Terrible input lag
Sorry didn’t introduce myself, In will later.
I have what seems to be a common problem as of late, but all the fixes and advice seem to conflict with each other, waters are very muddy. So, my problem is massive input lag that makes my system unusable. Mouse, touch-pad, keyboard, audio input, everything has a 3-4 second lag from action to result (its maddening) it happens in KDE, XFCE and GNOME DE’s I suspect it is multi-display + nvidia + IDK, I am new to linux as a whole, cutting my teeth on DEB distros seemed easy so I came to this and I think I learned bad habits, please, correct me if you can. Also if my first POST doesn’t conform to SOP please correct me there as well.
FNG
  Kernel: 6.0.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
    root=UUID=70cd4e1f-98e5-4007-ab6f-0020f01f85b6 rw quiet apparmor=1
    security=apparmor resume=UUID=380b2e0a-dace-4c35-b6a6-f39d1ba475fa
    udev.log_priority=3
  Desktop: MATE v: 1.26.0 info: mate-panel wm: marco v: 1.26.0 vt: 7
    dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: Dell product: G5 5590 v: N/A
  Mobo: Dell model: 0MXHK3 v: A02 serial: <superuser required> UEFI: Dell
    v: 1.21.1 date: 09/14/2022
  ID-1: BAT0 charge: 37.3 Wh (100.0%) condition: 37.3/60.0 Wh (62.2%)
    volts: 17.0 min: 15.2 model: BYD DELL HYWXJ99 type: Li-poly serial: <filter>
    status: full
  RAM: total: 15.44 GiB used: 2.03 GiB (13.2%)
  Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 2003 high: 2600 min/max: 800/4500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 2600 3: 2600
    4: 2600 5: 800 6: 2600 7: 838 8: 2600 9: 800 10: 2600 11: 2600 12: 2600
    bogomips: 62431
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
    PBRSB-eIBRS: Not affected
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: none off: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
    bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Dell
    driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 520.xx+
    status: current (as of 2022-10) arch: Turing code: TUxxx process: TSMC 12nm
    built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
  Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
    bus-ID: 1-5:4 chip-ID: 0c45:671f class-ID: 0e02
  Display: x11 server: X.org v: 1.21.1.4 compositor: marco v: 1.26.0 driver:
    X: loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
    gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-1-0 pos: primary res: 1920x1080 dpi: 44
    size: 1110x620mm (43.7x24.41") diag: 1271mm (50.06") modes: N/A
  Monitor-2: eDP-1 size-res: N/A modes: N/A
  API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
  Device-2: NVIDIA TU116 High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:1aeb
    class-ID: 0403
  Sound API: ALSA v: k6.0.11-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.61 running: no
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Realtek vendor: Dell driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:2502
    class-ID: 0200
  IF: enp60s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
    driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
  Local Storage: total: 1.14 TiB used: 269.28 GiB (23.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: KBG40ZNS256G NVMe
    KIOXIA 256GB size: 238.47 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 10410106
    temp: 31.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
    type: SSD serial: <filter> rev: 4B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: BUP Ultra
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B type: N/A
    serial: <filter> rev: 0004 scheme: GPT
  ID-1: / raw-size: 456.66 GiB size: 456.44 GiB (99.95%) used: 14.73 GiB (3.2%)
    fs: xfs dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 70cd4e1f-98e5-4007-ab6f-0020f01f85b6
    used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: ADC9-3A29
  ID-3: /run/media/ocleusoc/6741455d-358c-4054-9dfb-17354922487b
    raw-size: 237.97 GiB size: 233.18 GiB (97.99%) used: 26.57 GiB (11.4%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 6741455d-358c-4054-9dfb-17354922487b
  ID-4: /run/media/ocleusoc/bkp raw-size: 465.76 GiB
    size: 465.65 GiB (99.98%) used: 227.98 GiB (49.0%) fs: vfat dev: /dev/sdb1
    maj-min: 8:17 label: bkp uuid: 7311-DC93
    dev: /dev/sda3 maj-min: 8:3 label: swap
    uuid: 380b2e0a-dace-4c35-b6a6-f39d1ba475fa
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 512 MiB fs: vfat label: N/A
    uuid: 5057-3D6F
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-2:2 info: YICHIP JLab GO Keys type: Keyboard,Mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 3151:3000 class-ID: 0301
  Device-2: 1-3:3 info: 2.4G Wireless Mouse type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 100mA
    chip-ID: 3938:1191 class-ID: 0301
  Device-3: 1-5:4 info: Microdia Integrated_Webcam_HD type: Video
  Device-4: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 8087:0aaa class-ID: e001
  Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
  Device-1: 2-1:2 info: Seagate RSS LLC BUP Ultra type: Mass Storage
    driver: uas interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 144mA
    chip-ID: 0bc2:ac19 class-ID: 0806 serial: <filter>
  Hub-3: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-4: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 51.0 C pch: 52.0 C mobo: 47.0 C
  Fan Speeds (RPM): cpu: 0 fan-1: 0
  Processes: 290 Uptime: 4m wakeups: 2 Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
  pkgs: 1007 libs: 294 tools: pamac Shell: Bash v: 5.1.16
  running-in: mate-terminal inxi: 3.3.23
provide logs:
journalctl -b-1 -p4 --no-pager
The Info you requested
1010]:   group.add_action(about_action)
Dec 09 23:36:53 ocleus-g55590 mate-xapp-statu[1010]: gtk_widget_size_allocate(): attempt to allocate widget with width -3 and height 40
Dec 09 23:36:53 ocleus-g55590 kernel: FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Dec 09 23:43:01 ocleus-g55590 pulseaudio[866]: Lost I/O connection in module "module-gsettings"
Dec 09 23:43:01 ocleus-g55590 systemd[780]: obex.service: Failed with result 'exit-code'.
