[Testing Update] 2023-03-18 - Kernels, Thunderbird, Cinnamon, KDE-git, Python, Haskell
Hello community,
Another testing branch update with some usual package updates for you.
Dont miss out on 20% on our Merch
Recent News:
  • Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
  • As you might have seen some of our team were able to attend FOSDEM 2023 and the conference proved to be incredibly productive for us. See our blog post for more.
Previous News
Notable Package Updates:
  • Most of the Kernels got renewed
  • Thunderbird is at 102.9.0
  • Some updates to Cinnamon packages
  • Usual KDE-git, Python and Haskell updates
Additional Info
Info about AUR packages
:warning: AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcement topics are off-topic and will be flagged, moved or removed without warning.
Info about GNOME 43
GNOME 43 is here! :partying_face:
New in Manjaro GNOME:
Lonely leftover orphan packages that have been removed from the Arch / Manjaro repositories:
  • adwaita-maia
  • dynamic-wallpaper-editor
  • firefox-gnome-theme-maia
  • gtkhash-nautilus
    (Not compatible with Nautilus 43)
  • manjaro-dynamic-wallpaper
  • manjaro-gdm-tweak
  • nautilus-terminal
    (Not compatible with Nautilus 43 & EOL)
Our current supported kernels
  • linux419 4.19.278
  • linux54 5.4.237
  • linux510 5.10.175
  • linux515 5.15.103
  • linux61 6.1.20
  • linux62 6.2.7
  • linux515-rt 5.15.94_rt59
  • linux60-rt 6.0.5_rt14
Package Changes (Sat Mar 18 03:04:09 CET 2023)
  • testing community x86_64: 311 new and 305 removed package(s)
  • testing core x86_64: 18 new and 18 removed package(s)
  • testing extra x86_64: 298 new and 355 removed package(s)
  • testing kde-unstable x86_64: 175 new and 175 removed package(s)
  • testing multilib x86_64: 6 new and 6 removed package(s)
A detailed list of all package changes can be found here
0 voters
Known issues and solutions
:arrow_right: 2023-03-18
2023-03-11
Possible kernel fs block code regression in 6.2.3 umounting usb drives
With kernel 6.2.3 when you simply plug in a usb external drive, mount it and umount it, then the journal has a kernel Oops. A bug report, that includes the journal output was submitted at. Making sure you're not a bot! Discussion can be found here: https://www.spinics.net/lists/stable/msg637035.html
kernel 5.15.99+ Black/empty screen during boot with i915 Intel gfx. No ways to do anything
Seems there is a regression introduced with 5.15.99 kernel update: Making sure you're not a bot!. My thoughts here: [Testing Update] 2023-03-11 - Kernels, Mesa 22.3.7, Phosh, LibreOffice 7.4.6 - #31 by philm
2023-02-10
Switch to the base-devel meta package requires manual intervention
2023-02-12 - Robin Candau
On February 2nd, the base-devel package group has been replaced by a meta package of the same name.
If you installed the base-devel package group prior to this date, explicitly re-install it to get the new base-devel package installed on the system:
pacman -Syu base-devel
Arch Linux - News: Switch to the base-devel meta package requires manual intervention
2023-01-17
Very slow shutdown when using KDE Plasma Wayland
The issue is sddm that can not be finished until the default timeout 90 sec.
The solution: Install sddm-git
The known bug reports:
PHP 8.2 update and introduction of legacy branch
2023-01-13 - Pierre Schmitz
The php packages have been updated to the latest version 8.2. In addition to this, a new set of php-legacy packages have been introduced. These will follow the oldest but still actively supported PHP branch. This enables users to install the latest version but also introduces the option to use third party applications that might rely on an older version. Both branches will be kept up to date following our rolling release model. php and php-legacy can be installed at the same time as the latter uses a -legacy suffix for its binaries and configuration files.
In addition to this, the php7 packages have been removed as they reached end of life. The imap extension will no longer be provided as it relies on the c-client library which has been abandoned for many years.
