Manjaro-zsh-config was updated to version 0.13 in unstable. The main new feature is the improved command-not-found hook.If you run a command that belongs to a package that you don’t have installed, it should tell you what you need to install and offer to install it.
Steps to test:
Update manjaro-zsh-config to version 0.13
Ensure that your ~/.zshrc is the same as /etc/skel/.zshrc
Run some command that you don’t have installed, for example most, podman, docker, and so on
Please test if it is pleasant to use. Also, if you have any other suggestions for manjaro-zsh-config, you can post them here.
~ >>> most
zsh: correct 'most' to '_mosh' [nyae]? n
The command most is not installed. It may be found in the following packages:
extra/most 5.1.0-2 /usr/bin/most
Do you want to Install package most? (y/N) y
pamac install most
Preparing...
Authenticating as: Full Name (username)
Password:
Warning: manjaro-zsh-config: local (0.14-1) is newer than community (0.13-1)
Resolving dependencies...
Checking inter-conflicts...
To upgrade (11):
yelp-xsl 3.38.0-1 (3.36.0-1) extra 182,1 kB
xdg-desktop-portal 1.8.0-1 (1.7.2-1) extra 340,6 kB
xdg-desktop-portal-gtk 1.8.0-1 (1.7.1-1) extra 188,0 kB
tracker-miners 2.3.5-1 (2.3.4-1) extra 532,1 kB
tracker 2.3.6-1 (2.3.5-1) extra 1,1 MB
python-reportlab 3.5.50-1 (3.5.49-1) community 2,4 MB
pipewire 0.3.12-1 (0.3.11-1) extra 1,1 MB
lib32-mesa 20.1.8-1 (20.1.7-1) multilib 13,0 MB
mesa 20.1.8-1 (20.1.7-1) extra 14,8 MB
gupnp-igd 1.2.0-1 (0.2.5+3+gedd78a6-3) extra 30,0 kB
gupnp-av 0.12.11+3+g2123c81-1 (0.12.11+2+gb5ca07c-2) extra 138,0 kB
To install (1):
most 5.1.0-2 extra 54,4 kB
Total download size: 34,0 MB
Total installed size: 163,6 kB
Apply transaction ? [y/N]
Correction feature works perfectly as far as I can tell. Would be nice if it could be added to a list with corrections, though, since clicking through multiple y/n questions can be tiresome.
suggestions:
Für verständnis:
ist “find-the-command bzw command-not found schon bei manjaro dabei oder muss ich es zusätzlich installieren?
For understanding (Gnome / zsh):
is “find-the-command” or “command-not-found” already included with manjaro or do I have to install it additionally?”
(from: AUR)
pkgfile includes a Zsh script file that provides a command_not_found_handler function that will automatically search the pkgfile database when entering an unrecognized command.
You need to source the script to enable it. For example:
