Another testing branch update with some usual package updates for you.
Recent News:
Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
Previous News
As you might have seen some of our team were able to attend FOSDEM 2023 and the conference proved to be incredibly productive for us. See our blog post for more.
Protect your personal data, keep yourself safe (unlimited devices): 82% off + 2 mo. FREE
Finding information easier about Manjaro always has been a topic that needed to be solved. With our new search we have put all Manjaro data accessible in one place and divided by sections so it makes it easier to digest: New Manjaro search engine is available | Blog
Notable Package Updates:
Some Kernels got updated
we have now more or less a full feature complete support of the ASUS ROG ALLY
Pamac11.7.0 got now fully ported to libadwaita 1.4
it is now fully adaptive and works with phosh
Gnome 45 is now supported
Usual KDE-git, Haskell and Python updates
Additional Info
Info about AUR packages
AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcements topics are off-topic and will be flagged, moved or removed without warning.
For help with AUR packages, please create a new topic in AUR and a helpful volunteer may be able to assist you.
2023-12-10
2023-11-10
Nvidia 545 drivers might have issues
Due to various issues including non working backlights on some machines, the NVIDIA 545 series feature branch drivers have been downgraded to the 535 series production branch drivers.
If you are having no issues with the 545 series, there is nothing to do. If you are, you can downgrade to the 535 series with pamac update --enable-downgrade or sudo pacman -Syuu.
So far we know about these issues the Nvidia 545 driver series has:
Backlight control might not work on certain laptop configurations. Reported also here
If you experience similar or new issues please run sudo usr/bin/nvidia-bug-report.sh and post either in an already given post or create a new one, including your generated nvidia-bug-report.log.gz for Nvidia to fix the issue: Linux - NVIDIA Developer Forums
Changes in JDK / JRE 21 packages may require manual intervention
2023-11-02 - Frederik Schwan
We are introducing a change in JDK/JRE packages of our distro. This is triggered from the way a JRE is build in modern versions of Java (>9). We are introducing this change in Java 21.
To sum it up instead of having JDK and JRE packages coexist in the same system we will be making them conflict. The JDK variant package includes the runtime environment to execute Java applications so if one needs compilation and runtime of Java they need only the JDK package in the future. If, on the other hand, they need just runtime of Java then JRE (or jre-headless) will work.
This will (potentially) require a manual user action during upgrade:
If you have both JDK and JRE installed you can manually install the JDK with pacman -Sy jdk-openjdk && pacman -Su and this removes the JRE related packages.
If you have both JRE and JRE-headless you will need to choose one of them and install it manually since they would conflict each other now.
If you only have one of the JDK/JRE/JRE-headless pacman should resolve dependencies normally and no action is needed.
At the moment this is only valid for the upcoming JDK 21 release.
Mechanical HDDs may not spin-down properly on shutdown
There might be a regression introduced with 6.6.0-rc4 which got also backported to 6.1.59 and 6.5.8 Kernels. There is a discussion with the author of the offending patch ongoing here.
ZFS package changes
ZFS extramodules; i.e., linuxXX-zfs, have been dropped from the repos. There have been recent difficulties building them and no one on the Manjaro Team uses ZFS.
Please install zfs-dkms instead. You will to need to manually remove the old 2.1.13 extramodule package(s) first to install the new 2.2.0 packages; i.e., with linux61:
GNOME Extensions that target older GNOME versions will not work in GNOME 45
It is recommended to remove all third-party extensions before updating, then install the compatible versions after updating and rebooting. All Most extensions in the Manjaro repos are already updated.
2023-10-05
glibc-locales update requires manual intervention
If you had the old glibc-locales package from the extra repo installed, the update to the new core package will need manual intervention:
Changes to default password hashing algorithm and umask settings
2023-09-22 - David Runge
With shadow >= 4.14.0, Arch Linux’s default password hashing algorithm changed from SHA512 to yescrypt [1].
Furthermore, the umask [2] settings are now configured in /etc/login.defs instead of /etc/profile.
This should not require any manual intervention.
Reasons for Yescrypt
The password-based key derivation function (KDF) and password hashing scheme yescrypt has been chosen due to its adoption (readily available in libxcrypt, which is used by pam [3]) and its stronger resilience towards password cracking attempts over SHA512.
Although the winner of the Password Hashing Competition [4] has been argon2, this even more resilient algorithm is not yet available in libxcrypt [5][6].
Configuring yescrypt
The YESCRYPT_COST_FACTOR setting in /etc/login.defs is currently without effect, until pam implements reading its value [7]. If a YESCRYPT_COST_FACTOR higher (or lower) than the default (5) is needed, it can be set using the rounds option of the pam_unix [8] module (i.e. in /etc/pam.d/system-auth).
General list of changes
yescrypt is used as default password hashing algorithm, instead of SHA512
pam honors the chosen ENCRYPT_METHOD in /etc/login.defs and does not override the chosen method anymore
changes in the filesystem (>= 2023.09.18) and pambase (>= 20230918) packages ensure, that umask is set centrally in /etc/login.defs instead of /etc/profile
After update (probably related to 2023-12-08 update), wifi is no longer working, and causes graphical interface to freeze, also computer is unable to shutdown, I have to use sysrq REISUB to shutdown. Here is output from dmesg:
Wifi model is Broadcom BCM43142, kernel version is 6.1.66-1, driver is linux61-broadcom-wl 6.30.223.271-76. I tried upgrading to kernel 6.6 but same issue happens. I have to downgrade kernel to 6.1.65-1 and linux61-broadcom-wl to 6.30.223.271-75 to have a working system.
Update: linux 6.7.0rc4-8 + linux67-broadcom-wl 6.30.223.271-0.11 is working.
:: installing dotnet-runtime (8.0.0.sdk100-3) breaks dependency ‘dotnet-runtime-7.0’ required by pinta
Exactly the same problem on the previous update. Finally I updated everything, but stayed on 6.6.4 kernel. Evidently, there is something wrong with the 6.6.5 kernel.
UPDATE: I took the risk of installing the 6.6.5-3 kernel a few minutes ago. It seems to be OK. No problems with WiFi etc. Keeping my fingers crossed.