Arch Linux - News: PHP 8.2 update and introduction of legacy branch
2023-01-04
Some games like Dota 2 are freezing
The issue is caused by update libx11 1.8.3-4
The solution: Upgrade to libx11 1.8.3-5
VLC crashes when playing a video file
It looks like there has been a regression introduced with the new version of libva (2.17.0), which is used by VLC media player. If you get the following error when executing vlc in a terminal:
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
you may try to change the Output option in Preferences > Video to VDPAU output instead of Automatic (or whatever value it had been set to before).
Downgrading the libva package from 2.17.0-1 to 2.16.0-1 may also work, but it is a more short-term workaround that should not be kept for too long, as sooner or later, the older package won’t be compatible with the other packages. Consider to do the solution above first.
2022-12-22
pacman-mirrors was temporarily renamed to manjaro-mirrors (the changes were reverted)
This was done to avoid confusion with an AUR / WSL package with the same name and avoid possible breakage. It should be a seamless transition.
Rename project (#183) · Issues · Applications / pacman-mirrors · GitLab
2022-12-19
KDE Wayland sometimes hangs with mesa 22.3.1 and AMD GPU
2022-12-16
dbus-x11 demoted to AUR
dbus-x11 was installed out of the box on some flavors of Manjaro as of a year ago, but is no longer needed. If you have it installed, please replace it with dbus using the following:
sudo pacman -Syu dbus
XFCE becomes unusable if libxfce4ui-nocsd is still installed
So far XFCE Classic project hasn’t updated yet to 4.18 series. We pushed 4.17.0 version of the package, but don’t know if that helps in that situation. It is recommended to install the regular libxfce4ui package to avoid issues and comment on this issue: libxfce4ui 4.18.0 released · Issue #15 · Xfce-Classic/libxfce4ui-nocsd · GitHub
2022-12-04
python-cairo 1.23.0-2 update requires manual intervention
The python-cairo package prior to version 1.23.0-2 was missing the compiled python module. This has been fixed in 1.23.0-2, so the upgrade will need to overwrite the untracked pyc file that was created. If you receive this error
python-cairo: /usr/lib/python3.10/site-packages/cairo/__pycache__/__init__.cpython-310.pyc exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/python3.10/site-packages/cairo/__pycache__/\*
to perform the upgrade.
2022-11-08
Pop Shell issues with Xorg session with Mutter 43.1 (fixed with mutter 43.1-1.0)
Gnome 43 (X11) GTK4 windows failed to render · Issue #1541 · pop-os/shell · GitHub
2022-10-28
signature from "Manjaro Build Server <build_at_manjaro_dot_org>" is unknown trust
Seems our signing key for our Build Server had the 2022-10-28 as expire date set when generated. This is now fixed for chroot builds and fresh as also current existing installs via manjaro-keyring 20221028-4 Simply update your system to get that package, which got pushed to all our branches.
2022-10-27
Kernel 6.1-rc# might break backlight control on old/weird laptops
2022-10-18
Firefox 106.0 may have issues with screen sharing on GNOME with Wayland
2022-09-23
Nvidia 3060RTX cards may have issues with the 515.76 driver (fixed with 520.56.06)
Removing python2 from the repositories
2022-09-23 - Jelle van der Waa
Python 2 went end of life January 2020. Since then we have been actively cutting down the number of projects depending on python2 in our repositories, and we have finally been able to drop it from our distribution. If you still have python2 installed on your system consider removing it and any python2 package.
If you still require the python2 package you can keep it around, but please be aware that there will be no security updates. If you need a patched package please consult the AUR, or use an unofficial user repository.*
Arch Linux - News: Removing python2 from the repositories
* Note: Unofficial user repositories are not supported
I’m having trouble with kernels linux510 5.10.175-1 and 4.19.278-1 on my imac late 2015.
They hang at loading modules and won’t continue booting.
Booting back to the previous kernel 5.10.174-1 works fine (thanks Timeshift ! :slight_smile:) .
I found several errors related to i915 / DRM in dmesg (while trying to boot 4.19.278-1 here), with this line in red:
"kernel: [drm:drm_mode_config_cleanup.cold [drm]] *ERROR* connector DP-3 leaked!"
