Good morning everyone.
Last two days I have had two very sudden hard freezes on my system. Both times I was watching something on the internet (first one YouTube, the second Odysee). Both times I was using Nvidia settings with optimus-manager and both freezes happened after updating few graphical drivers (mesa, mesa-vulkan, I think Nvidia was there also, update log at the bottom) drivers.
Both times everything was frozen solid, meaning I wasn’t even able to use TTY. Only hard reset seemed to do the trick.
I have been looking at the logs, but to be honest, I am not experienced enough to notice what I am looking for. If someone can help me identify the problem, I should be able to figure out the solution myself
The log is MASSIVE and I went 40x over the allowed numbrer of char in this post so I had to use pastebin:
INXI
Kernel: 5.12.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=1c142e9a-0f6d-4249-a9c9-c0091c0fdbf8 rw quiet apparmor=1
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8478 v: 70.57 serial: <filter> UEFI: Insyde v: F.22
date: 04/21/2020
ID-1: BAT1 charge: 26.7 Wh (100.0%) condition: 26.7/52.8 Wh (50.6%)
volts: 12.8 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Full
RAM: total: 15.53 GiB used: 2.47 GiB (15.9%)
Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE cache: L2: 8 MiB bogomips: 36812
Speed: 900 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 900 2: 3223
3: 2799 4: 1506 5: 909 6: 900 7: 900 8: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0300
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
Integrated Webcam
type: USB driver: uvcvideo bus-ID: 1-5:4 chip-ID: 05c8:03bc class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.4:8 chip-ID: 0d8c:0005
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.12.8-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:b822 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 05:00.0
Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-14:6 chip-ID: 0bda:b00b class-ID: e001 serial: <filter>
Local Storage: total: 1.6 TiB used: 558.86 GiB (34.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLW256HEHP-000H1
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: CXB73H1Q scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Toshiba
model: External USB 3.0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B serial: <filter> rev: 5438 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD My Passport 0740 size: 465.73 GiB block-size: physical: 512 B
logical: 512 B serial: <filter> rev: 1007 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 53.28 GiB (22.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 1c142e9a-0f6d-4249-a9c9-c0091c0fdbf8
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: D7A9-849E
ID-3: /run/media/olividir/500 Gaming raw-size: 465.73 GiB
size: 457.42 GiB (98.22%) used: 382.43 GiB (83.6%) fs: ext4 dev: /dev/sdb1
maj-min: 8:17 label: 500 Gaming uuid: de409be9-45c3-41ba-973e-edb56ccb5ee2
ID-4: /run/timeshift/backup raw-size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 123.15 GiB (13.4%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
label: 1TB_Backup uuid: 36188c27-123c-4a32-8813-b60224d6cc58
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Hub-2: 1-2:3 info: Terminus Hub ports: 4 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-2.1:5 info: MosArt USB Device type: Mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 062a:410c class-ID: 0300
Device-2: 1-2.2:7 info: HP ENVY 4520 series type: Printer driver: usblp
interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 2mA chip-ID: 03f0:d711
class-ID: 0701 serial: <filter>
Device-3: 1-2.4:8 info: C-Media Blue Snowball type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0005 class-ID: 0300
serial: <filter>
Device-4: 1-5:4 info: Cheng Uei Precision Industry (Foxlink) HP Wide Vision
HD Integrated Webcam
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05c8:03bc class-ID: 0e02
Device-5: 1-14:6 info: Realtek Realtek Bluetooth 4.2 Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
Device-1: 2-1:3 info: Western Digital My Passport Essential (WDBACY)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 896mA chip-ID: 1058:0740 class-ID: 0806 serial: <filter>
Device-2: 2-3:2 info: Toshiba America MQ04UBF100 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 0480:0900 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 57.0 C mobo: 29.8 C gpu: nvidia temp: 52 C
Processes: 253 Uptime: 26m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 alt: 10 clang: 11.1.0 Packages: pacman: 1369 lib: 388
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.04
Pacman log:
[2021-05-21T22:04:56+0000] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/mhwd/pacman-mhwd.conf --root / -Sy'
[2021-05-21T22:04:56+0000] [PACMAN] synchronizing package lists
[2021-05-21T22:04:56+0000] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/mhwd/pacman-mhwd.conf --root / --needed -S nvidia-utils nvidia-prime lib32-nvidia-utils linux510-nvidia'
[2021-05-21T22:05:00+0000] [ALPM] transaction started
[2021-05-21T22:05:01+0000] [ALPM] installed nvidia-utils (460.73.01-1)
[2021-05-21T22:05:01+0000] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m If you run into trouble with CUDA not being available, run nvidia-modprobe first.e[1;0m
[2021-05-21T22:05:01+0000] [ALPM] installed nvidia-prime (1.0-4)
[2021-05-21T22:05:01+0000] [ALPM] installed lib32-nvidia-utils (460.73.01-1)
[2021-05-21T22:05:01+0000] [ALPM] installed linux510-nvidia (460.73.01-1)
[2021-05-21T22:05:07+0000] [ALPM-SCRIPTLET] In order to use nvidia module, reboot the system.
[2021-05-21T22:05:07+0000] [ALPM] transaction completed
[2021-05-21T22:05:07+0000] [ALPM] running '20-systemd-sysusers.hook'...
[2021-05-21T22:05:07+0000] [ALPM-SCRIPTLET] Creating group nvidia-persistenced with gid 143.
[2021-05-21T22:05:07+0000] [ALPM-SCRIPTLET] Creating user nvidia-persistenced (NVIDIA Persistence Daemon) with uid 143 and gid 143.
[2021-05-21T22:05:07+0000] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-05-21T22:05:07+0000] [ALPM-SCRIPTLET] Skipped: Current root is not booted.
[2021-05-21T22:05:07+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-21T22:05:07+0000] [ALPM] running '60-depmod.hook'...
[2021-05-21T22:05:07+0000] [ALPM] running '90-nvidia-utils.hook'...
[2021-05-21T22:05:07+0000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
[2021-05-21T22:05:07+0000] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
[2021-05-21T22:05:07+0000] [ALPM-SCRIPTLET] ==> Starting build: 5.10.32-1-MANJARO
[2021-05-21T22:05:07+0000] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-05-21T22:05:07+0000] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-05-21T22:05:07+0000] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-05-21T22:05:08+0000] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-05-21T22:05:08+0000] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-05-21T22:05:08+0000] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-05-21T22:05:08+0000] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-05-21T22:05:08+0000] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-05-21T22:05:08+0000] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-05-21T22:05:08+0000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-05-21T22:05:08+0000] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
[2021-05-21T22:05:09+0000] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-05-21T22:05:09+0000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
[2021-05-21T22:05:09+0000] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
[2021-05-21T22:05:09+0000] [ALPM-SCRIPTLET] ==> Starting build: 5.10.32-1-MANJARO
[2021-05-21T22:05:09+0000] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-05-21T22:05:09+0000] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-05-21T22:05:09+0000] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-05-21T22:05:09+0000] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-05-21T22:05:11+0000] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-05-21T22:05:12+0000] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-05-21T22:05:12+0000] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-05-21T22:05:13+0000] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-05-21T22:05:14+0000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-05-21T22:05:14+0000] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-05-21T22:05:18+0000] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-05-21T22:05:18+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-05-21T22:05:18+0000] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/mhwd/pacman-mhwd.conf --root / -D --asexplicit nvidia-utils nvidia-prime lib32-nvidia-utils linux510-nvidia'
[2021-05-21T22:05:32+0000] [PACMAN] Running 'pacman -R --noconfirm amd-ucode'
[2021-05-21T22:05:32+0000] [ALPM] transaction started
[2021-05-21T22:05:32+0000] [ALPM] removed amd-ucode (20210426.r1905.fa0efef-1)
[2021-05-21T22:05:32+0000] [ALPM] transaction completed
[2021-05-21T22:05:32+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-21T22:12:15+0000] [PACMAN] Running 'pacman -Syyu'
[2021-05-21T22:12:15+0000] [PACMAN] synchronizing package lists
[2021-05-21T22:12:19+0000] [PACMAN] starting full system upgrade
[2021-05-21T22:23:49+0000] [ALPM] running '60-mkinitcpio-remove.hook'...
[2021-05-21T22:23:49+0000] [ALPM] running 'firefox-pre.hook'...
[2021-05-21T22:23:49+0000] [ALPM] running 'kernel-alive-pre.hook'...
[2021-05-21T22:23:50+0000] [ALPM] running 'thunderbird-pre.hook'...
[2021-05-21T22:23:50+0000] [ALPM] transaction started
[2021-05-21T22:23:50+0000] [ALPM] upgraded linux-api-headers (5.10.13-1 -> 5.12.3-1)
[2021-05-21T22:23:50+0000] [ALPM] upgraded glibc (2.33-4 -> 2.33-5)
[2021-05-21T22:23:50+0000] [ALPM-SCRIPTLET] Generating locales...
[2021-05-21T22:23:51+0000] [ALPM-SCRIPTLET] en_US.UTF-8... done
[2021-05-21T22:23:52+0000] [ALPM-SCRIPTLET] is_IS.UTF-8... done
[2021-05-21T22:23:52+0000] [ALPM-SCRIPTLET] Generation complete.
[2021-05-21T22:23:52+0000] [ALPM] upgraded gcc-libs (10.2.0-6 -> 11.1.0-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded ncurses (6.2-1 -> 6.2-2)
[2021-05-21T22:23:53+0000] [ALPM] upgraded readline (8.1.0-2 -> 8.1.001-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded bashrc-manjaro (5.1.0-2 -> 5.1.008-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded bash (5.1.0-2 -> 5.1.008-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded glib2 (2.68.1-1 -> 2.68.2-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded harfbuzz (2.8.0-3 -> 2.8.1-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded xorgproto (2021.3-1 -> 2021.4-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded libx11 (1.7.0-4 -> 1.7.1-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded pango (1:1.48.4-1 -> 1:1.48.5-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded zstd (1.4.9-1 -> 1.5.0-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded librsvg (2:2.50.4-1 -> 2:2.50.5-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded gtk-update-icon-cache (1:4.2.0-5 -> 1:4.2.1-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded adwaita-icon-theme (40.0-1 -> 40.1.1-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded alsa-card-profiles (1:0.3.26-1 -> 1:0.3.28-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded protobuf (3.15.8-1 -> 3.16.0-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded libxcrypt (4.4.19-1 -> 4.4.20-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded libldap (2.4.58-1 -> 2.4.58-2)
[2021-05-21T22:23:53+0000] [ALPM] upgraded libtirpc (1.3.1-1 -> 1.3.2-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded libtasn1 (4.16.0-1 -> 4.17.0-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded systemd-libs (247.6-1.0 -> 248.3-2)
[2021-05-21T22:23:53+0000] [ALPM] upgraded libidn2 (2.3.0-1 -> 2.3.1-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded ca-certificates-mozilla (3.64-1 -> 3.65-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded libelf (0.183-3 -> 0.184-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded device-mapper (2.03.11-5 -> 2.03.12-1)
[2021-05-21T22:23:53+0000] [ALPM] upgraded file (5.40-2 -> 5.40-3)
[2021-05-21T22:23:53+0000] [ALPM] upgraded systemd (247.6-1.0 -> 248.3-2)
[2021-05-21T22:23:53+0000] [ALPM-SCRIPTLET] Creating group sgx with gid 963.
[2021-05-21T22:23:53+0000] [ALPM-SCRIPTLET] Creating group systemd-oom with gid 962.
[2021-05-21T22:23:53+0000] [ALPM-SCRIPTLET] Creating user systemd-oom (systemd Userspace OOM Killer) with uid 962 and gid 962.
[2021-05-21T22:23:54+0000] [ALPM] upgraded android-udev (20210302-1 -> 20210501-1)
[2021-05-21T22:23:54+0000] [ALPM] upgraded android-tools (31.0.0-2 -> 31.0.0-3)
[2021-05-21T22:23:54+0000] [ALPM] upgraded aom (3.0.0-2 -> 3.1.0-1)
[2021-05-21T22:23:54+0000] [ALPM] upgraded vulkan-icd-loader (1.2.174-2 -> 1.2.176-1)
[2021-05-21T22:23:54+0000] [ALPM] upgraded libxfixes (5.0.3-4 -> 6.0.0-1)
[2021-05-21T22:23:54+0000] [ALPM] upgraded mesa (21.0.3-2 -> 21.1.1-0)
[2021-05-21T22:23:54+0000] [ALPM] upgraded libepoxy (1.5.5-1 -> 1.5.8-1)
[2021-05-21T22:23:54+0000] [ALPM] upgraded libwacom (1.9-1 -> 1.10-1)
[2021-05-21T22:23:54+0000] [ALPM] upgraded libinput (1.17.1-1 -> 1.17.2-2)
[2021-05-21T22:23:54+0000] [ALPM] upgraded nvidia-utils (460.73.01-1 -> 465.31-1)
[2021-05-21T22:23:54+0000] [ALPM-SCRIPTLET] xorg configuration symlink valid...
[2021-05-21T22:23:54+0000] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m If you run into trouble with CUDA not being available, run nvidia-modprobe first.e[1;0m
[2021-05-21T22:23:54+0000] [ALPM] upgraded libglvnd (1.3.2-2 -> 1.3.3-1)
[2021-05-21T22:23:54+0000] [ALPM] upgraded libxkbcommon (1.2.1-1 -> 1.3.0-1)
[2021-05-21T22:23:54+0000] [ALPM] upgraded libxkbcommon-x11 (1.2.1-1 -> 1.3.0-1)
[2021-05-21T22:23:54+0000] [ALPM] upgraded md4c (0.4.7-1 -> 0.4.8-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded qt5-base (5.15.2+kde+r177-1 -> 5.15.2+kde+r193-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded js78 (78.10.0-1 -> 78.10.1-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded btrfs-progs (5.11.1-1 -> 5.12.1-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded lvm2 (2.03.11-5 -> 2.03.12-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded mpfr (4.1.0-1 -> 4.1.0-2)
[2021-05-21T22:23:55+0000] [ALPM] upgraded nss (3.64-1 -> 3.65-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded solid (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded kcoreaddons (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded kwidgetsaddons (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded kjobwidgets (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded kdbusaddons (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded kconfig (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded kwindowsystem (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded kcrash (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded kglobalaccel (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded kauth (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded kcodecs (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded qt5-wayland (5.15.2+kde+r19-1 -> 5.15.2+kde+r23-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded kguiaddons (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded ki18n (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded kconfigwidgets (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded kitemviews (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded karchive (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded kiconthemes (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded attica (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded kxmlgui (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded kbookmarks (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:55+0000] [ALPM] upgraded libtool (2.4.6+42+gb88cebd5-14 -> 2.4.6+42+gb88cebd5-16)
[2021-05-21T22:23:55+0000] [ALPM] upgraded flac (1.3.3-2 -> 1.3.3-3)
[2021-05-21T22:23:56+0000] [ALPM] upgraded python (3.9.4-1 -> 3.9.5-2)
[2021-05-21T22:23:56+0000] [ALPM] upgraded knotifications (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded kservice (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded kwallet (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded kcompletion (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded sonnet (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded ktextwidgets (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded kded (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded kio (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded kparts (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded kpty (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded kitemmodels (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded ark (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded at-spi2-core (2.40.0-1 -> 2.40.1-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded poppler (21.04.0-2 -> 21.05.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded poppler-qt5 (21.04.0-2 -> 21.05.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded libass (0.15.0-2 -> 0.15.1-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded dav1d (0.8.2-1 -> 0.9.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded libmfx (20.5.1-1 -> 21.1.3-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded srt (1.4.2-1 -> 1.4.3-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded svt-av1 (0.8.6-2 -> 0.8.7-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded ffmpeg (2:4.3.2-6 -> 2:4.4-3)
[2021-05-21T22:23:56+0000] [ALPM] upgraded kfilemetadata (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded kidletime (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded baloo (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded baloo-widgets (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded bluez-qt (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded kpackage (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded kdeclarative (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded bluedevil (1:5.21.4-1 -> 1:5.21.5-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded botan (2.18.0-1 -> 2.18.1-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded knewstuff (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded frameworkintegration (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:56+0000] [ALPM] upgraded kdecoration (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded breeze-icons (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded kwayland (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded breeze (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded bubblewrap (0.4.1-1 -> 0.4.1-2)
[2021-05-21T22:23:58+0000] [ALPM] upgraded oath-toolkit (2.6.6-2 -> 2.6.7-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded ceph-libs (15.2.10-1 -> 15.2.12-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded djvulibre (3.5.28-2 -> 3.5.28-3)
[2021-05-21T22:23:58+0000] [ALPM] upgraded kdnssd (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded smbclient (4.14.3-1 -> 4.14.4-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded syntax-highlighting (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded kio-extras (21.04.0-1 -> 21.04.1-2)
[2021-05-21T22:23:58+0000] [ALPM] upgraded kcmutils (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded kinit (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded kactivities (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded dolphin (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded dolphin-plugins (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded ffmpegthumbs (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded filelight (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded mailcap (2.1.49-1 -> 2.1.53-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded ttf-liberation (2.1.3-1 -> 2.1.4-1)
[2021-05-21T22:23:58+0000] [ALPM] upgraded wayland-protocols (1.20-1 -> 1.21-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded firefox (88.0-1 -> 88.0.1-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded xdg-dbus-proxy (0.1.2-2 -> 0.1.2-3)
[2021-05-21T22:23:59+0000] [ALPM] upgraded libfdk-aac (2.0.1-2 -> 2.0.2-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded pipewire (1:0.3.26-1 -> 1:0.3.28-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded kirigami2 (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded plasma-framework (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded xdg-desktop-portal-kde (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded xdg-desktop-portal (1.8.0-1 -> 1.8.1-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded python-chardet (4.0.0-1 -> 4.0.0-2)
[2021-05-21T22:23:59+0000] [ALPM] upgraded pacman (5.2.2-5 -> 5.2.2-6)
[2021-05-21T22:23:59+0000] [ALPM] upgraded flatpak (1.10.2-1 -> 1.11.1-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded tpm2-tss (3.0.3-1 -> 3.1.0-1)
[2021-05-21T22:23:59+0000] [ALPM] installed fwupd-efi (1.0-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded fwupd (1.5.9-1 -> 1.6.0-3)
[2021-05-21T22:23:59+0000] [ALPM] upgraded game-devices-udev (0.12-1 -> 0.13-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded glslang (11.2.0-3 -> 11.4.0-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded gnustep-base (1.27.0-3 -> 1.28.0-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded gst-plugins-bad-libs (1.18.4-4 -> 1.18.4-7)
[2021-05-21T22:23:59+0000] [ALPM] upgraded mjpegtools (2.2.0beta-1 -> 2.2.0-1)
[2021-05-21T22:23:59+0000] [ALPM] installed imath (3.0.3-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded openexr (2.5.5-1 -> 3.0.3-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded svt-hevc (1.5.0-1 -> 1.5.1-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded mpg123 (1.26.5-1 -> 1.27.2-1)
[2021-05-21T22:23:59+0000] [ALPM] upgraded imagemagick (7.0.11.9-1 -> 7.0.11.13-2)
[2021-05-21T22:23:59+0000] [ALPM] upgraded gst-plugins-bad (1.18.4-4 -> 1.18.4-7)
[2021-05-21T22:24:00+0000] [ALPM] upgraded gvfs (1.48.0+13+gc615cfe1-1 -> 1.48.1-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded gvfs-afc (1.48.0+13+gc615cfe1-1 -> 1.48.1-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded libheif (1.11.0-3 -> 1.12.0-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded gvfs-gphoto2 (1.48.0+13+gc615cfe1-1 -> 1.48.1-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded gvfs-mtp (1.48.0+13+gc615cfe1-1 -> 1.48.1-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded gvfs-nfs (1.48.0+13+gc615cfe1-1 -> 1.48.1-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded gvfs-smb (1.48.0+13+gc615cfe1-1 -> 1.48.1-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded libkipi (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded libkdcraw (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded signon-kwallet-extension (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded qt5-webengine (5.15.3-4 -> 5.15.3-5)
[2021-05-21T22:24:00+0000] [ALPM] upgraded kaccounts-integration (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded purpose (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded gwenview (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded harfbuzz-icu (2.8.0-3 -> 2.8.1-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded hdparm (9.60-1 -> 9.61-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded qpdf (10.3.1-1 -> 10.3.2-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded perl-ffi-checklib (0.27-2 -> 0.28-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded perl-alien-build (2.38-1 -> 2.40-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded libidn (1.36-1 -> 1.37-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded python-six (1.15.0-3 -> 1.16.0-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded python-setuptools (1:56.0.0-1 -> 1:56.1.0-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded hplip (1:3.21.2-1 -> 1:3.21.4-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded iproute2 (5.11.0-1 -> 5.12.0-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded iputils (20200821-1 -> 20210202-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded libkcddb (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded knotifyconfig (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded k3b (1:21.04.0-1 -> 1:21.04.1-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded kaccounts-providers (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded kactivities-stats (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded kactivitymanagerd (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded kamera (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:00+0000] [ALPM] upgraded ktexteditor (5.81.0-1 -> 5.82.0-2)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kate (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kcalc (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kcontacts (1:5.81.0-1 -> 1:5.82.0-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kdesu (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kde-cli-tools (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kde-gtk-config (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kpeople (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kdeconnect (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded libkexiv2 (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kdegraphics-thumbnailers (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kunitconversion (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kemoticons (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kdelibs4support (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kdenetwork-filesharing (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded libksysguard (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kholidays (1:5.81.0-1 -> 1:5.82.0-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded threadweaver (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded krunner (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded milou (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded prison (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kscreenlocker (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kwayland-server (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kwin (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded qqc2-desktop-style (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded plasma-integration (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded libkscreen (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:01+0000] [ALPM] upgraded kquickcharts (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded plasma-workspace (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded kdeplasma-addons (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded kdoctools (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded keditbookmarks (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded kfind (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded systemsettings (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded kgamma5 (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded kget (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded kjs (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded khtml (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded khelpcenter (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded khotkeys (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded kimageformats (5.81.0-1 -> 5.82.0-2)
[2021-05-21T22:24:02+0000] [ALPM] upgraded kinfocenter (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded kmenuedit (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded konsole (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded konversation (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded kpmcore (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded kscreen (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:02+0000] [ALPM] upgraded ksshaskpass (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded ksysguard (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded ksystemlog (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded kwallet-pam (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded kwalletmanager (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded kwayland-integration (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded kwrited (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded less (1:581-1 -> 1:581.2-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded lib32-glibc (2.33-4 -> 2.33-5)
[2021-05-21T22:24:03+0000] [ALPM] upgraded lib32-gcc-libs (10.2.0-6 -> 11.1.0-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded lib32-libidn2 (2.3.0-1 -> 2.3.1-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded lib32-libxcrypt (4.4.19-1 -> 4.4.20-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded lib32-libelf (0.183-3 -> 0.184-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded lib32-vulkan-icd-loader (1.2.174-1 -> 1.2.176-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded lib32-readline (8.1.0-2 -> 8.1.001-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded lib32-mesa (21.0.3-2 -> 21.1.1-0)
[2021-05-21T22:24:03+0000] [ALPM] upgraded perl-http-message (6.29-1 -> 6.32-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded perl-libwww (6.53-1 -> 6.54-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded mhwd-nvidia (460.73.01-1 -> 465.31-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded lib32-nvidia-utils (460.73.01-1 -> 465.31-1)
[2021-05-21T22:24:03+0000] [ALPM-SCRIPTLET] xorg configuration symlink valid...
