/KVM/QEMU when running a VM with MXLinux as guest.
A short time after logging into the VM and starting Xfce (less than 1 min), the Virt-Manager viewer loses the connection to the VM and closes. The VM itself continues to run in the background. When I reconnect virt-manager to the hypervisor and open the viewer again, the same thing happens shortly afterwards.
If i do not login and change to another tty everything is fine.
Logs of the guest are fine.
I tried to downgrade libvirt and libvirt-python to 1:10.4.0-1 and 6.6 LTS Kernel but same result.
inxi
  Kernel: 6.9.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=9dc4ed12-cf8e-41b5-a31c-9de5f50e8dc6 rw
    resume=UUID=9dc4ed12-cf8e-41b5-a31c-9de5f50e8dc6 resume_offset=30074880
    apparmor=1 security=apparmor udev.log_priority=3 sysrq_always_enabled=1
    NVreg_PreserveVideoMemoryAllocations=1 NVreg_TemporaryFilePath=/var/tmp
    modprobe.blacklist=nouveau systemd.setenv=GPUMOD=nvidia nowatchdog
    intel_iommu=on iommu=pt
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
  Type: Desktop Mobo: MSI model: P55-GD55 (MS-7589) v: 1.0
    serial: <superuser required> uuid: <superuser required>
    BIOS: American Megatrends v: 1.9 date: 03/02/2011
  System RAM: total: 8 GiB available: 7.75 GiB used: 2.66 GiB (34.3%)
  Array-1: capacity: 8 GiB slots: 4 modules: 4 EC: None
    max-module-size: 2 GiB note: est.
  Device-1: DIMM1 type: SDRAM detail: synchronous size: 2 GiB
    speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: N/A part-no: N/A serial: N/A
  Device-2: DIMM2 type: SDRAM detail: synchronous size: 2 GiB
  Device-3: DIMM3 type: SDRAM detail: synchronous size: 2 GiB
  Device-4: DIMM4 type: SDRAM detail: synchronous size: 2 GiB
  Info: model: Intel Core i7 860 bits: 64 type: MT MCP arch: Nehalem
    gen: core 1 level: v2 built: 2008-10 process: Intel 45nm family: 6
    model-id: 0x1E (30) stepping: 5 microcode: 0xA
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1400 high: 2801 min/max: 1200/2801 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1200 2: 1200
    3: 1200 4: 1200 5: 1200 6: 1200 7: 1200 8: 2801 bogomips: 44924
  Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
    cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority flush_l1d
    fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr
    nonstop_tsc nopl nx pae pat pbe pdcm pebs pge pni popcnt pse pse36 pti
    rdtscp rep_good sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
    vulnerable
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
    SMT vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Micro-Star MSI
    driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2024-06; EOL~2026-12-xx) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-2019 pcie: gen: 2 speed: 5 GT/s lanes: 16
    ports: active: none off: DVI-I-1 empty: DP-1,DVI-D-1,HDMI-A-1
    bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 95 s-size: 513x292mm (20.20x11.50")
    s-diag: 590mm (23.24")
  Monitor-1: DVI-I-1 note: disabled model: Samsung SyncMaster
    serial: <filter> built: 2010 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
    size: 510x287mm (20.08x11.3") diag: 585mm (23") ratio: 16:9 modes:
    max: 1920x1080 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 555.58.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 970/PCIe/SSE2
    memory: 3.91 GiB
  API: Vulkan v: 1.3.279 layers: 6 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 970 driver: nvidia v: 555.58.02 device-ID: 10de:13c2
    surfaces: xcb,xlib
  Device-1: Intel 5 Series/3400 Series High Definition Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:3b56 class-ID: 0403
  Device-2: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
  API: ALSA v: k6.9.7-1-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d800 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Local Storage: total: 3.18 TiB used: 226.68 GiB (7.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: HD103SJ size: 931.51 GiB
    block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: HDD
    rpm: 7200 serial: <filter> fw-rev: 00E4 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HDS5C3020ALA632
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 5940 serial: <filter> fw-rev: A580 scheme: MBR
  ID-1: / raw-size: 371.09 GiB size: 364.2 GiB (98.14%) used: 71.23 GiB (19.6%)
    fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: SSDRoot
    uuid: 9dc4ed12-cf8e-41b5-a31c-9de5f50e8dc6
  ID-2: /home raw-size: 489.27 GiB size: 480.51 GiB (98.21%)
    used: 155.45 GiB (32.4%) fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: home
    uuid: c5fcc6d4-1db5-4ec5-8ede-0f76cd6ee4ab
  Kernel: swappiness: 50 (default 60) cache-pressure: 100 (default) zswap: yes
  ID-1: swap-1 type: file size: 11 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs label: System-reserviert
    uuid: 583E97273E96FD66
  ID-2: /dev/sda2 maj-min: 8:2 size: 199.39 GiB fs: ntfs label: System
    uuid: 0A12C25D12C24CFF
  ID-3: /dev/sda3 maj-min: 8:3 size: 527 MiB fs: ntfs label: N/A
    uuid: 34862028861FE95E
  ID-4: /dev/sda4 maj-min: 8:4 size: 1 KiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-5: /dev/sda5 maj-min: 8:5 size: 242.25 GiB fs: ntfs label: Daten
    uuid: 7024BEAB24BE73A6
  ID-6: /dev/sdb2 maj-min: 8:18 size: 94.66 GiB fs: ext4 label: SSDDaten
    uuid: b9358f37-9f4f-4c92-a7e7-034e046fa0f8
  ID-7: /dev/sdc1 maj-min: 8:33 size: 1.15 TiB fs: ntfs label: Daten3
    uuid: 86E470A6E47099DF
  ID-8: /dev/sdc2 maj-min: 8:34 size: 100.18 GiB fs: ext4 label: Backup
    uuid: ff56fbe9-6e09-4569-8fa8-8b97d1c923f1
  ID-9: /dev/sdc3 maj-min: 8:35 size: 439.45 GiB fs: ext4
    label: manjaro-gnome uuid: ba16c9d4-46e2-475f-acfb-453275b5b42a
  ID-10: /dev/sdc4 maj-min: 8:36 size: 146.48 GiB fs: ext4 label: Testsys
    uuid: afafb774-fda7-444d-b5f3-8ded4befe91c
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0020
  Device-1: 1-1.5:3 info: Cooler Master Masterkeys Lite L Combo RGB Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 2516:0042 class-ID: 0301
  Device-2: 1-1.6:4 info: USB OPTICAL MOUSE type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 30fa:0400 class-ID: 0301
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.2:3 info: Logitech F510 Gamepad [DirectInput Mode] type: HID
    driver: logitech,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 500mA chip-ID: 046d:c218 class-ID: 0300
  Device-2: 2-1.3:4 info: Genesys Logic USB 2.0 Card Reader
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    chip-ID: 05e3:070e class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 43.0 C mobo: 34.0 C gpu: nvidia temp: 48 C
  Fan Speeds (rpm): cpu: 1064 fan-1: 798 fan-3: 872 gpu: nvidia fan: 0%
  Power: 12v: N/A 5v: N/A 3.3v: 3.33 vbat: 3.28
  Processes: 277 Power: uptime: 54m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.08 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 256 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1924 libs: 515 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.26 running-in: yakuake inxi: 3.3.35
Jul 06 00:23:27 alexander-ms7589 systemd[1]: libvirtd.service: Found left-over process 755 (dnsmasq) in control group while starting unit. Ignoring.
Jul 06 00:23:27 alexander-ms7589 systemd[1]: libvirtd.service: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
Jul 06 00:23:27 alexander-ms7589 systemd[1]: libvirtd.service: Found left-over process 756 (dnsmasq) in control group while starting unit. Ignoring.
Jul 06 00:24:10 alexander-ms7589 kded6[938]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Jul 06 00:24:10 alexander-ms7589 plasmashell[961]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Jul 06 00:24:17 alexander-ms7589 kded6[938]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Jul 06 00:24:17 alexander-ms7589 plasmashell[961]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Jul 06 00:25:07 alexander-ms7589 libvirtd[1362]: Interner Fehler: connection closed due to keepalive timeout
VM Configuration
<domain type="kvm">
  <name>MXLinux-QXL-23</name>
  <uuid>a8d2dc63-ddef-42b2-93c4-30d79df02de3</uuid>
  <description>MXLinux Xfce
Video QXL
CPU 3
RAM 3072 - 5120</description>
  <metadata>
    <libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
      <libosinfo:os id="http://debian.org/debian/11"/>
    </libosinfo:libosinfo>
  </metadata>
  <memory unit="KiB">5242880</memory>
  <currentMemory unit="KiB">3145728</currentMemory>
  <vcpu placement="static">3</vcpu>
  <os>
    <type arch="x86_64" machine="pc-q35-6.2">hvm</type>
  </os>
  <features>
    <acpi/>
    <apic/>
    <vmport state="off"/>
  </features>
  <cpu mode="host-passthrough" check="none" migratable="on"/>
  <clock offset="utc">
    <timer name="rtc" tickpolicy="catchup"/>
    <timer name="pit" tickpolicy="delay"/>
    <timer name="hpet" present="no"/>
  </clock>
  <on_poweroff>destroy</on_poweroff>
  <on_reboot>restart</on_reboot>
  <on_crash>destroy</on_crash>
  <pm>
    <suspend-to-mem enabled="no"/>
    <suspend-to-disk enabled="no"/>
  </pm>
  <devices>
    <emulator>/usr/bin/qemu-system-x86_64</emulator>
    <disk type="file" device="disk">
      <driver name="qemu" type="raw"/>
      <source file="/var/lib/libvirt/images/MXLinux23_20GBoG.img"/>
      <target dev="vda" bus="virtio"/>
      <boot order="1"/>
      <address type="pci" domain="0x0000" bus="0x08" slot="0x00" function="0x0"/>
    </disk>
    <controller type="usb" index="0" model="qemu-xhci" ports="15">
      <address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
    </controller>
    <controller type="pci" index="0" model="pcie-root"/>
    <controller type="pci" index="1" model="pcie-root-port">
      <model name="pcie-root-port"/>
      <target chassis="1" port="0x10"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
    </controller>
    <controller type="pci" index="2" model="pcie-root-port">
      <target chassis="2" port="0x11"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
    </controller>
    <controller type="pci" index="3" model="pcie-root-port">
      <target chassis="3" port="0x12"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
    </controller>
    <controller type="pci" index="4" model="pcie-root-port">