Followed by several occurances of:
mrt 18 16:01:23 imac kernel: WARN_ON(({ void *__mptr = (void *)(state); do { extern void __compiletime_assert_262(void) __attribute__((error("pointer type mismatch in container_of()"))); if (!(!(!__builtin_types_compatible_p(typeof(*(state)), typeof(((>
mrt 18 16:01:23 imac kernel: WARNING: CPU: 0 PID: 153 at drivers/gpu/drm/i915/intel_atomic_plane.c:105 intel_plane_destroy_state+0x37/0x50 [i915]
mrt 18 16:01:23 imac kernel: Modules linked in: i915(+) kvmgt vfio_mdev sd_mod mdev vfio_iommu_type1 vfio kvm irqbypass intel_gtt i2c_algo_bit ahci drm_kms_helper libahci syscopyarea sdhci_pci libata xhci_pci cqhci sysfillrect sysimgblt fb_sys_fops xhc>
mrt 18 16:01:23 imac kernel: CPU: 0 PID: 153 Comm: (udev-worker) Tainted: G        W         4.19.278-1-MANJARO #1
mrt 18 16:01:23 imac kernel: Hardware name: Apple Inc. iMac16,2/Mac-FFE5EF870D7BA81A, BIOS 428.60.3.0.0 10/27/2021
mrt 18 16:01:23 imac kernel: RIP: 0010:intel_plane_destroy_state+0x37/0x50 [i915]
mrt 18 16:01:23 imac kernel: Code: 90 00 00 00 00 48 89 f3 75 0d 48 89 de 48 89 ef 5b 5d e9 ac 6c e3 ff 48 c7 c6 28 38 7b c0 48 c7 c7 11 f1 79 c0 e8 4e d3 57 e3 <0f> 0b 48 89 de 48 89 ef 5b 5d e9 8a 6c e3 ff 66 2e 0f 1f 84 00 00
mrt 18 16:01:23 imac kernel: RSP: 0018:ffffb0d0011bbb38 EFLAGS: 00010282
mrt 18 16:01:23 imac kernel: RAX: 0000000000000000 RBX: ffffa0ad21eba600 RCX: 0000000000000000
mrt 18 16:01:23 imac kernel: RDX: 00000000000001d7 RSI: ffffffffa4ceb497 RDI: 0000000000000246
mrt 18 16:01:23 imac kernel: RBP: ffffa0ad21490400 R08: 0000000000000002 R09: ffffffffa4ceb2bf
mrt 18 16:01:23 imac kernel: R10: 0000000000000001 R11: 0000000000000000 R12: ffffa0ad21b38000
mrt 18 16:01:23 imac kernel: R13: ffffa0ad21b3c9e8 R14: 00000000fffffffa R15: ffffa0ad24e05000
mrt 18 16:01:23 imac kernel: FS:  00007f86e003b080(0000) GS:ffffa0ad26a00000(0000) knlGS:0000000000000000
mrt 18 16:01:23 imac kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
mrt 18 16:01:23 imac kernel: CR2: 00007f8026f80000 CR3: 000000026193a002 CR4: 00000000003606f0
mrt 18 16:01:23 imac kernel: DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
mrt 18 16:01:23 imac kernel: DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
mrt 18 16:01:23 imac kernel: Call Trace:
mrt 18 16:01:23 imac kernel:  drm_plane_cleanup+0xad/0xf0 [drm]
mrt 18 16:01:23 imac kernel:  intel_plane_destroy+0xe/0x20 [i915]
mrt 18 16:01:23 imac kernel:  drm_mode_config_cleanup+0x104/0x280 [drm]
mrt 18 16:01:23 imac kernel:  intel_modeset_cleanup+0xbc/0x130 [i915]
mrt 18 16:01:23 imac kernel:  i915_driver_load+0xbad/0xdc0 [i915]
mrt 18 16:01:23 imac kernel:  ? acpi_dev_found+0x5f/0x70
mrt 18 16:01:23 imac kernel:  local_pci_probe+0x3e/0x80
mrt 18 16:01:23 imac kernel:  pci_device_probe+0x102/0x1a0
mrt 18 16:01:23 imac kernel:  really_probe+0x245/0x3c0