Dec 09 23:43:01 ocleus-g55590 systemd-coredump[1924]: Failed to connect to coredump service: Connection refused
Dec 09 23:43:01 ocleus-g55590 systemd[1]: udisks2.service: Main process exited, code=dumped, status=6/ABRT
Dec 09 23:43:01 ocleus-g55590 systemd[1]: udisks2.service: Failed with result 'core-dump'.
Dec 09 23:43:01 ocleus-g55590 pulseaudio[866]: Error opening PCM device hdmi:1: Permission denied
Dec 09 23:43:01 ocleus-g55590 pulseaudio[866]: Error opening PCM device front:0: No such file or directory
Dec 09 23:43:05 ocleus-g55590 kernel: watchdog: watchdog0: watchdog did not stop!
[ocleusoc@ocleus-g55590 ~]$
thats not the whole output … and i gave you a command for the previous boot, so provide logs from this:
journalctl -b0 -p4 --no-pager
Sorry about any incomplete data, this lag is impossible, I really like this distro and dont want to abandon it, also I have never seen support so fast before that is very cool
It may be duplicated, I ran one as root as well
ocleusoc@ocleus-g55590 ~]$ journalctl -b0 -p4 --no-pager
Dec 10 01:04:00 ocleus-g55590 kernel: x86/cpu: SGX disabled by BIOS.
Dec 10 01:04:00 ocleus-g55590 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Dec 10 01:04:00 ocleus-g55590 kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Dec 10 01:04:00 ocleus-g55590 kernel:   #7  #8  #9 #10 #11
Dec 10 01:04:00 ocleus-g55590 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dec 10 01:04:00 ocleus-g55590 kernel: ACPI Error: No pointer back to namespace node in package 000000007ab5170f (20220331/dsargs-301)
Dec 10 01:04:00 ocleus-g55590 kernel: hpet_acpi_add: no address or irqs in _CRS
Dec 10 01:04:00 ocleus-g55590 kernel: ata1.00: supports DRM functions and may not be fully accessible
Dec 10 01:04:00 ocleus-g55590 kernel: i8042: Warning: Keylock active
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 0
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 1
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 2
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 3
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 4
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 6
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 8
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 9
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 10
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 11
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 15
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 16
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 18
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 19
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 20
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 21
Dec 10 01:04:00 ocleus-g55590 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 28
Dec 10 01:04:00 ocleus-g55590 kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
Dec 10 01:04:00 ocleus-g55590 kernel: wmi_bus wmi_bus-PNP0C14:05: WQBC data block query control method not found
Dec 10 01:04:00 ocleus-g55590 kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
Dec 10 01:04:00 ocleus-g55590 kernel: acpi PNP0C14:06: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
Dec 10 01:04:00 ocleus-g55590 kernel: acpi PNP0C14:07: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
Dec 10 01:04:00 ocleus-g55590 kernel: acpi PNP0C14:08: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
Dec 10 01:04:00 ocleus-g55590 kernel: sd 1:0:0:0: [sdb] Optimal transfer size 33553920 bytes not a multiple of preferred minimum block size (4096 bytes)
Dec 10 01:04:01 ocleus-g55590 kernel: nvidia: loading out-of-tree module taints kernel.
Dec 10 01:04:01 ocleus-g55590 kernel: nvidia: module license 'NVIDIA' taints kernel.