[2021-05-21T22:24:03+0000] [ALPM] upgraded lib32-libglvnd (1.3.2-1 -> 1.3.3-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded lib32-libva-mesa-driver (21.0.3-2 -> 21.1.1-0)
[2021-05-21T22:24:03+0000] [ALPM] upgraded lib32-sqlite (3.35.4-1 -> 3.35.5-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded lib32-nss (3.64-1 -> 3.65-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded lib32-systemd (247.6-1 -> 248.3-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded libimagequant (2.14.1-1 -> 2.15.1-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded poppler-glib (21.04.0-2 -> 21.05.0-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded libksane (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded libktorrent (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded libmanette (0.2.6-1 -> 0.2.6-2)
[2021-05-21T22:24:03+0000] [ALPM] upgraded libnm (1.30.4-1 -> 1.30.4-3)
[2021-05-21T22:24:03+0000] [ALPM] upgraded spirv-tools (2020.7-1 -> 2021.1-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded shaderc (2020.5-1 -> 2021.0-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded libplacebo (3.104.0-2 -> 3.120.3-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded libqmi (1.28.2-1 -> 1.28.4-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded libsidplayfp (2.1.1-1 -> 2.1.2-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded libupnp (1.14.6-1 -> 1.14.7-1)
[2021-05-21T22:24:03+0000] [ALPM] upgraded libva-mesa-driver (21.0.3-2 -> 21.1.1-0)
[2021-05-21T22:24:04+0000] [ALPM] upgraded linux-firmware (20210426.r1905.fa0efef-1 -> 20210518.r1928.f846292-1)
[2021-05-21T22:24:05+0000] [ALPM] upgraded linux510 (5.10.32-1 -> 5.10.38-1)
[2021-05-21T22:24:05+0000] [ALPM] upgraded linux510-nvidia (460.73.01-1 -> 465.31-2)
[2021-05-21T22:24:11+0000] [ALPM] upgraded manjaro-release (21.0.3-1 -> 21.0.4-1)
[2021-05-21T22:24:11+0000] [ALPM] upgraded manjaro-settings-manager (0.5.6-13 -> 0.5.6-14)
[2021-05-21T22:24:11+0000] [ALPM] upgraded manjaro-settings-manager-kcm (0.5.6-13 -> 0.5.6-14)
[2021-05-21T22:24:11+0000] [ALPM] upgraded manjaro-settings-manager-knotifier (0.5.6-13 -> 0.5.6-14)
[2021-05-21T22:24:11+0000] [ALPM] upgraded ppp (2.4.8-1 -> 2.4.9-1)
[2021-05-21T22:24:11+0000] [ALPM] upgraded modemmanager-qt (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:11+0000] [ALPM] upgraded mpd (0.22.6-4 -> 0.22.7-1)
[2021-05-21T22:24:11+0000] [ALPM] upgraded nano (5.6.1-1 -> 5.7-1)
[2021-05-21T22:24:11+0000] [ALPM] upgraded networkmanager (1.30.4-1 -> 1.30.4-3)
[2021-05-21T22:24:11+0000] [ALPM] upgraded networkmanager-openconnect (1.2.7dev+49+gc512d5a-1 -> 1.2.7dev+65+gca4187c-1)
[2021-05-21T22:24:11+0000] [ALPM] upgraded networkmanager-pptp (1.2.9dev+10+gb41b0d0-3 -> 1.2.9dev+10+gb41b0d0-4)
[2021-05-21T22:24:11+0000] [ALPM] upgraded networkmanager-qt (5.81.0-1 -> 5.82.0-1)
[2021-05-21T22:24:11+0000] [ALPM] upgraded okular (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:11+0000] [ALPM] upgraded oxygen (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:12+0000] [ALPM] upgraded oxygen-icons (1:5.81.0-1 -> 1:5.82.0-1)
[2021-05-21T22:24:12+0000] [ALPM] upgraded vte-common (0.64.0-2 -> 0.64.1-1)
[2021-05-21T22:24:12+0000] [ALPM] upgraded vte3 (0.64.0-2 -> 0.64.1-1)
[2021-05-21T22:24:12+0000] [ALPM] upgraded pamac-common (10.0.6-2 -> 10.1.2-3)
[2021-05-21T22:24:12+0000] [ALPM] upgraded pamac-cli (10.0.6-2 -> 10.1.2-3)
[2021-05-21T22:24:12+0000] [ALPM] upgraded pamac-flatpak-plugin (10.0.6-2 -> 10.1.2-3)
[2021-05-21T22:24:13+0000] [ALPM] installed libhandy (1.2.2-1)
[2021-05-21T22:24:13+0000] [ALPM] upgraded pamac-gtk (10.0.6-2 -> 10.1.2-3)
[2021-05-21T22:24:13+0000] [ALPM] upgraded snapd (2.49.2-1 -> 2.50.1-1)
[2021-05-21T22:24:13+0000] [ALPM] upgraded pamac-snap-plugin (10.0.6-2 -> 10.1.2-3)
[2021-05-21T22:24:13+0000] [ALPM] upgraded partitionmanager (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:13+0000] [ALPM] upgraded polkit-kde-agent (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:14+0000] [ALPM] upgraded plasma-desktop (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:14+0000] [ALPM] upgraded plasma-nm (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:14+0000] [ALPM] upgraded plasma-pa (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:14+0000] [ALPM] upgraded plasma-systemmonitor (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:14+0000] [ALPM] upgraded plasma-workspace-wallpapers (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:14+0000] [ALPM] upgraded powerdevil (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:14+0000] [ALPM] upgraded powertop (2.13-1 -> 2.14-1)
[2021-05-21T22:24:14+0000] [ALPM] upgraded print-manager (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:14+0000] [ALPM] upgraded python-pep517 (0.10.0-1 -> 0.10.0-2)
[2021-05-21T22:24:14+0000] [ALPM] upgraded python-pillow (8.2.0-1 -> 8.2.0-2)
[2021-05-21T22:24:14+0000] [ALPM] upgraded python-pyqt5-sip (12.8.1-3 -> 12.9.0-1)
[2021-05-21T22:24:14+0000] [ALPM] upgraded python-reportlab (3.5.66-1 -> 3.5.67-1)
[2021-05-21T22:24:14+0000] [ALPM] upgraded samba (4.14.3-1 -> 4.14.4-1)
[2021-05-21T22:24:14+0000] [ALPM] upgraded sddm (0.19.0-5 -> 0.19.0-6)
[2021-05-21T22:24:14+0000] [ALPM] upgraded sddm-kcm (5.21.4-1 -> 5.21.5-1)
[2021-05-21T22:24:14+0000] [ALPM] upgraded spectacle (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:14+0000] [ALPM] upgraded sudo (1.9.6.p1-1 -> 1.9.7-1)
[2021-05-21T22:24:14+0000] [ALPM] upgraded systemd-sysvcompat (247.6-1.0 -> 248.3-2)
[2021-05-21T22:24:15+0000] [ALPM] upgraded thunderbird (78.10.0-1 -> 78.10.2-0.3)
[2021-05-21T22:24:15+0000] [ALPM] upgraded unarchiver (1.10.7-3 -> 1.10.7-4)
[2021-05-21T22:24:15+0000] [ALPM] upgraded vi (1:070224-4 -> 1:070224-5)
[2021-05-21T22:24:15+0000] [ALPM] upgraded vlc (3.0.12-4 -> 3.0.14-1)
[2021-05-21T22:24:15+0000] [ALPM] upgraded wpebackend-fdo (1.8.3-1 -> 1.9.92-1)
[2021-05-21T22:24:15+0000] [ALPM] upgraded webkit2gtk (2.32.0-2 -> 2.32.1-1)
[2021-05-21T22:24:15+0000] [ALPM] upgraded yakuake (21.04.0-1 -> 21.04.1-1)
[2021-05-21T22:24:15+0000] [ALPM] upgraded zsh-completions (0.32.0-1 -> 0.33.0-1)
[2021-05-21T22:24:15+0000] [ALPM] transaction completed
[2021-05-21T22:24:18+0000] [ALPM] running '20-systemd-sysusers.hook'...
[2021-05-21T22:24:18+0000] [ALPM] running '30-systemd-catalog.hook'...
[2021-05-21T22:24:18+0000] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-05-21T22:24:18+0000] [ALPM] running '30-systemd-hwdb.hook'...
[2021-05-21T22:24:18+0000] [ALPM] running '30-systemd-sysctl.hook'...
[2021-05-21T22:24:18+0000] [ALPM] running '30-systemd-tmpfiles.hook'...
[2021-05-21T22:24:18+0000] [ALPM] running '30-systemd-udev-reload.hook'...
[2021-05-21T22:24:18+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-21T22:24:18+0000] [ALPM] running '40-update-ca-trust.hook'...
[2021-05-21T22:24:19+0000] [ALPM] running '60-depmod.hook'...
[2021-05-21T22:24:24+0000] [ALPM] running '80-cronie.hook'...
[2021-05-21T22:24:24+0000] [ALPM] running '90-mkinitcpio-install.hook'...
[2021-05-21T22:24:24+0000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
[2021-05-21T22:24:24+0000] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
[2021-05-21T22:24:24+0000] [ALPM-SCRIPTLET] ==> Starting build: 5.10.38-1-MANJARO
[2021-05-21T22:24:24+0000] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-05-21T22:24:24+0000] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-05-21T22:24:24+0000] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-05-21T22:24:25+0000] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-05-21T22:24:25+0000] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-05-21T22:24:25+0000] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-05-21T22:24:25+0000] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-05-21T22:24:25+0000] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-05-21T22:24:25+0000] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-05-21T22:24:25+0000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-05-21T22:24:25+0000] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
[2021-05-21T22:24:26+0000] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-05-21T22:24:26+0000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
[2021-05-21T22:24:26+0000] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
[2021-05-21T22:24:26+0000] [ALPM-SCRIPTLET] ==> Starting build: 5.10.38-1-MANJARO
[2021-05-21T22:24:26+0000] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-05-21T22:24:26+0000] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-05-21T22:24:26+0000] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-05-21T22:24:26+0000] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-05-21T22:24:28+0000] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-05-21T22:24:29+0000] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-05-21T22:24:29+0000] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-05-21T22:24:30+0000] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-05-21T22:24:31+0000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-05-21T22:24:31+0000] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-05-21T22:24:35+0000] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-05-21T22:24:35+0000] [ALPM] running '90-nvidia-utils.hook'...
[2021-05-21T22:24:35+0000] [ALPM] running '99-grub.hook'...
[2021-05-21T22:24:35+0000] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2021-05-21T22:24:36+0000] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2021-05-21T22:24:36+0000] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.10-x86_64
[2021-05-21T22:24:36+0000] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
[2021-05-21T22:24:37+0000] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-05-21T22:24:37+0000] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2021-05-21T22:24:37+0000] [ALPM-SCRIPTLET] It's output will be used to detect bootable binaries on them and create new boot entries.
[2021-05-21T22:24:37+0000] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2021-05-21T22:24:37+0000] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2021-05-21T22:24:37+0000] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2021-05-21T22:24:37+0000] [ALPM-SCRIPTLET] done
[2021-05-21T22:24:37+0000] [ALPM] running 'dbus-reload.hook'...
[2021-05-21T22:24:37+0000] [ALPM] running 'detect-old-perl-modules.hook'...
[2021-05-21T22:24:37+0000] [ALPM] running 'firefox-post.hook'...
[2021-05-21T22:24:37+0000] [ALPM] running 'fontconfig.hook'...
[2021-05-21T22:24:38+0000] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2021-05-21T22:24:38+0000] [ALPM] running 'gio-querymodules.hook'...
[2021-05-21T22:24:38+0000] [ALPM] running 'glib-compile-schemas.hook'...
[2021-05-21T22:24:38+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-05-21T22:24:38+0000] [ALPM] running 'gvfsd.hook'...
[2021-05-21T22:24:38+0000] [ALPM] running 'kernel-alive-post.hook'...
[2021-05-21T22:24:39+0000] [ALPM-SCRIPTLET]
[2021-05-21T22:24:39+0000] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Warning:
[2021-05-21T22:24:39+0000] [ALPM-SCRIPTLET] -> Kernel has been updated. Modules of the current kernel
[2021-05-21T22:24:39+0000] [ALPM-SCRIPTLET] -> have been backed up so you can continue to use your
[2021-05-21T22:24:39+0000] [ALPM-SCRIPTLET] -> computer. However, the new kernel will only work
[2021-05-21T22:24:39+0000] [ALPM-SCRIPTLET] -> at next boot.
[2021-05-21T22:24:39+0000] [ALPM-SCRIPTLET] e[1;0m
[2021-05-21T22:24:39+0000] [ALPM] running 'networkmanager-connectivity.hook'...
[2021-05-21T22:24:39+0000] [ALPM] running 'texinfo-install.hook'...
[2021-05-21T22:24:40+0000] [ALPM] running 'thunderbird-post.hook'...
[2021-05-21T22:24:40+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-05-21T22:24:40+0000] [ALPM] running 'update-mime-database.hook'...
[2021-05-21T22:24:40+0000] [ALPM] running 'update-vlc-plugin-cache.hook'...
[2021-05-21T22:24:40+0000] [ALPM] running 'xorg-mkfontscale.hook'...
[2021-05-21T22:28:28+0000] [PAMAC] synchronizing package lists
[2021-05-21T22:29:08+0000] [ALPM] transaction started
[2021-05-21T22:29:08+0000] [ALPM] installed pkgconf (1.7.3-1)
[2021-05-21T22:29:08+0000] [ALPM] installed jsoncpp (1.9.4-1)
[2021-05-21T22:29:08+0000] [ALPM] installed libuv (1.41.0-1)
[2021-05-21T22:29:08+0000] [ALPM] installed rhash (1.4.1-1)
[2021-05-21T22:29:08+0000] [ALPM] installed cmake (3.20.2-1)
[2021-05-21T22:29:08+0000] [ALPM] installed extra-cmake-modules (5.82.0-2)
[2021-05-21T22:29:08+0000] [ALPM] installed gc (8.0.4-4)
[2021-05-21T22:29:08+0000] [ALPM] installed guile (2.2.7-1)
[2021-05-21T22:29:08+0000] [ALPM] installed make (4.3-3)
[2021-05-21T22:29:09+0000] [ALPM] installed optimus-manager (1.4-1)
[2021-05-21T22:29:09+0000] [ALPM-SCRIPTLET] optimus-manager : enabling optimus-manager.service
[2021-05-21T22:29:09+0000] [ALPM-SCRIPTLET] tput: No value for $TERM and no -T specified
[2021-05-21T22:29:09+0000] [ALPM-SCRIPTLET] Please reboot your computer before using optimus-manager
[2021-05-21T22:29:09+0000] [ALPM] installed m4 (1.4.18-3)
[2021-05-21T22:29:09+0000] [ALPM] installed flex (2.6.4-3)
[2021-05-21T22:29:09+0000] [ALPM] installed fakeroot (1.25.3-2)
[2021-05-21T22:29:09+0000] [ALPM] installed bison (3.7.6-1)
[2021-05-21T22:29:09+0000] [ALPM] installed libmicrohttpd (0.9.73-1)
[2021-05-21T22:29:09+0000] [ALPM] installed elfutils (0.184-1)
[2021-05-21T22:29:09+0000] [ALPM] installed binutils (2.36.1-3)
[2021-05-21T22:29:09+0000] [ALPM] installed libmpc (1.2.1-1)
[2021-05-21T22:29:09+0000] [ALPM] installed gcc (11.1.0-1)
[2021-05-21T22:29:09+0000] [ALPM] installed patch (2.7.6-8)
[2021-05-21T22:29:09+0000] [ALPM] installed autoconf (2.71-1)
[2021-05-21T22:29:09+0000] [ALPM] installed automake (1.16.3-1)
[2021-05-21T22:29:09+0000] [ALPM] transaction completed
[2021-05-21T22:29:09+0000] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-05-21T22:29:10+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-21T22:29:10+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-05-21T22:29:10+0000] [ALPM] running 'texinfo-install.hook'...
[2021-05-21T22:29:10+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-05-21T22:29:10+0000] [ALPM] running 'update-mime-database.hook'...
[2021-05-21T22:29:53+0000] [ALPM] transaction started
[2021-05-21T22:29:53+0000] [ALPM] installed optimus-manager-qt (1.6.3-1)
[2021-05-21T22:29:53+0000] [ALPM] transaction completed
[2021-05-21T22:29:53+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-21T22:29:53+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-05-21T22:29:53+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-05-21T22:33:26+0000] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S qt5-translations firefox-i18n-en-us thunderbird-i18n-en-us hunspell-en_us hyphen-en firefox-i18n-is thunderbird-i18n-is'
[2021-05-21T22:33:30+0000] [ALPM] transaction started
[2021-05-21T22:33:30+0000] [ALPM] installed qt5-translations (5.15.2-1)
[2021-05-21T22:33:30+0000] [ALPM] installed firefox-i18n-en-us (88.0.1-1)
[2021-05-21T22:33:30+0000] [ALPM] installed thunderbird-i18n-en-us (78.10.2-0.3)
[2021-05-21T22:33:30+0000] [ALPM] installed hunspell-en_us (2020.12.07-2)
[2021-05-21T22:33:30+0000] [ALPM] installed hyphen-en (2.8.8-3)
[2021-05-21T22:33:30+0000] [ALPM] installed firefox-i18n-is (88.0.1-1)
[2021-05-21T22:33:30+0000] [ALPM] installed thunderbird-i18n-is (78.10.2-0.3)
[2021-05-21T22:33:30+0000] [ALPM] transaction completed
[2021-05-21T22:33:30+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-21T22:40:22+0000] [PAMAC] synchronizing package lists
[2021-05-21T22:45:29+0000] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S linux512 linux512-nvidia'
[2021-05-21T22:52:16+0000] [ALPM] transaction started
[2021-05-21T22:52:16+0000] [ALPM] installed lib32-pcre (8.44-1)
[2021-05-21T22:52:16+0000] [ALPM] installed lib32-libnl (3.5.0-1)
[2021-05-21T22:52:16+0000] [ALPM] installed lib32-attr (2.5.1-1)
[2021-05-21T22:52:16+0000] [ALPM] installed lib32-libpcap (1.10.0-1)
[2021-05-21T22:52:16+0000] [ALPM] installed libaec (1.0.4-1)
[2021-05-21T22:52:16+0000] [ALPM] installed hdf5 (1.12.0-2)
[2021-05-21T22:52:16+0000] [ALPM] installed openxr (1.0.16-1)
[2021-05-21T22:52:16+0000] [ALPM] installed python-lxml (4.6.3-1)
[2021-05-21T22:52:16+0000] [ALPM] installed python-evdev (1.4.0-1)
[2021-05-21T22:52:16+0000] [ALPM] installed cabextract (1.9.1-2)
[2021-05-21T22:52:16+0000] [ALPM] installed unzip (6.0-14)
[2021-05-21T22:52:16+0000] [ALPM] installed gnome-desktop (1:40.1-1)
[2021-05-21T22:52:17+0000] [ALPM] installed lutris (0.5.8.3-2)
[2021-05-21T22:52:17+0000] [ALPM] installed opencollada (1:1.6.68-2)
[2021-05-21T22:52:17+0000] [ALPM] installed lib32-acl (2.3.1-1)
[2021-05-21T22:52:17+0000] [ALPM] installed netpbm (10.73.33-1)
[2021-05-21T22:52:17+0000] [ALPM] installed gts (0.7.6.121130-2)
[2021-05-21T22:52:17+0000] [ALPM] installed graphviz (2.47.1-1)
[2021-05-21T22:52:17+0000] [ALPM-SCRIPTLET] Warning: Could not load "/usr/lib/graphviz/libgvplugin_gdk.so.6" - It was found, so perhaps one of its dependents was not. Try ldd.
[2021-05-21T22:52:17+0000] [ALPM-SCRIPTLET] Warning: Could not load "/usr/lib/graphviz/libgvplugin_gtk.so.6" - It was found, so perhaps one of its dependents was not. Try ldd.
[2021-05-21T22:52:17+0000] [ALPM] installed libgexiv2 (0.12.2-1)
[2021-05-21T22:52:17+0000] [ALPM] installed libspnav (0.2.3-3)
[2021-05-21T22:52:17+0000] [ALPM] installed babl (0.1.86-1)
[2021-05-21T22:52:17+0000] [ALPM] installed libspiro (1:20200505-2)
[2021-05-21T22:52:17+0000] [ALPM] installed luajit (2.0.5-3)
[2021-05-21T22:52:17+0000] [ALPM] installed lensfun (0.3.95-4)
[2021-05-21T22:52:17+0000] [ALPM] installed metis (5.1.0.p10-2)
[2021-05-21T22:52:17+0000] [ALPM] installed blas (3.9.1-1)
[2021-05-21T22:52:17+0000] [ALPM] installed lapack (3.9.1-1)
[2021-05-21T22:52:17+0000] [ALPM] installed tbb (2020.3-1)
[2021-05-21T22:52:17+0000] [ALPM] installed suitesparse (5.10.0-1)
[2021-05-21T22:52:17+0000] [ALPM] installed gegl (0.4.30-3)
[2021-05-21T22:52:17+0000] [ALPM] installed libmypaint (1.6.1-1)
[2021-05-21T22:52:17+0000] [ALPM] installed libwmf (0.2.12-2)
[2021-05-21T22:52:17+0000] [ALPM] installed mypaint-brushes1 (1.3.1-1)
[2021-05-21T22:52:17+0000] [ALPM] installed gtk2 (2.24.33-2)
[2021-05-21T22:52:17+0000] [ALPM] installed gimp (2.10.24-4)
[2021-05-21T22:52:17+0000] [ALPM] installed c-ares (1.17.1-1)
[2021-05-21T22:52:17+0000] [ALPM] installed alembic (1.8.1-2)
[2021-05-21T22:52:17+0000] [ALPM] installed lib32-glib2 (2.68.2-1)
[2021-05-21T22:52:17+0000] [ALPM] installed lib32-libpng (1.6.37-3)
[2021-05-21T22:52:17+0000] [ALPM] installed lib32-freetype2 (2.10.4-1)
[2021-05-21T22:52:17+0000] [ALPM] installed lib32-harfbuzz (2.8.1-1)
[2021-05-21T22:52:17+0000] [ALPM] installed lib32-libjpeg-turbo (2.1.0-1)
[2021-05-21T22:52:17+0000] [ALPM] installed lib32-libtiff (4.3.0-1)
[2021-05-21T22:52:17+0000] [ALPM] installed lib32-lcms2 (2.12-1)
[2021-05-21T22:52:18+0000] [ALPM] installed ptex (2.3.2-2)
[2021-05-21T22:52:18+0000] [ALPM] installed opensubdiv (3.4.4-1)
[2021-05-21T22:52:18+0000] [ALPM] installed bash-completion (2.11-2)
[2021-05-21T22:52:18+0000] [ALPM] installed lib32-fontconfig (2:2.13.93-4)
[2021-05-21T22:52:18+0000] [ALPM-SCRIPTLET] Rebuilding 32-bit fontconfig cache...
[2021-05-21T22:52:21+0000] [ALPM] installed potrace (1.16-2)
[2021-05-21T22:52:21+0000] [ALPM] installed pybind11 (2.6.2-2)
[2021-05-21T22:52:21+0000] [ALPM] installed embree (3.12.2-1)
[2021-05-21T22:52:21+0000] [ALPM] installed openimagedenoise (1.3.0-1)
[2021-05-21T22:52:21+0000] [ALPM] installed gcc10-libs (1:10.2.0-3)
[2021-05-21T22:52:21+0000] [ALPM] installed gcc10 (1:10.2.0-3)
[2021-05-21T22:52:22+0000] [ALPM] installed opencl-nvidia (465.31-1)
[2021-05-21T22:52:27+0000] [ALPM] installed cuda (11.3.0-2)
[2021-05-21T22:52:27+0000] [ALPM-SCRIPTLET] The cuda binaries are in /opt/cuda/bin
[2021-05-21T22:52:27+0000] [ALPM-SCRIPTLET] The cuda samples are in /opt/cuda/samples
[2021-05-21T22:52:27+0000] [ALPM-SCRIPTLET] The cuda docs are in /opt/cuda/doc
[2021-05-21T22:52:27+0000] [ALPM-SCRIPTLET] You need to relogin in order for the cuda binaries to appear in your PATH
[2021-05-21T22:52:28+0000] [ALPM] installed jemalloc (1:5.2.1-3)
[2021-05-21T22:52:28+0000] [ALPM] installed blosc (1.21.0-1)
[2021-05-21T22:52:28+0000] [ALPM] installed log4cplus (2.0.5-1)
[2021-05-21T22:52:28+0000] [ALPM] installed openvdb (8.0.1-4)
[2021-05-21T22:52:28+0000] [ALPM] installed faudio (21.05-1)
[2021-05-21T22:52:29+0000] [ALPM] installed libgsf (1.14.47-1)
[2021-05-21T22:52:32+0000] [ALPM] installed electron (12.0.7-1)
[2021-05-21T22:52:32+0000] [ALPM] installed cblas (3.9.1-1)
[2021-05-21T22:52:33+0000] [ALPM] installed python-numpy (1.20.2-1)
[2021-05-21T22:52:33+0000] [ALPM] installed tinyxml (2.6.2-7)
[2021-05-21T22:52:33+0000] [ALPM] installed yaml-cpp (0.6.3-2)
[2021-05-21T22:52:33+0000] [ALPM] installed opencolorio1 (1.1.1-2)
[2021-05-21T22:52:33+0000] [ALPM] installed pugixml (1.11.4-1)
[2021-05-21T22:52:33+0000] [ALPM] installed openimageio (2.2.13.0-3)
[2021-05-21T22:52:33+0000] [ALPM] installed compiler-rt (11.1.0-1)
[2021-05-21T22:52:36+0000] [ALPM] installed clang (11.1.0-1)
[2021-05-21T22:52:36+0000] [ALPM] installed openshadinglanguage (1.11.14.0-1)
[2021-05-21T22:52:38+0000] [ALPM] installed blender (17:2.92.0-7)
[2021-05-21T22:52:38+0000] [ALPM] installed lib32-libxrender (0.9.10-2)
[2021-05-21T22:52:38+0000] [ALPM] installed lib32-libxrandr (1.5.2-1)
[2021-05-21T22:52:38+0000] [ALPM] installed lib32-libxcursor (1.2.0-1)
[2021-05-21T22:52:38+0000] [ALPM] installed lib32-gettext (0.21-1)
[2021-05-21T22:52:38+0000] [ALPM] installed lib32-sdl2 (2.0.14-1)
[2021-05-21T22:52:38+0000] [ALPM] installed lib32-faudio (21.05-1)
[2021-05-21T22:52:39+0000] [ALPM] installed wine (6.8-1)
[2021-05-21T22:52:39+0000] [ALPM-SCRIPTLET] Run 'systemctl restart systemd-binfmt' in order to make the wine binfmt available on your system.
[2021-05-21T22:52:39+0000] [ALPM] installed libindicator-gtk3 (12.10.1-9)
[2021-05-21T22:52:39+0000] [ALPM] installed libvips (8.10.6-3)
[2021-05-21T22:52:39+0000] [ALPM] installed lib32-vkd3d (1.2-2)
[2021-05-21T22:52:39+0000] [ALPM] installed ripgrep (12.1.1-1)
[2021-05-21T22:52:39+0000] [ALPM] installed code (1.56.2-2)
[2021-05-21T22:52:39+0000] [ALPM] installed libappindicator-gtk3 (12.10.0.r296-1)
[2021-05-21T22:52:40+0000] [ALPM] installed signal-desktop (5.2.0-1)
[2021-05-21T22:52:41+0000] [ALPM] installed electron11 (11.4.6-1)
[2021-05-21T22:52:41+0000] [ALPM] installed bitwarden (1.26.3-1)
[2021-05-21T22:52:41+0000] [ALPM] installed vkd3d (1.2-1)
[2021-05-21T22:52:41+0000] [ALPM] transaction completed
[2021-05-21T22:52:42+0000] [ALPM] running '30-systemd-binfmt.hook'...
[2021-05-21T22:52:42+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-21T22:52:42+0000] [ALPM] running '40-fontconfig-config.hook'...
[2021-05-21T22:52:42+0000] [ALPM] running 'detect-old-perl-modules.hook'...
[2021-05-21T22:52:42+0000] [ALPM] running 'fontconfig.hook'...
[2021-05-21T22:52:42+0000] [ALPM] running 'fontconfig-32.hook'...
[2021-05-21T22:52:42+0000] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2021-05-21T22:52:42+0000] [ALPM] running 'gtk-query-immodules-2.0.hook'...
[2021-05-21T22:52:42+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-05-21T22:52:42+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-05-21T22:53:44+0000] [ALPM] transaction started
[2021-05-21T22:53:44+0000] [ALPM] installed teams (1.4.00.7556-1)
[2021-05-21T22:53:45+0000] [ALPM] installed binance (1.16.2-2)
[2021-05-21T22:53:46+0000] [ALPM] transaction completed
[2021-05-21T22:53:46+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-21T22:53:46+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-05-21T22:53:47+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-05-21T22:54:39+0000] [PACMAN] Running 'pacman -S libreoffice-fresh'
[2021-05-21T22:56:01+0000] [ALPM] transaction started
[2021-05-21T22:56:01+0000] [ALPM] installed librevenge (0.0.4-3)
[2021-05-21T22:56:01+0000] [ALPM] installed libwpd (0.10.3-2)
[2021-05-21T22:56:01+0000] [ALPM] installed libwps (0.4.12-1)
[2021-05-21T22:56:01+0000] [ALPM] installed rasqal (1:0.9.33-4)
[2021-05-21T22:56:01+0000] [ALPM] installed redland (1:1.0.17-8)
[2021-05-21T22:56:01+0000] [ALPM] installed lpsolve (5.5.2.11-1)
[2021-05-21T22:56:01+0000] [ALPM] installed libwpg (0.3.3-2)
[2021-05-21T22:56:01+0000] [ALPM] installed libvisio (0.1.7-5)
[2021-05-21T22:56:01+0000] [ALPM] installed liblangtag (0.6.3-2)
[2021-05-21T22:56:01+0000] [ALPM] installed libetonyek (0.1.9-2)
[2021-05-21T22:56:01+0000] [ALPM] installed libodfgen (0.1.8-1)
[2021-05-21T22:56:01+0000] [ALPM] installed libcdr (0.1.7-2)
[2021-05-21T22:56:02+0000] [ALPM] installed libmspub (0.1.4-10)
[2021-05-21T22:56:02+0000] [ALPM] installed clucene (2.3.3.4-11)
[2021-05-21T22:56:02+0000] [ALPM] installed libpagemaker (0.0.4-2)
[2021-05-21T22:56:02+0000] [ALPM] installed libabw (0.1.3-2)
[2021-05-21T22:56:02+0000] [ALPM] installed libmwaw (0.3.19-1)
[2021-05-21T22:56:02+0000] [ALPM] installed libe-book (0.1.3-9)
[2021-05-21T22:56:02+0000] [ALPM] installed libexttextcat (3.4.5-2)
[2021-05-21T22:56:02+0000] [ALPM] installed libcmis (0.5.2-7)
[2021-05-21T22:56:02+0000] [ALPM] installed libixion (0.16.1-5)
[2021-05-21T22:56:02+0000] [ALPM] installed liborcus (0.16.1-5)
[2021-05-21T22:56:02+0000] [ALPM] installed libzmf (0.0.2-10)
[2021-05-21T22:56:02+0000] [ALPM] installed libatomic_ops (7.6.10-2)
[2021-05-21T22:56:02+0000] [ALPM] installed libnumbertext (1.0.7-1)
[2021-05-21T22:56:02+0000] [ALPM] installed libfreehand (0.1.2-3)
[2021-05-21T22:56:02+0000] [ALPM] installed libstaroffice (0.0.7-1)
[2021-05-21T22:56:02+0000] [ALPM] installed libepubgen (0.1.1-2)
[2021-05-21T22:56:02+0000] [ALPM] installed libqxp (0.0.2-6)
[2021-05-21T22:56:02+0000] [ALPM] installed box2d (2.4.1-1)
[2021-05-21T22:56:04+0000] [ALPM] installed libreoffice-fresh (7.1.3-1)
[2021-05-21T22:56:05+0000] [ALPM] transaction completed
[2021-05-21T22:56:05+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-21T22:56:05+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-05-21T22:56:05+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-05-21T22:56:05+0000] [ALPM] running 'update-mime-database.hook'...
[2021-05-21T22:57:51+0000] [PAMAC] synchronizing package lists
[2021-05-21T22:58:31+0000] [ALPM] transaction started
[2021-05-21T22:58:31+0000] [ALPM] removed yakuake (21.04.1-1)
[2021-05-21T22:58:31+0000] [ALPM] installed mbedtls (2.25.0-1)
[2021-05-21T22:58:31+0000] [ALPM] installed libebur128 (1.2.6-1)
[2021-05-21T22:58:31+0000] [ALPM] installed mlt6 (6.26.1-4)
[2021-05-21T22:58:31+0000] [ALPM] installed recordmydesktop (0.4.0-1)
[2021-05-21T22:58:31+0000] [ALPM] installed obs-studio (26.1.2-2)
[2021-05-21T22:58:31+0000] [ALPM] installed qt5-networkauth (5.15.2-1)
[2021-05-21T22:58:31+0000] [ALPM] installed rttr (0.9.6-3)
[2021-05-21T22:58:31+0000] [ALPM] installed gavl (1.4.0-5)
[2021-05-21T22:58:31+0000] [ALPM] installed frei0r-plugins (1.7.0-1)
[2021-05-21T22:58:31+0000] [ALPM] installed kdenlive (21.04.1-1)
[2021-05-21T22:58:31+0000] [ALPM] installed java-runtime-common (3-3)
[2021-05-21T22:58:31+0000] [ALPM-SCRIPTLET] For the complete set of Java binaries to be available in your PATH,
[2021-05-21T22:58:31+0000] [ALPM-SCRIPTLET] you need to re-login or source /etc/profile.d/jre.sh
[2021-05-21T22:58:31+0000] [ALPM-SCRIPTLET] Please note that this package does not support forcing JAVA_HOME as former package java-common did
[2021-05-21T22:58:31+0000] [ALPM] installed libnet (1:1.1.6-1)
[2021-05-21T22:58:32+0000] [ALPM] installed jre-openjdk-headless (15.0.2.u7-1)
[2021-05-21T22:58:32+0000] [ALPM] installed jre-openjdk (15.0.2.u7-1)
[2021-05-21T22:58:32+0000] [ALPM-SCRIPTLET] when you use a non-reparenting window manager,
[2021-05-21T22:58:32+0000] [ALPM-SCRIPTLET] set _JAVA_AWT_WM_NONREPARENTING=1 in /etc/profile.d/jre.sh
[2021-05-21T22:58:32+0000] [ALPM] installed opencv (4.5.2-4)
[2021-05-21T22:58:32+0000] [ALPM] transaction completed
[2021-05-21T22:58:32+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-21T22:58:32+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-05-21T22:58:32+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-05-21T22:58:32+0000] [ALPM] running 'update-mime-database.hook'...
[2021-05-21T22:59:55+0000] [ALPM] transaction started
[2021-05-21T22:59:55+0000] [ALPM] installed olive (0.1.2-2)
[2021-05-21T22:59:55+0000] [ALPM] installed coinomi-wallet-bin (1.3.0-3)
[2021-05-21T22:59:55+0000] [ALPM] transaction completed
[2021-05-21T22:59:55+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-21T22:59:55+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-05-21T22:59:55+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-05-21T22:59:55+0000] [ALPM] running 'update-mime-database.hook'...
[2021-05-21T23:13:48+0000] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S linux512 linux512-nvidia'
[2021-05-21T23:15:16+0000] [ALPM] transaction started
[2021-05-21T23:15:16+0000] [ALPM] installed linux512 (5.12.5-1)
[2021-05-21T23:15:16+0000] [ALPM] installed linux512-nvidia (465.31-2)
[2021-05-21T23:15:22+0000] [ALPM-SCRIPTLET] In order to use nvidia module, reboot the system.
[2021-05-21T23:15:22+0000] [ALPM] transaction completed
[2021-05-21T23:15:22+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-21T23:15:22+0000] [ALPM] running '60-depmod.hook'...
[2021-05-21T23:15:28+0000] [ALPM] running '90-mkinitcpio-install.hook'...
[2021-05-21T23:15:28+0000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux512.preset: 'default'
[2021-05-21T23:15:28+0000] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.12-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.12-x86_64.img
[2021-05-21T23:15:28+0000] [ALPM-SCRIPTLET] ==> Starting build: 5.12.5-1-MANJARO
[2021-05-21T23:15:28+0000] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-05-21T23:15:28+0000] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-05-21T23:15:28+0000] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-05-21T23:15:28+0000] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-05-21T23:15:28+0000] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-05-21T23:15:29+0000] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-05-21T23:15:29+0000] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-05-21T23:15:29+0000] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-05-21T23:15:29+0000] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-05-21T23:15:29+0000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-05-21T23:15:29+0000] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.12-x86_64.img
[2021-05-21T23:15:30+0000] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-05-21T23:15:30+0000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux512.preset: 'fallback'
[2021-05-21T23:15:30+0000] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.12-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.12-x86_64-fallback.img -S autodetect
[2021-05-21T23:15:30+0000] [ALPM-SCRIPTLET] ==> Starting build: 5.12.5-1-MANJARO
[2021-05-21T23:15:30+0000] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-05-21T23:15:30+0000] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-05-21T23:15:30+0000] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-05-21T23:15:30+0000] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-05-21T23:15:32+0000] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-05-21T23:15:33+0000] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-05-21T23:15:33+0000] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-05-21T23:15:34+0000] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-05-21T23:15:35+0000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-05-21T23:15:35+0000] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.12-x86_64-fallback.img
[2021-05-21T23:15:39+0000] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-05-21T23:15:39+0000] [ALPM] running '90-nvidia-utils.hook'...
[2021-05-21T23:15:39+0000] [ALPM] running '99-grub.hook'...
[2021-05-21T23:15:39+0000] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2021-05-21T23:15:39+0000] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2021-05-21T23:15:40+0000] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.12-x86_64
[2021-05-21T23:15:40+0000] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.12-x86_64.img
[2021-05-21T23:15:40+0000] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.12-x86_64-fallback.img
[2021-05-21T23:15:40+0000] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.10-x86_64
[2021-05-21T23:15:40+0000] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
[2021-05-21T23:15:40+0000] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-05-21T23:15:40+0000] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2021-05-21T23:15:40+0000] [ALPM-SCRIPTLET] It's output will be used to detect bootable binaries on them and create new boot entries.
[2021-05-21T23:15:44+0000] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2021-05-21T23:15:44+0000] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2021-05-21T23:15:44+0000] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2021-05-21T23:15:44+0000] [ALPM-SCRIPTLET] done
[2021-05-22T00:31:45+0000] [ALPM] transaction started
[2021-05-22T00:31:45+0000] [ALPM] installed google-chrome (90.0.4430.212-1)
[2021-05-22T00:31:46+0000] [ALPM-SCRIPTLET] tput: No value for $TERM and no -T specified
[2021-05-22T00:31:46+0000] [ALPM-SCRIPTLET] ==> NOTE: Custom flags should be put directly in: ~/.config/chrome-flags.conf
[2021-05-22T00:31:46+0000] [ALPM-SCRIPTLET] ==> NOTE: The launcher is called: 'google-chrome-stable'
[2021-05-22T00:31:46+0000] [ALPM] transaction completed
[2021-05-22T00:31:46+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-22T00:31:46+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-05-22T00:31:46+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-05-22T10:30:47+0000] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S gimp-help-en libreoffice-fresh-is'
[2021-05-22T10:31:13+0000] [ALPM] transaction started
[2021-05-22T10:31:13+0000] [ALPM] installed gimp-help-en (2.10.0-3)
[2021-05-22T10:31:13+0000] [ALPM] installed libreoffice-fresh-is (7.1.3-1)
[2021-05-22T10:31:13+0000] [ALPM] transaction completed
[2021-05-22T10:31:13+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-22T21:18:11+0000] [PAMAC] synchronizing package lists
[2021-05-22T21:18:22+0000] [ALPM] transaction started
[2021-05-22T21:18:22+0000] [ALPM] installed godot (3.3.1-1)
[2021-05-22T21:18:22+0000] [ALPM] transaction completed
[2021-05-22T21:18:22+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-22T21:18:22+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-05-23T21:30:07+0000] [PAMAC] synchronizing package lists
[2021-05-23T21:30:53+0000] [ALPM] transaction started
[2021-05-23T21:30:53+0000] [ALPM] installed t1lib (5.1.2-8)
[2021-05-23T21:30:53+0000] [ALPM] installed libsigsegv (2.13-1)
[2021-05-23T21:30:53+0000] [ALPM] installed libsynctex (2020.54586-14)
[2021-05-23T21:30:53+0000] [ALPM] installed texlive-bin (2020.54586-14)
[2021-05-23T21:30:55+0000] [ALPM] installed texlive-core (2020.57066-2)
[2021-05-23T21:30:55+0000] [ALPM-SCRIPTLET] >>> updmap custom entries should go into /etc/texmf/web2c/updmap-local.cfg
[2021-05-23T21:30:55+0000] [ALPM-SCRIPTLET] >>> fmtutil custom entries should go into /etc/texmf/web2c/fmtutil-local.cnf
[2021-05-23T21:30:55+0000] [ALPM-SCRIPTLET] NB: To setup ConTeXt and the lua(la)tex font db,
[2021-05-23T21:30:55+0000] [ALPM-SCRIPTLET] see http://wiki.archlinux.org/index.php/TeX_Live
[2021-05-23T21:30:56+0000] [ALPM] installed texlive-latexextra (2020.57067-1)
[2021-05-23T21:30:56+0000] [ALPM] installed libmythes (1:1.2.4-4)
[2021-05-23T21:30:56+0000] [ALPM] installed libsigc++ (2.10.7-1)
[2021-05-23T21:30:56+0000] [ALPM] installed ed (1.17-1)
[2021-05-23T21:30:56+0000] [ALPM] installed rcs (5.10.0-1)
[2021-05-23T21:30:56+0000] [ALPM] installed ttf-opensans (1.101-2)
[2021-05-23T21:30:56+0000] [ALPM] installed glibmm (2.66.1-1)
[2021-05-23T21:30:56+0000] [ALPM] installed telegram-desktop (2.7.4-2)
[2021-05-23T21:30:56+0000] [ALPM] installed lyx (2.3.6.1-1)
[2021-05-23T21:30:56+0000] [ALPM] transaction completed
[2021-05-23T21:30:56+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-23T21:30:57+0000] [ALPM] running 'fontconfig.hook'...
[2021-05-23T21:30:57+0000] [ALPM] running 'fontconfig-32.hook'...
[2021-05-23T21:30:57+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-05-23T21:30:57+0000] [ALPM] running 'mktexlsr.hook'...
[2021-05-23T21:30:57+0000] [ALPM] running 'texinfo-install.hook'...
[2021-05-23T21:30:57+0000] [ALPM] running 'texlive-fmtutil.hook'...
[2021-05-23T21:31:16+0000] [ALPM] running 'texlive-updmap.hook'...
[2021-05-23T21:31:17+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-05-23T21:31:17+0000] [ALPM] running 'xorg-mkfontscale.hook'...
[2021-05-25T12:27:27+0000] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S mythes-en'
[2021-05-25T12:27:29+0000] [ALPM] transaction started
[2021-05-25T12:27:29+0000] [ALPM] installed mythes-en (20060306-5)
[2021-05-25T12:27:29+0000] [ALPM] transaction completed
[2021-05-25T12:27:29+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-25T12:28:59+0000] [PAMAC] synchronizing package lists
[2021-05-25T12:29:20+0000] [ALPM] transaction started
[2021-05-25T12:29:20+0000] [ALPM] upgraded binance (1.16.2-2 -> 1.17.0-1)
[2021-05-25T12:29:20+0000] [ALPM] transaction completed
[2021-05-25T12:29:20+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-25T12:29:20+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-05-25T12:29:20+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-05-25T20:17:34+0000] [PAMAC] synchronizing package lists
[2021-05-25T20:17:50+0000] [ALPM] transaction started
[2021-05-25T20:17:50+0000] [ALPM] upgraded google-chrome (90.0.4430.212-1 -> 91.0.4472.77-1)
[2021-05-25T20:17:50+0000] [ALPM-SCRIPTLET] tput: No value for $TERM and no -T specified
[2021-05-25T20:17:50+0000] [ALPM-SCRIPTLET] ==> NOTE: Custom flags should be put directly in: ~/.config/chrome-flags.conf
[2021-05-25T20:17:50+0000] [ALPM-SCRIPTLET] ==> NOTE: The launcher is called: 'google-chrome-stable'
[2021-05-25T20:17:50+0000] [ALPM] transaction completed
[2021-05-25T20:17:50+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-25T20:17:50+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-05-25T20:17:50+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-05-27T23:04:23+0000] [PACMAN] Running 'pacman -Syu'
[2021-05-27T23:04:23+0000] [PACMAN] synchronizing package lists
[2021-05-27T23:04:27+0000] [PACMAN] starting full system upgrade
[2021-05-31T19:52:19+0000] [PAMAC] synchronizing package lists
[2021-05-31T19:52:21+0000] [ALPM] transaction started
[2021-05-31T19:52:21+0000] [ALPM] upgraded manjaro-system (20210412-1 -> 20210523-1)
[2021-05-31T19:52:21+0000] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Checking for 'os-prober' setup ...e[1;0m
[2021-05-31T19:52:21+0000] [ALPM-SCRIPTLET] 'os-prober' was already enabled by the user.
[2021-05-31T19:52:21+0000] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Checking if graphic drivers need an update ...e[1;0m
[2021-05-31T19:52:21+0000] [ALPM] transaction completed
[2021-05-31T19:52:21+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-31T19:56:29+0000] [ALPM] running '60-mkinitcpio-remove.hook'...
[2021-05-31T19:56:29+0000] [ALPM] running 'kernel-alive-pre.hook'...
[2021-05-31T19:56:30+0000] [ALPM] running 'thunderbird-pre.hook'...
