Something is coming...
Do you have blur enabled in Konsole? I think it’s infamous “korners” bug.
Yeah, it might be related … i did a small change to the svg files, and will see if that helps. I doubt, but if is not working then i go back to png instead of svg.
Let’s see how this will go…
I will create a new thread for this bug, but before that, what information do you need from me to deal with this bug?
Make sure Yakuake is not launched (check for yakuake
process) and launch it from terminal. Provide an output and make a screenshot if it’s launching but visuals broken.
I’m on unstable. I don’t have any issues with yakuake. I did have to go through a few extra steps before and after that update: I had to manually get rid of manjaro-kde-settings-19.0 because it depended on the breath2 packages. Then I had to update my settings to set everythong back to breath. If kconf_update was supposed to do this automagically, it didn’t for me…
I don’t know how this will work in case of manjaro-kde-settings-19.0
… Other users updated fine it seems.
Oh well. I guess I must’ve messed things up at some point. I have no clue why I was stuck with manjaro-kde-settings-19.0…
I think it was an oversight from our end?.. But yes, just change theme manually/reset settings if it’s not done automagically.
What’s the way to disable blur on Yakuake in these new themes? Unticking the “Blur background” box and restarting Yakuake doesn’t seem to have an effect.
Oops, it seems I accidentally left it in global config? Will fix tomorrow.
It worked for me even without restarting of Yakuake. I turned it back on though since I can live with those corners but can’t stand the absence of blur effect.
Ah I got it wrong, I meant switching global Blur effect off had its, huh, effect immediately. Regarding [Konsole] profiles setting, well, Blur has never worked for Yakuake on my installation.
The Blur™. We needs it. We wants it. We will has The Blur™!
I actually prefer seeing though Yakuake window, to a certain extent.
Those being the keywords.
@LordTermor Since a big overhaul of KDE is being done, I propose some changes in an area where I find KDE to be lacking: Calendar. The default calendar applet in KDE is a joke out of the box compared to GNOME( integrates with google and M$ accounts). Even after setting up the bloated Korganiser suite, it’s unusable.
Thus I’d suggest to use the plasmoid Event Calendar
by default in Manjaro KDE, which looks way better and has Google integration, a weather applet and a timer built in.
Our current course is to follow upstream as close as possible. So no major downstream changes. We even work with KDE now to get our current changes upstreamed. You’d better ask KDE to improve calendar.
Well, if we change it and get +ve feedback, maybe they’d accept it upstream?
The calendar applet actually does integrate the system calendar (which itself integrates google stuff), it’s just not enabled by default. I’ll have to ask around why it isn’t enabled by default but it really should be changed.
Edit: the calendar plugin configuration is using absolute paths. Once that’s fixed we can make the PIM integration the default