mrt 18 16:01:23 imac kernel:  driver_probe_device+0xb3/0xf0
mrt 18 16:01:23 imac kernel:  __driver_attach+0x104/0x110
mrt 18 16:01:23 imac kernel:  ? driver_probe_device+0xf0/0xf0
mrt 18 16:01:23 imac kernel:  bus_for_each_dev+0x71/0xb0
mrt 18 16:01:23 imac kernel:  bus_add_driver+0x16a/0x220
mrt 18 16:01:23 imac kernel:  driver_register+0x89/0xd0
mrt 18 16:01:23 imac kernel:  ? 0xffffffffc0871000
mrt 18 16:01:23 imac kernel:  do_one_initcall+0x46/0x1d0
mrt 18 16:01:23 imac kernel:  ? kmem_cache_alloc_trace+0x2f/0x1b0
mrt 18 16:01:23 imac kernel:  do_init_module+0x4c/0x260
mrt 18 16:01:23 imac kernel:  __se_sys_finit_module+0xb1/0x110
mrt 18 16:01:23 imac kernel:  do_syscall_64+0x4e/0x110
mrt 18 16:01:23 imac kernel:  entry_SYSCALL_64_after_hwframe+0x5c/0xc1
mrt 18 16:01:23 imac kernel: RIP: 0033:0x7f86e0b660dd
mrt 18 16:01:23 imac kernel: Code: 5d c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 63 7c 0d 00 f7 d8 64 89 01 48
mrt 18 16:01:23 imac kernel: RSP: 002b:00007fff34b17fc8 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
mrt 18 16:01:23 imac kernel: RAX: ffffffffffffffda RBX: 00005566daeded40 RCX: 00007f86e0b660dd
mrt 18 16:01:23 imac kernel: RDX: 0000000000000000 RSI: 00007f86e0cb9343 RDI: 000000000000001b
mrt 18 16:01:23 imac kernel: RBP: 00007f86e0cb9343 R08: 0000000000000000 R09: 0000000000000000
mrt 18 16:01:23 imac kernel: R10: 000000000000001b R11: 0000000000000246 R12: 0000000000020000
mrt 18 16:01:23 imac kernel: R13: 00005566daece520 R14: 00005566daeded40 R15: 00005566daee28f0
mrt 18 16:01:23 imac kernel: ---[ end trace 07e565c61a1cf4c3 ]---
My system info:
  Host: imac Kernel: 5.10.174-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 12.2.1 Desktop: KDE Plasma v: 5.24.7 tk: Qt v: 5.15.8 wm: kwin_x11
  Type: Desktop System: Apple product: iMac16,2 v: 1.0
    serial: <superuser required> Chassis: type: 13 v: Mac-FFE5EF870D7BA81A
  Mobo: Apple model: Mac-FFE5EF870D7BA81A v: iMac16,2
    serial: <superuser required> UEFI: Apple v: 428.60.3.0.0 date: 10/27/2021
  Info: quad core model: Intel Core i5-5675R bits: 64 type: MCP
    arch: Broadwell rev: 1 cache: L1: 256 KiB L2: 1024 KiB L3: 4 MiB
  Speed (MHz): avg: 2904 high: 3033 min/max: 800/3600 cores: 1: 2854 2: 2828
    3: 3033 4: 2904 bogomips: 24751
  Device-1: Intel Iris Pro Graphics 6200 vendor: Apple driver: i915 v: kernel
    arch: Gen-8 ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
    bus-ID: 00:02.0 chip-ID: 8086:1622
  Device-2: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo
    bus-ID: 1-7:3 chip-ID: 05ac:8511
  Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: i965 gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 4096x2304 s-dpi: 192
  Monitor-1: DP-3 model: Apple iMac res: 4096x2304 dpi: 219
    diag: 545mm (21.5")