[2021-05-31T19:56:30+0000] [ALPM] transaction started
[2021-05-31T19:56:30+0000] [ALPM] upgraded expat (2.3.0-1 -> 2.4.1-1)
[2021-05-31T19:56:30+0000] [ALPM] upgraded bashrc-manjaro (5.1.008-1 -> 5.1.008-3)
[2021-05-31T19:56:30+0000] [ALPM] upgraded bash (5.1.008-1 -> 5.1.008-3)
[2021-05-31T19:56:30+0000] [ALPM] upgraded libldap (2.4.58-2 -> 2.4.58-3)
[2021-05-31T19:56:30+0000] [ALPM] upgraded python (3.9.5-2 -> 3.9.5-3)
[2021-05-31T19:56:30+0000] [ALPM] upgraded apparmor (3.0.1-1 -> 3.0.1-3)
[2021-05-31T19:56:30+0000] [ALPM] upgraded nspr (4.30-1 -> 4.31-1)
[2021-05-31T19:56:30+0000] [ALPM] upgraded libcap (2.49-1 -> 2.50-1)
[2021-05-31T19:56:30+0000] [ALPM] upgraded lz4 (1:1.9.3-1 -> 1:1.9.3-2)
[2021-05-31T19:56:30+0000] [ALPM] upgraded nss (3.65-1 -> 3.66-1)
[2021-05-31T19:56:30+0000] [ALPM] upgraded librsvg (2:2.50.5-1 -> 2:2.50.6-1)
[2021-05-31T19:56:30+0000] [ALPM] upgraded libdrm (2.4.105-1 -> 2.4.106-1)
[2021-05-31T19:56:30+0000] [ALPM] upgraded libmfx (21.1.3-1 -> 21.1.3-2)
[2021-05-31T19:56:30+0000] [ALPM] upgraded cryptsetup (2.3.5-4 -> 2.3.6-1)
[2021-05-31T19:56:30+0000] [ALPM] upgraded kmod (28-1 -> 29-1)
[2021-05-31T19:56:30+0000] [ALPM] upgraded pcre2 (10.36-1 -> 10.37-1)
[2021-05-31T19:56:31+0000] [ALPM] upgraded file (5.40-3 -> 5.40-5)
[2021-05-31T19:56:31+0000] [ALPM] upgraded ca-certificates-mozilla (3.65-1 -> 3.66-1)
[2021-05-31T19:56:31+0000] [ALPM] upgraded curl (7.76.1-1 -> 7.77.0-1)
[2021-05-31T19:56:31+0000] [ALPM] upgraded libnl (3.5.0-2 -> 3.5.0-3)
[2021-05-31T19:56:31+0000] [ALPM] upgraded mesa (21.1.1-0 -> 21.1.1-1)
[2021-05-31T19:56:31+0000] [ALPM] upgraded libinput (1.17.2-2 -> 1.17.3-1)
[2021-05-31T19:56:31+0000] [ALPM] upgraded gsettings-desktop-schemas (40.0-2 -> 40.0-3)
[2021-05-31T19:56:31+0000] [ALPM] upgraded libproxy (0.4.17-1 -> 0.4.17-2)
[2021-05-31T19:56:31+0000] [ALPM] upgraded electron11 (11.4.6-1 -> 11.4.7-1)
[2021-05-31T19:56:31+0000] [ALPM] upgraded bitwarden (1.26.3-1 -> 1.26.4-1)
[2021-05-31T19:56:32+0000] [ALPM] upgraded breath2-icon-themes (1.0.11-1 -> 1.0.13-1)
[2021-05-31T19:56:32+0000] [ALPM] upgraded breath2-wallpaper (1.0.11-1 -> 1.0.13-1)
[2021-05-31T19:56:33+0000] [ALPM] upgraded cmake (3.20.2-1 -> 3.20.3-1)
[2021-05-31T19:56:33+0000] [ALPM] upgraded dhclient (4.4.2-2 -> 4.4.2.P1-1)
[2021-05-31T19:56:33+0000] [ALPM] upgraded electron (12.0.7-1 -> 12.0.9-1)
[2021-05-31T19:56:33+0000] [ALPM] upgraded foomatic-db (3:20210222-1 -> 3:20210528-1)
[2021-05-31T19:56:33+0000] [ALPM] upgraded libsigc++ (2.10.7-1 -> 2.10.7-2)
[2021-05-31T19:56:33+0000] [ALPM] upgraded glibmm (2.66.1-1 -> 2.66.1-2)
[2021-05-31T19:56:33+0000] [ALPM] upgraded godot (3.3.1-1 -> 3.3.2-1)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl (5.32.1-1 -> 5.34.0-1)
[2021-05-31T19:56:34+0000] [ALPM] upgraded graphviz (2.47.1-1 -> 2.47.2-1)
[2021-05-31T19:56:34+0000] [ALPM] upgraded gupnp (1.2.4-1 -> 1.2.6-1)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-encode-locale (1.05-7 -> 1.05-8)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-timedate (2.33-2 -> 2.33-3)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-http-date (6.05-3 -> 6.05-4)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-file-listing (6.14-1 -> 6.14-2)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-html-tagset (3.20-10 -> 3.20-11)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-clone (0.45-2 -> 0.45-3)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-io-html (1.004-1 -> 1.004-2)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-lwp-mediatypes (6.02-8 -> 6.02-9)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-uri (5.09-1 -> 5.09-2)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-http-message (6.32-1 -> 6.32-2)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-html-parser (3.76-1 -> 3.76-2)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-http-cookies (6.10-1 -> 6.10-2)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-http-daemon (6.06-2 -> 6.06-3)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-http-negotiate (6.01-8 -> 6.01-9)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-net-http (6.21-1 -> 6.21-2)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-try-tiny (0.30-5 -> 0.30-6)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-www-robotrules (6.02-8 -> 6.02-9)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-libwww (6.54-1 -> 6.54-2)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-xml-parser (2.46-2 -> 2.46-3)
[2021-05-31T19:56:34+0000] [ALPM] upgraded perl-xml-writer (0.625-6 -> 0.625-7)
[2021-05-31T19:56:34+0000] [ALPM] upgraded hwinfo (21.73-1 -> 21.74-1)
[2021-05-31T19:56:34+0000] [ALPM] upgraded imagemagick (7.0.11.13-2 -> 7.0.11.13-3)
[2021-05-31T19:56:34+0000] [ALPM] upgraded qt5-base (5.15.2+kde+r193-1 -> 5.15.2+kde+r196-1)
[2021-05-31T19:56:34+0000] [ALPM] upgraded kcolorpicker (0.1.5-1 -> 0.1.6-1)
[2021-05-31T19:56:34+0000] [ALPM] upgraded pulseaudio-qt (1.2-2 -> 1.3-1)
[2021-05-31T19:56:34+0000] [ALPM] upgraded qt5-declarative (5.15.2+kde+r24-1 -> 5.15.2+kde+r26-1)
[2021-05-31T19:56:34+0000] [ALPM] upgraded kdeconnect (21.04.1-1 -> 21.04.1-2)
[2021-05-31T19:56:34+0000] [ALPM] upgraded kimageannotator (0.4.2-1 -> 0.5.0-2)
[2021-05-31T19:56:34+0000] [ALPM] upgraded lib32-curl (7.76.1-1 -> 7.77.0-1)
[2021-05-31T19:56:34+0000] [ALPM] upgraded lib32-expat (2.3.0-2 -> 2.4.1-1)
[2021-05-31T19:56:34+0000] [ALPM] upgraded lib32-libcap (2.49-1 -> 2.50-1)
[2021-05-31T19:56:34+0000] [ALPM] upgraded lib32-libdrm (2.4.105-1 -> 2.4.106-1)
[2021-05-31T19:56:34+0000] [ALPM] upgraded lib32-libx11 (1.7.0-1 -> 1.7.1-1)
[2021-05-31T19:56:35+0000] [ALPM] upgraded lib32-libva-mesa-driver (21.1.1-0 -> 21.1.1-1)
[2021-05-31T19:56:35+0000] [ALPM] upgraded python-urllib3 (1.26.4-1 -> 1.26.5-1)
[2021-05-31T19:56:35+0000] [ALPM] upgraded lib32-mesa (21.1.1-0 -> 21.1.1-1)
[2021-05-31T19:56:35+0000] [ALPM] upgraded lib32-nspr (4.30-1 -> 4.31-1)
[2021-05-31T19:56:35+0000] [ALPM] upgraded lib32-nss (3.65-1 -> 3.66-1)
[2021-05-31T19:56:35+0000] [ALPM] upgraded libcaca (0.99.beta19-4 -> 0.99.beta19-5)
[2021-05-31T19:56:35+0000] [ALPM] upgraded libwpd (0.10.3-2 -> 0.10.3-3)
[2021-05-31T19:56:35+0000] [ALPM] upgraded libetonyek (0.1.9-2 -> 0.1.10-1)
[2021-05-31T19:56:35+0000] [ALPM] upgraded libndp (1.7-2 -> 1.8-1)
[2021-05-31T19:56:35+0000] [ALPM] upgraded liborcus (0.16.1-5 -> 0.16.1-6)
[2021-05-31T19:56:35+0000] [ALPM] upgraded libqalculate (3.18.0-2 -> 3.19.0-1)
[2021-05-31T19:56:35+0000] [ALPM] upgraded libsynctex (2020.54586-14 -> 2021.58686-3)
[2021-05-31T19:56:35+0000] [ALPM] upgraded libva-mesa-driver (21.1.1-0 -> 21.1.1-1)
[2021-05-31T19:56:36+0000] [ALPM] upgraded linux510 (5.10.38-1 -> 5.10.41-1)
[2021-05-31T19:56:36+0000] [ALPM] upgraded linux510-nvidia (465.31-2 -> 465.31-5)
[2021-05-31T19:56:42+0000] [ALPM] upgraded linux512 (5.12.5-1 -> 5.12.8-1)
[2021-05-31T19:56:42+0000] [ALPM] upgraded linux512-nvidia (465.31-2 -> 465.31-6)
[2021-05-31T19:56:48+0000] [ALPM] upgraded log4cplus (2.0.5-1 -> 2.0.6-1)
[2021-05-31T19:56:48+0000] [ALPM] upgraded mpd (0.22.7-1 -> 0.22.8-1)
[2021-05-31T19:56:48+0000] [ALPM] upgraded net-snmp (5.9-3 -> 5.9.1-1)
[2021-05-31T19:56:48+0000] [ALPM] upgraded openimagedenoise (1.3.0-1 -> 1.4.0-1)
[2021-05-31T19:56:48+0000] [ALPM] upgraded openimageio (2.2.13.0-3 -> 2.2.14.0-1)
[2021-05-31T19:56:48+0000] [ALPM] upgraded perl-error (0.17029-2 -> 0.17029-3)
[2021-05-31T19:56:48+0000] [ALPM] upgraded perl-mailtools (2.21-4 -> 2.21-5)
[2021-05-31T19:56:49+0000] [ALPM] upgraded pamac-common (10.1.2-3 -> 10.1.2-4)
[2021-05-31T19:56:49+0000] [ALPM] upgraded pamac-cli (10.1.2-3 -> 10.1.2-4)
[2021-05-31T19:56:49+0000] [ALPM] upgraded pamac-flatpak-plugin (10.1.2-3 -> 10.1.2-4)
[2021-05-31T19:56:49+0000] [ALPM] upgraded pamac-gtk (10.1.2-3 -> 10.1.2-4)
[2021-05-31T19:56:50+0000] [ALPM] upgraded snapd (2.50.1-1 -> 2.51-1)
[2021-05-31T19:56:50+0000] [ALPM] upgraded pamac-snap-plugin (10.1.2-3 -> 10.1.2-4)
[2021-05-31T19:56:50+0000] [ALPM] upgraded perl-capture-tiny (0.48-4 -> 0.48-5)
[2021-05-31T19:56:50+0000] [ALPM] upgraded perl-ffi-checklib (0.28-1 -> 0.28-2)
[2021-05-31T19:56:50+0000] [ALPM] upgraded perl-file-which (1.24-1 -> 1.24-2)
[2021-05-31T19:56:50+0000] [ALPM] upgraded perl-path-tiny (0.118-1 -> 0.118-2)
[2021-05-31T19:56:50+0000] [ALPM] upgraded perl-alien-build (2.40-1 -> 2.40-3)
[2021-05-31T19:56:50+0000] [ALPM] upgraded perl-alien-libxml2 (0.17-1 -> 0.17-2)
[2021-05-31T19:56:50+0000] [ALPM] upgraded perl-dbi (1.643-2 -> 1.643-3)
[2021-05-31T19:56:50+0000] [ALPM] upgraded perl-ipc-system-simple (1.30-2 -> 1.30-3)
[2021-05-31T19:56:50+0000] [ALPM] upgraded perl-file-basedir (0.08-5 -> 0.08-6)
[2021-05-31T19:56:50+0000] [ALPM] upgraded perl-file-desktopentry (0.22-7 -> 0.22-8)
[2021-05-31T19:56:50+0000] [ALPM] upgraded perl-file-mimeinfo (0.30-1 -> 0.30-2)
[2021-05-31T19:56:50+0000] [ALPM] upgraded perl-parse-yapp (1.21-3 -> 1.21-4)
[2021-05-31T19:56:50+0000] [ALPM] upgraded perl-xml-libxml (2.0207-1 -> 2.0207-2)
[2021-05-31T19:56:50+0000] [ALPM] upgraded plasma5-themes-breath2 (1.0.11-1 -> 1.0.13-1)
[2021-05-31T19:56:50+0000] [ALPM] upgraded python-numpy (1.20.2-1 -> 1.20.3-1)
[2021-05-31T19:56:50+0000] [ALPM] upgraded python-setuptools (1:56.1.0-1 -> 1:56.2.0-1)
[2021-05-31T19:56:50+0000] [ALPM] upgraded sddm-breath2-theme (1.0.11-1 -> 1.0.13-1)
[2021-05-31T19:56:51+0000] [ALPM] upgraded signal-desktop (5.2.0-1 -> 5.3.0-1)
[2021-05-31T19:56:51+0000] [ALPM] upgraded suitesparse (5.10.0-1 -> 5.10.1-1)
[2021-05-31T19:56:51+0000] [ALPM] upgraded texlive-bin (2020.54586-14 -> 2021.58686-3)
[2021-05-31T19:56:53+0000] [ALPM] upgraded texlive-core (2020.57066-2 -> 2021.58710-2)
[2021-05-31T19:56:53+0000] [ALPM-SCRIPTLET] >>> updmap custom entries should go into /etc/texmf/web2c/updmap-local.cfg
[2021-05-31T19:56:53+0000] [ALPM-SCRIPTLET] >>> fmtutil custom entries should go into /etc/texmf/web2c/fmtutil-local.cnf
[2021-05-31T19:56:53+0000] [ALPM] upgraded texlive-latexextra (2020.57067-1 -> 2021.58668-2)
[2021-05-31T19:56:54+0000] [ALPM] upgraded thunderbird (78.10.2-0.3 -> 78.10.2-1)
[2021-05-31T19:56:54+0000] [ALPM] upgraded thunderbird-i18n-en-us (78.10.2-0.3 -> 78.10.2-1)
[2021-05-31T19:56:54+0000] [ALPM] upgraded thunderbird-i18n-is (78.10.2-0.3 -> 78.10.2-1)
[2021-05-31T19:56:55+0000] [ALPM] upgraded wine (6.8-1 -> 6.9-1)
[2021-05-31T19:56:55+0000] [ALPM] upgraded xapp (2.0.7-1 -> 2.2.0-1)
[2021-05-31T19:56:55+0000] [ALPM] upgraded zxing-cpp (1.1.1-1 -> 1.2.0-1)
[2021-05-31T19:56:55+0000] [ALPM] transaction completed
[2021-05-31T19:56:57+0000] [ALPM] running '20-systemd-sysusers.hook'...