      <target chassis="4" port="0x13"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
    </controller>
    <controller type="pci" index="5" model="pcie-root-port">
      <target chassis="5" port="0x14"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
    </controller>
    <controller type="pci" index="6" model="pcie-root-port">
      <target chassis="6" port="0x15"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x5"/>
    </controller>
    <controller type="pci" index="7" model="pcie-root-port">
      <target chassis="7" port="0x16"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x6"/>
    </controller>
    <controller type="pci" index="8" model="pcie-root-port">
      <target chassis="8" port="0x17"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x7"/>
    </controller>
    <controller type="pci" index="9" model="pcie-root-port">
      <target chassis="9" port="0x18"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x0" multifunction="on"/>
    </controller>
    <controller type="pci" index="10" model="pcie-root-port">
      <target chassis="10" port="0x19"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x1"/>
    </controller>
    <controller type="pci" index="11" model="pcie-root-port">
      <target chassis="11" port="0x1a"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x2"/>
    </controller>
    <controller type="pci" index="12" model="pcie-root-port">
      <target chassis="12" port="0x1b"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x3"/>
    </controller>
    <controller type="pci" index="13" model="pcie-root-port">
      <target chassis="13" port="0x1c"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x4"/>
    </controller>
    <controller type="pci" index="14" model="pcie-root-port">
      <target chassis="14" port="0x1d"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x5"/>
    </controller>
    <controller type="sata" index="0">
      <address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
    </controller>
    <controller type="virtio-serial" index="0">
      <address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
    </controller>
    <filesystem type="mount" accessmode="mapped">
      <source dir="/home/alexander/Downloads"/>
      <target dir="/VB_Shared"/>
      <address type="pci" domain="0x0000" bus="0x07" slot="0x00" function="0x0"/>
    </filesystem>
    <interface type="network">
      <mac address="52:54:00:75:16:66"/>
      <source network="default"/>
      <model type="virtio"/>
      <address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
    </interface>
    <serial type="pty">
      <target type="isa-serial" port="0">
        <model name="isa-serial"/>
      </target>
    </serial>
    <console type="pty">
      <target type="serial" port="0"/>
    </console>
    <channel type="unix">
      <target type="virtio" name="org.qemu.guest_agent.0"/>
      <address type="virtio-serial" controller="0" bus="0" port="1"/>
    </channel>
    <channel type="spicevmc">
      <target type="virtio" name="com.redhat.spice.0"/>
      <address type="virtio-serial" controller="0" bus="0" port="2"/>
    </channel>
    <input type="mouse" bus="ps2"/>
    <input type="keyboard" bus="ps2"/>
    <graphics type="spice">
      <listen type="none"/>
      <image compression="off"/>
      <gl enable="no"/>
    </graphics>
    <sound model="ich9">
      <address type="pci" domain="0x0000" bus="0x00" slot="0x1b" function="0x0"/>
    </sound>
    <audio id="1" type="spice"/>
    <video>
      <model type="virtio" heads="1" primary="yes">
        <acceleration accel3d="no"/>
      </model>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0"/>
    </video>
    <redirdev bus="usb" type="spicevmc">
      <address type="usb" bus="0" port="2"/>
    </redirdev>
      <address type="usb" bus="0" port="3"/>
    </redirdev>
    <watchdog model="itco" action="reset"/>
    <memballoon model="virtio">
      <address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
    </memballoon>
    <rng model="virtio">
      <backend model="random">/dev/urandom</backend>
      <address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
    </rng>
  </devices>
</domain>
This should solve your issue:
This is my mkinitcpio.
Are there any changes to be made? Or is everything correct?
Thank you
mkinitcpio -L
==> Available hooks
acpi_override		keymap			sd-encrypt
autodetect		kms			sd-plymouth²
base			lvm2			sd-shutdown
block			mdadm_udev		sd-vconsole
btrfs			memdisk			shutdown
consolefont		mhwd-fb			sleep
dmraid			microcode		strip
encrypt			modconf			systemd
filesystems		openswap		udev
fsck			plymouth		usr
grub-btrfs-overlayfs	plymouth-encrypt¹	v86d
hostdata		plymouth-shutdown
keyboard		resume
'¹' This hook is deprecated in favor of 'encrypt'
'²' This hook is deprecated in favor of 'plymouth'
I added my user only to the libvirt group according to ArchWiki libvirt 2. Configuration 2.1.1. Using libvirt group. and never run into problems before…
Yes, I had previously configured it this way, and the problem occurs less with the 2 other groups.
But at all it is a bug anyway.
