You should search / switch for libreoffice-fresh to find v7. Seems you’ve Libreoffice-still installed instead.
Can confirm, the same happened on my machine (also manjaro-i3). Since dunstify is required by dunst and dunst is required by manjaro-i3-settings, I can’t fix this myself.
1,remove dust dunstify manjaro-i3-settings
2,pacman -Syu
3,install dust dunstify manjaro-i3-settings
it is ok …maybe u can try!
Upgrade was a delight.
pacman -Su --overwrite /usr/bin/dunstify got rid of the above-mentioned error.
Also, it complained about the file /etc/apparmor.d/local/firejail-default being already there. It was empty, so I deleted it and the upgrade went fine.
Especially nice is, that the pam updates now work perfectly with systemd-homed and the custom changes from the Arch-Wiki are no longer necessary.
I renamed dunstify to dusntify.bak and after that the update went fine and the new dunstify binary was installed.
Seems to be good on my side, on Manjaro Cinnamon. Thanks for the update.
Had the same problem with dunstify on manjaro i3wm. This solved the problem and the update went fine. Thanks.
Still have LibreOffice version 6.4.6.2, did I miss anything about this update?
You’ll have to install libreoffice-fresh if you want 7.0.
Ah, I didn’t really mess with much when I changed from stable to testing, will check it out, thank you
Updated my system without any problems…
Although because the first install was made with 0.8.13 version some details related to systemd startup got changed in one of the latest versions namely the remove of the “telinit” command …
I didn’t get on Cinnamon.
I hope It will came in few days. I so curious about Libre Office
you mean LibreOffice 7.0?
@Yochanan just put it as clear as it gets.
The libreoffice-fresh package always points to the latest version.
So:
sudo pacman -S libreoffice-fresh
and you get LibreOffice 7.0
I am also having trouble with LibreOffice 7. Currently I am running v6.4.5.2 but the only update I see is for LibreOffice Math (libreoffice-fresh) 7.0.0-1 (6.4.5-2) and there is no mention of other LibreOffice applications. I can’t even find libreoffice-fresh among the software anymore (only search hits regard language packs for libreoffice-fresh). Also, searching among already installed applications, the only hit I get is for LibreOffice Math, even though I previously installed the whole libreoffice-fresh package and I am able to launch Writer, Calc etc. Something is wrong…
EDIT: Seems to have solved itself after running:
sudo pacman -Syyu
[sudo] password for axe:
warning: libreoffice-fresh-6.4.5-2 is up to date -- reinstalling
resolving dependencies...
Packages (1) libreoffice-fresh-6.4.5-2
Total Installed Size: 395,33 MiB
Net Upgrade Size: 0,00 MiB
:: Proceed with installation? [Y/n] n
but
yay -Ss libreoffice-fresh
aur/papirus-libreoffice-fresh-rpm-theme-git 20170228-1 (+0 0.00) (Orphaned)
Papirus theme for LibreOffice-Fresh RPM (git version)
aur/libreoffice-fresh-rpm 7.0.0-1 (+18 0.64)
LGPL Office Suite installed from rpms
extra/libreoffice-fresh-zu 6.4.5-1 (255.8 KiB 1.4 MiB)
Zulu language pack for LibreOffice Fresh
I think I should wait little bit more
@maxemilian Use pacman-mirrors -f5 && pacman -Syy libreoffice-fresh
Yes and no, I vaguely remember this being a result of appstream data pamac is using.
edit: found it:
https://archived.forum.manjaro.org/t/libreoffice-fresh-6-4-4-1-missing-in-repository/148445/5
Hi @philm, I cannot use virtualbox (v6.1.12) on kernel 5.8.3 anymore. When it starts, it freezes the whole system (KDE on nvidia driver).
That happens both with and without virtualbox-ext-oracle.
It works on my laptop with hybrid-intel drivers.
Is this a known issue?
Receiving the following for virtualbox:
Packages (1) virtualbox-host-dkms-6.1.12-3
Total Installed Size: 9.97 MiB
Net Upgrade Size: 0.00 MiB
(1/1) checking keys in keyring [##############################################] 100%
(1/1) checking package integrity [##############################################] 100%
(1/1) loading package files [##############################################] 100%
(1/1) checking for file conflicts [##############################################] 100%
(1/1) checking available disk space [##############################################] 100%
(1/1) Remove upgraded DKMS modules
==> dkms remove --no-depmod -m vboxhost -v 6.1.12_OSE -k 5.7.17-2-MANJARO
==> dkms remove --no-depmod -m vboxhost -v 6.1.12_OSE -k 5.4.60-2-MANJARO
==> Unable to remove module vboxhost/6.1.12_OSE for kernel 5.8.3-2-MANJARO: Not found in dkms status output.
(1/1) reinstalling virtualbox-host-dkms [##############################################] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Install DKMS modules
==> dkms install --no-depmod -m vboxhost -v 6.1.12_OSE -k 5.8.3-2-MANJARO
Error! Bad return status for module build on kernel: 5.8.3-2-MANJARO (x86_64)
Consult /var/lib/dkms/vboxhost/6.1.12_OSE/build/make.log for more information.
==> Warning, `dkms install --no-depmod -m vboxhost -v 6.1.12_OSE -k 5.8.3-2-MANJARO' returned 10
==> dkms install --no-depmod -m vboxhost -v 6.1.12_OSE -k 5.7.17-2-MANJARO
==> dkms install --no-depmod -m vboxhost -v 6.1.12_OSE -k 5.4.60-2-MANJARO
==> depmod 5.8.3-2-MANJARO
==> depmod 5.7.17-2-MANJARO
==> depmod 5.4.60-2-MANJARO
The /var/lib/dkms/vboxhost/6.1.12_OSE/build folder does not exist.