  API: OpenGL v: 4.6 Mesa 21.3.9 Amber renderer: Mesa DRI Intel Iris Pro
    Graphics 6200 (BDW GT3) compat-v: 3.0 direct-render: Yes
  Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
  Device-2: Intel 9 Series Family HD Audio driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:8ca0
  Sound API: ALSA v: k5.10.174-1-MANJARO running: yes
  Sound Server-1: JACK v: 1.9.22 running: no
  Sound Server-3: PipeWire v: 0.3.67 running: no
  Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
    driver: brcmfmac v: kernel pcie: speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
    chip-ID: 14e4:43ba
  IF: wlp3s0 state: up mac: 28:f0:76:77:58:72
  IP v4: 192.168.1.20/24 type: dynamic noprefixroute scope: global
    broadcast: 192.168.1.255
  Device-2: Broadcom NetXtreme BCM57766 Gigabit Ethernet PCIe driver: tg3
    v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0
    chip-ID: 14e4:1686
  IF: eno1 state: down mac: a8:60:b6:1e:2f:b3
  IP v4: 10.120.18.43/23 scope: global
  WAN IP: 84.17.46.25
  Device-1: Apple Bluetooth USB Host Controller type: USB
    driver: btusb,hid-generic,usbhid bus-ID: 1-8:5 chip-ID: 05ac:8294
  Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: 28:F0:76:77:58:73
  Local Storage: total: 1.36 TiB used: 496.86 GiB (35.6%)
  ID-1: /dev/sda vendor: Apple model: HDD HTS541010A9E662 size: 931.51 GiB
    speed: 3.0 Gb/s serial: JD8002D825WUDD
  ID-2: /dev/sdb type: USB vendor: Samsung model: Portable SSD T3
    size: 465.76 GiB serial: S2WENP0HA05448V
  ID-1: / size: 457.09 GiB used: 150.72 GiB (33.0%) fs: ext4 dev: /dev/sdb2
  ID-2: /boot/efi size: 299.4 MiB used: 16.4 MiB (5.5%) fs: vfat
    dev: /dev/sdb1
  ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 50.0 C mobo: N/A
  Processes: 210 Uptime: 57m Memory: 7.64 GiB used: 3.4 GiB (44.5%)
  Init: systemd v: 252 default: graphical Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1360 Shell: Bash v: 5.1.16
  running-in: mate-terminal inxi: 3.3.25
Thanks in advance !
Cheers,
Eddy
Yes, linux510 5.10.175-1 won’t boot for me either. I am also using the i915 driver. 5.10.174-1 works for me (5.15.103-1 works also).
This is literally the same bug I had on 5.15.99 a week ago.
You can send a report to the Linux developers, like described here:
In two words, the problem is in drm-i915-don-t-use-bar-mappings-for-ring-buffers-with-llc.patch
I noticed linux515 5.15.103-1 works for me with i915.
Most likely that is the issue here. Since the other LLC patches got removed I really wonder how that slipped in. Seems I’ve to write Greg again. I really wonder if 6.3RC is now working on i915 at all …
Yes, as only the following kernels are affected by this: 4.14.310, 4.19.278, 5.4.237, 5.10.175
Hi,
Friday’s kernel 6.1 and 6.2 update gives me a black screen, I have to downgrade to 5.15.
What should I do to get my system back in order?
Some info:
inxi -Fza         ✔
  Kernel: 5.15.102-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=884fb64e-f4e4-4e60-9e47-78aaf8e7d11e rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: PRIME B350M-K v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 5602
    date: 07/14/2020
  Info: model: AMD Ryzen 3 1200 bits: 64 type: MCP arch: Zen level: v3
    note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
    stepping: 1 microcode: 0x8001138
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
    desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1698 high: 2318 min/max: 1550/3100 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1504 2: 1637
    3: 1336 4: 2318 bogomips: 24760
    prctl and seccomp
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GK208B [GeForce GT 710] vendor: ASUSTeK GT710-SL-1GD5
    driver: nvidia v: 470.161.03 alternate: nouveau,nvidia_drm non-free:
    series: 470.xx+ status: legacy-active (EOL~2023/24) arch: Fermi 2
    code: GF119/GK208 process: TSMC 28nm built: 2010-16 pcie: gen: 2
    speed: 5 GT/s lanes: 8 bus-ID: 08:00.0 chip-ID: 10de:128b class-ID: 0300
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.87x11.85")
    s-diag: 610mm (24")
  Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 93
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 470.161.03 renderer: NVIDIA GeForce GT
    710/PCIe/SSE2 direct-render: Yes
  Device-1: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8 bus-ID: 08:00.1
    chip-ID: 10de:0e0f class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.3
    chip-ID: 1022:1457 class-ID: 0403
  Sound API: ALSA v: k5.15.102-1-MANJARO running: yes
  Sound Interface: sndio v: N/A running: no
  Sound Server-3: PipeWire v: 0.3.65 running: yes
    vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.66 TiB used: 83.8 GiB (4.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
    type: SSD serial: <filter> rev: 1B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1ER162
    type: HDD rpm: 7200 serial: <filter> rev: CC45 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: HD322HJ
    size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: N/A serial: <filter> rev: 1113 scheme: GPT
  ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 34.16 GiB (71.5%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
    used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 416.44 GiB size: 408.84 GiB (98.17%)
    used: 49.64 GiB (12.1%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
  ID-1: swap-1 type: file size: 512 MiB used: 2.2 MiB (0.4%) priority: 50
    file: /var/lib/systemd-swap/swapfc/1
  System Temperatures: cpu: 33.5 C mobo: N/A gpu: nvidia temp: 46 C
  Processes: 243 Uptime: 34m wakeups: 0 Memory: 7.69 GiB
  used: 6.38 GiB (82.9%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1713 libs: 429 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
Currently running: 5.15.102-1-MANJARO (linux515)
   * linux515
   * linux61
   * linux62
sudo mhwd -li         ✔  12s 
> Installed PCI configs:
    video-nvidia-470xx            2021.12.18               false            PCI
sudo journalctl -b0 -g 'nvidia'                                                        ✔
mars 19 10:02:46 jeanluc-pc kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03>
mars 19 10:02:46 jeanluc-pc kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03>
mars 19 10:02:46 jeanluc-pc kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03>
mars 19 10:02:46 jeanluc-pc kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03>
mars 19 10:02:46 jeanluc-pc kernel: input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:0>
mars 19 10:02:46 jeanluc-pc kernel: nvidia: loading out-of-tree module taints kernel.
mars 19 10:02:46 jeanluc-pc kernel: nvidia: module license 'NVIDIA' taints kernel.
mars 19 10:02:46 jeanluc-pc kernel: nvidia: module verification failed: signature and/or required key>
mars 19 10:02:46 jeanluc-pc kernel: nvidia-nvlink: Nvlink Core is being initialized, major device num>
mars 19 10:02:46 jeanluc-pc kernel: nvidia 0000:08:00.0: vgaarb: changed VGA decodes: olddecodes=io+m>
mars 19 10:02:46 jeanluc-pc systemd-modules-load[266]: Inserted module 'nvidia'
mars 19 10:02:46 jeanluc-pc kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  470.161.03  Wed O>
mars 19 10:02:47 jeanluc-pc kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNI>
mars 19 10:02:47 jeanluc-pc systemd-modules-load[266]: Inserted module 'nvidia_drm'
mars 19 10:02:47 jeanluc-pc kernel: [drm] [nvidia-drm] [GPU ID 0x00000800] Loading driver
mars 19 10:02:47 jeanluc-pc kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:08:00.0 on m>
mars 19 10:02:47 jeanluc-pc kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, i>
mars 19 10:02:47 jeanluc-pc systemd-modules-load[266]: Inserted module 'nvidia_uvm'
mars 19 10:02:47 jeanluc-pc kernel: nvidia-uvm: Loaded the UVM driver, major device number 510.