[2021-05-31T19:56:57+0000] [ALPM] running '30-systemd-binfmt.hook'...
[2021-05-31T19:56:57+0000] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-05-31T19:56:58+0000] [ALPM] running '30-systemd-tmpfiles.hook'...
[2021-05-31T19:56:58+0000] [ALPM] running '30-systemd-udev-reload.hook'...
[2021-05-31T19:56:58+0000] [ALPM] running '30-systemd-update.hook'...
[2021-05-31T19:56:58+0000] [ALPM] running '40-update-ca-trust.hook'...
[2021-05-31T19:56:58+0000] [ALPM] running '60-depmod.hook'...
[2021-05-31T19:57:10+0000] [ALPM] running '90-mkinitcpio-install.hook'...
[2021-05-31T19:57:10+0000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
[2021-05-31T19:57:10+0000] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
[2021-05-31T19:57:10+0000] [ALPM-SCRIPTLET] ==> Starting build: 5.10.41-1-MANJARO
[2021-05-31T19:57:10+0000] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-05-31T19:57:10+0000] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-05-31T19:57:10+0000] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-05-31T19:57:11+0000] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-05-31T19:57:11+0000] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-05-31T19:57:11+0000] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-05-31T19:57:11+0000] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-05-31T19:57:11+0000] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-05-31T19:57:11+0000] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-05-31T19:57:11+0000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-05-31T19:57:11+0000] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
[2021-05-31T19:57:12+0000] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-05-31T19:57:12+0000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
[2021-05-31T19:57:12+0000] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
[2021-05-31T19:57:12+0000] [ALPM-SCRIPTLET] ==> Starting build: 5.10.41-1-MANJARO
[2021-05-31T19:57:12+0000] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-05-31T19:57:12+0000] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-05-31T19:57:13+0000] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-05-31T19:57:13+0000] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-05-31T19:57:15+0000] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-05-31T19:57:16+0000] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-05-31T19:57:16+0000] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-05-31T19:57:17+0000] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-05-31T19:57:18+0000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-05-31T19:57:18+0000] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-05-31T19:57:22+0000] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-05-31T19:57:22+0000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux512.preset: 'default'
[2021-05-31T19:57:22+0000] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.12-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.12-x86_64.img
[2021-05-31T19:57:22+0000] [ALPM-SCRIPTLET] ==> Starting build: 5.12.8-1-MANJARO
[2021-05-31T19:57:22+0000] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-05-31T19:57:22+0000] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-05-31T19:57:22+0000] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-05-31T19:57:23+0000] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-05-31T19:57:23+0000] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-05-31T19:57:23+0000] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-05-31T19:57:23+0000] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-05-31T19:57:23+0000] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-05-31T19:57:23+0000] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-05-31T19:57:23+0000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-05-31T19:57:23+0000] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.12-x86_64.img
[2021-05-31T19:57:24+0000] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-05-31T19:57:24+0000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux512.preset: 'fallback'
[2021-05-31T19:57:24+0000] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.12-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.12-x86_64-fallback.img -S autodetect
[2021-05-31T19:57:24+0000] [ALPM-SCRIPTLET] ==> Starting build: 5.12.8-1-MANJARO
[2021-05-31T19:57:24+0000] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-05-31T19:57:24+0000] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-05-31T19:57:25+0000] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-05-31T19:57:25+0000] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-05-31T19:57:27+0000] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-05-31T19:57:28+0000] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-05-31T19:57:28+0000] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-05-31T19:57:29+0000] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-05-31T19:57:30+0000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-05-31T19:57:30+0000] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.12-x86_64-fallback.img
[2021-05-31T19:57:34+0000] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-05-31T19:57:34+0000] [ALPM] running '90-nvidia-utils.hook'...
[2021-05-31T19:57:34+0000] [ALPM] running '99-grub.hook'...
[2021-05-31T19:57:35+0000] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2021-05-31T19:57:35+0000] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2021-05-31T19:57:35+0000] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.12-x86_64
[2021-05-31T19:57:35+0000] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.12-x86_64.img
[2021-05-31T19:57:35+0000] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.12-x86_64-fallback.img
[2021-05-31T19:57:35+0000] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.10-x86_64
[2021-05-31T19:57:35+0000] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
[2021-05-31T19:57:35+0000] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-05-31T19:57:36+0000] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2021-05-31T19:57:36+0000] [ALPM-SCRIPTLET] It's output will be used to detect bootable binaries on them and create new boot entries.
[2021-05-31T19:57:42+0000] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2021-05-31T19:57:42+0000] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2021-05-31T19:57:42+0000] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2021-05-31T19:57:42+0000] [ALPM-SCRIPTLET] done
[2021-05-31T19:57:42+0000] [ALPM] running 'dbus-reload.hook'...
[2021-05-31T19:57:42+0000] [ALPM] running 'detect-old-perl-modules.hook'...
[2021-05-31T19:57:42+0000] [ALPM] running 'fontconfig.hook'...
[2021-05-31T19:57:42+0000] [ALPM] running 'fontconfig-32.hook'...
[2021-05-31T19:57:42+0000] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2021-05-31T19:57:42+0000] [ALPM] running 'glib-compile-schemas.hook'...
[2021-05-31T19:57:42+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-05-31T19:57:42+0000] [ALPM] running 'kernel-alive-post.hook'...
[2021-05-31T19:57:43+0000] [ALPM-SCRIPTLET]
[2021-05-31T19:57:43+0000] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Warning:
[2021-05-31T19:57:43+0000] [ALPM-SCRIPTLET] -> Kernel has been updated. Modules of the current kernel
[2021-05-31T19:57:43+0000] [ALPM-SCRIPTLET] -> have been backed up so you can continue to use your
[2021-05-31T19:57:43+0000] [ALPM-SCRIPTLET] -> computer. However, the new kernel will only work
[2021-05-31T19:57:43+0000] [ALPM-SCRIPTLET] -> at next boot.
[2021-05-31T19:57:43+0000] [ALPM-SCRIPTLET] e[1;0m
[2021-05-31T19:57:43+0000] [ALPM] running 'mktexlsr.hook'...
[2021-05-31T19:57:44+0000] [ALPM] running 'texinfo-install.hook'...
[2021-05-31T19:57:44+0000] [ALPM] running 'texlive-fmtutil.hook'...
[2021-05-31T19:58:04+0000] [ALPM] running 'texlive-updmap.hook'...
[2021-05-31T19:58:05+0000] [ALPM] running 'thunderbird-post.hook'...
[2021-05-31T19:58:05+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-05-31T19:58:05+0000] [ALPM] running 'update-mime-database.hook'...
[2021-06-01T19:43:53+0000] [PAMAC] synchronizing package lists
[2021-06-01T19:44:30+0000] [ALPM] transaction started
[2021-06-01T19:44:30+0000] [ALPM] upgraded binance (1.17.0-1 -> 1.17.1-1)
[2021-06-01T19:44:30+0000] [ALPM] transaction completed
[2021-06-01T19:44:30+0000] [ALPM] running '30-systemd-update.hook'...
[2021-06-01T19:44:30+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-06-01T19:44:30+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-06-02T19:14:46+0000] [PAMAC] synchronizing package lists
[2021-06-02T19:15:08+0000] [ALPM] running 'firefox-pre.hook'...
[2021-06-02T19:15:08+0000] [ALPM] transaction started
[2021-06-02T19:15:09+0000] [ALPM] upgraded firefox (88.0.1-1 -> 89.0-1)
[2021-06-02T19:15:09+0000] [ALPM] upgraded firefox-i18n-en-us (88.0.1-1 -> 89.0-1)
[2021-06-02T19:15:09+0000] [ALPM] upgraded firefox-i18n-is (88.0.1-1 -> 89.0-1)
[2021-06-02T19:15:09+0000] [ALPM] transaction completed
[2021-06-02T19:15:09+0000] [ALPM] running '30-systemd-update.hook'...
[2021-06-02T19:15:09+0000] [ALPM] running 'firefox-post.hook'...
[2021-06-02T19:15:09+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-06-02T19:15:09+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-06-04T17:28:10+0000] [PAMAC] synchronizing package lists
[2021-06-04T17:28:29+0000] [ALPM] transaction started
[2021-06-04T17:28:29+0000] [ALPM] upgraded lib32-libva-mesa-driver (21.1.1-1 -> 21.1.2-0)
[2021-06-04T17:28:29+0000] [ALPM] upgraded mesa (21.1.1-1 -> 21.1.2-0)
[2021-06-04T17:28:29+0000] [ALPM] upgraded lib32-mesa (21.1.1-1 -> 21.1.2-0)
[2021-06-04T17:28:29+0000] [ALPM] upgraded libva-mesa-driver (21.1.1-1 -> 21.1.2-0)
[2021-06-04T17:28:29+0000] [ALPM] transaction completed
[2021-06-04T17:28:29+0000] [ALPM] running '30-systemd-update.hook'...
[2021-06-05T23:07:39+0000] [PACMAN] Running 'pacman -S nvtop'
[2021-06-05T23:07:42+0000] [ALPM] transaction started
[2021-06-05T23:07:42+0000] [ALPM] installed nvtop (1.2.1-1)
[2021-06-05T23:07:42+0000] [ALPM] transaction completed
[2021-06-05T23:07:42+0000] [ALPM] running '30-systemd-update.hook'...
