After logging in, I get no desktop at all, all I get is a dolphin gui window but nothing else, haven’t updated my pc in like 2 weeks but this update definitely made things wrong. Is there a way to fix it?
I tried your first suggestion, but nothing changed.
Normally I don’t use kernels above 5.0, because of a bug in the suspension/resume. Like I reported here and here. So, I prefer using an old kernel like 4.19.
Anyway, I tried kernel 5.12, 5.10 and 4.9, too. They boot up without problems but I had the suspension issue again on 5.12 and 5.10.
I had the virtualbox modules installed only for kernel 4.19, so I decided to remove virtualbox and kernel modules, then sudo mkinitcpio -P again. Nothing to do.
The 4.19 is the only kernel that won’t boot.
I didn’t check you third suggestion. Is there a way to check the voltage using a software?
cat /proc/driver/rtc | grep batt_status
If it says “batt_status” : okay then o.k.
otherwise may be BIOS entry?
Problems looks like “nvidia-drivers” related. I avoid nvidia-cards, sorry.
There was a big change recently
regarding nvidia-drivers…
Please search Forum “Nvidia” related issues?!