mars 19 10:02:48 jeanluc-pc kernel: caller _nv000720rm+0x1ad/0x200 [nvidia] mapping multiple BARs
mars 19 10:02:52 jeanluc-pc kwin_x11[697]: OpenGL vendor string:                   NVIDIA Corporation
mars 19 10:02:52 jeanluc-pc kwin_x11[697]: OpenGL renderer string:                 NVIDIA GeForce GT >
mars 19 10:02:52 jeanluc-pc kwin_x11[697]: OpenGL version string:                  3.1.0 NVIDIA 470.1>
mars 19 10:02:52 jeanluc-pc kwin_x11[697]: OpenGL shading language version string: 1.40 NVIDIA via Cg>
mars 19 10:02:52 jeanluc-pc kwin_x11[697]: Driver:                                 NVIDIA
mars 19 10:38:31 jeanluc-pc dbus-daemon[451]: [system] Activating via systemd: service name='org.free>
mars 19 10:38:31 jeanluc-pc sudo[5857]:  jeanluc : TTY=pts/1 ; PWD=/home/jeanluc ; USER=root ; COMMAN>
...skipping...
...skipping...
...skipping...
It looks like your running the nvidia-470xx driver.Have you checked to see if it’s been updated for the latest kernels.If not 5.15 is an LTS kernel so maybe stick with it until the drivers are updated.
This morning I got a new update only for kernel 6.2 and nvidia-470xx, but nothing has changed, still black screen… I’m sticking with 5.15 for now.
@jeanluc This packages always update due new kernel updates. 470.161.03-25 (b85d5564) · Commits · Packages / Extra / linux61-extramodules / nvidia-470xx · GitLab
booting the just released 4.19.278-2 still fails with the same problem:
mrt 19 19:13:03 imac kernel: [drm:drm_mode_config_cleanup.cold [drm]] *ERROR* connector DP-3 leaked!
mrt 19 19:13:03 imac kernel: =============================================================================
mrt 19 19:13:03 imac kernel: BUG i915_vma (Tainted: G        W        ): Objects remaining in i915_vma on __kmem_cache_shutdown()
mrt 19 19:13:03 imac kernel: -----------------------------------------------------------------------------
mrt 19 19:13:03 imac kernel: INFO: Slab 0x0000000033192b98 objects=28 used=1 fp=0x0000000060efe245 flags=0x2ffff0000008100
mrt 19 19:13:03 imac kernel: INFO: Object 0x00000000eed88901 @offset=9216
mrt 19 19:13:03 imac kernel: kmem_cache_destroy i915_vma: Slab cache still has objects
mrt 19 19:13:03 imac kernel: i915 0000:00:02.0: Device initialization failed (-6)
Keeping the old kernel for now…
Cheers,
Eddy
A little error did slip in the package change url : it’s “859” that should be read instead of “856”.
Fixed it.
drm-i915-don-t-use-stolen-memory-for-ring-buffers-with-llc.patch « queue-5.10 - kernel/git/stable/stable-queue.git - Linux kernel stable patch queue seems to be another patch to fix the issue. I could do a 5.10.176-rc1 build if @stasadev is willing to give it a try …
Well it will be based on 5.10.175 plus the RC patches on top. With 5.10.175-2 I reverted the offending patch, which I won’t do with the RC kernel as upstream claims additional drm patches fixes the issue we have now. You may give 5.10.176-0 a run when it is available and give me your result: Releases · manjaro-kernels/linux510 · GitHub - it is currently compiling: Rebuild Kernel · manjaro-kernels/linux510@cdeb2f9 · GitHub
I’ve no issue to trigger 4.19.279-rc1 too: Rebuild Kernel · manjaro-kernels/linux419@23b8019 · GitHub. Find it here in 3-4 hours: Releases · manjaro-kernels/linux419 · GitHub
Also I figured out why 4.19.278-2 didn’t worked. It seems that kernel is not yet adopted to apply the patches as we do it in other kernels …
We should not push them to stable, but I guess you know that.
Maybe give 5.15.104-0 also a try when ready: https://github.com/manjaro-kernels/linux515/releases There the patch got reverted in 5.15.101 but never readded, so we might have again only a partial patch set for i915-drm …