Dec 10 01:04:01 ocleus-g55590 kernel: Disabling lock debugging due to kernel taint
Dec 10 01:04:01 ocleus-g55590 kernel: thermal thermal_zone9: failed to read out thermal zone (-61)
Dec 10 01:04:02 ocleus-g55590 kernel:
Dec 10 01:04:02 ocleus-g55590 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  525.60.11  Wed Nov 23 23:04:03 UTC 2022
Dec 10 01:04:03 ocleus-g55590 kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Dec 10 01:04:03 ocleus-g55590 kernel: kauditd_printk_skb: 159 callbacks suppressed
Dec 10 01:04:03 ocleus-g55590 systemd[612]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Dec 10 01:04:03 ocleus-g55590 bluetoothd[612]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Dec 10 01:04:03 ocleus-g55590 bluetoothd[612]: src/plugin.c:plugin_init() Failed to init vcp plugin
Dec 10 01:04:03 ocleus-g55590 bluetoothd[612]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Dec 10 01:04:03 ocleus-g55590 bluetoothd[612]: src/plugin.c:plugin_init() Failed to init mcp plugin
Dec 10 01:04:03 ocleus-g55590 bluetoothd[612]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Dec 10 01:04:03 ocleus-g55590 bluetoothd[612]: src/plugin.c:plugin_init() Failed to init bap plugin
Dec 10 01:04:03 ocleus-g55590 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Dec 10 01:04:06 ocleus-g55590 kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
Dec 10 01:04:08 ocleus-g55590 kernel: kauditd_printk_skb: 33 callbacks suppressed
Dec 10 01:04:09 ocleus-g55590 lightdm[778]: gkr-pam: no password is available for user
Dec 10 01:04:09 ocleus-g55590 lightdm[778]: gkr-pam: couldn't unlock the login keyring.
Dec 10 01:04:10 ocleus-g55590 mate-session[797]: WARNING: Unable to find provider '' of required component 'dock'
Dec 10 01:04:10 ocleus-g55590 gnome-keyring-daemon[857]: discover_other_daemon: 1
Dec 10 01:04:13 ocleus-g55590 kernel: kauditd_printk_skb: 10 callbacks suppressed
Dec 10 01:04:13 ocleus-g55590 gnome-keyring-daemon[965]: discover_other_daemon: 1
Dec 10 01:04:13 ocleus-g55590 gnome-keyring-daemon[976]: discover_other_daemon: 1
Dec 10 01:04:13 ocleus-g55590 gnome-keyring-daemon[991]: discover_other_daemon: 1
Dec 10 01:04:14 ocleus-g55590 pulseaudio[872]: stat('/etc/pulse/default.pa.d'): No such file or directory
Dec 10 01:04:14 ocleus-g55590 clock-applet[1011]: Negative content width -7 (allocation 1, extents 4x4) while allocating gadget (node button, owner GtkToggleButton)
Dec 10 01:04:14 ocleus-g55590 org.mate.panel.applet.MateXAppStatusAppletFactory[1003]: /usr/lib/xapps/mate-xapp-status-applet.py:322: DeprecationWarning: MatePanelApplet.Applet.set_background_widget is deprecated
Dec 10 01:04:14 ocleus-g55590 org.mate.panel.applet.MateXAppStatusAppletFactory[1003]:   self.applet.set_background_widget(self.applet)
Dec 10 01:04:14 ocleus-g55590 org.mate.panel.applet.MateXAppStatusAppletFactory[1003]: /usr/lib/xapps/mate-xapp-status-applet.py:342: DeprecationWarning: Gtk.ActionGroup.set_translation_domain is deprecated
Dec 10 01:04:14 ocleus-g55590 org.mate.panel.applet.MateXAppStatusAppletFactory[1003]:   group.set_translation_domain("xapp")
Dec 10 01:04:14 ocleus-g55590 org.mate.panel.applet.MateXAppStatusAppletFactory[1003]: /usr/lib/xapps/mate-xapp-status-applet.py:350: DeprecationWarning: Gtk.ActionGroup.add_action is deprecated
Dec 10 01:04:14 ocleus-g55590 org.mate.panel.applet.MateXAppStatusAppletFactory[1003]:   group.add_action(about_action)
Dec 10 01:04:14 ocleus-g55590 mate-xapp-statu[1003]: gtk_widget_size_allocate(): attempt to allocate widget with width -3 and height 40
Dec 10 01:04:14 ocleus-g55590 kernel: FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ocleusoc@ocleus-g55590 ~]$ su root
Password:
[ocleus-g55590 ocleusoc]# journalctl -b0 -p4 --no-pager
one more thing, it did this with the previous kernel too but not with nouveau but this kernel both prop nvidia and nouveau are affected
well theres really nothing there except:
and this lag didnt happen on non arch distros?
hmm, it could be related to nvidia… try adding the ibt parameter:
open this file:
sudo nano /etc/default/grub
and inside this line: GRUB_CMDLINE_LINUX_DEFAULT inside the quotes add this parameter:
ibt=off
dont remove anything, just add it to existing parameters, save the file with ctrl+x, update grub:
sudo update-grub
reboot and see if it helped
Only on this distro, and I added that line but no joy
install envycontrol:
pamac build envycontrol
after its done, switch to integrated:
sudo envycontrol -s integrated
it will prompt you for reboot, so do it, and see if the lags happen also when nvidia is disabled…
you can check with:
inxi -G
if the nvidia is disabled, it should not be detected
thank you i will do that 1st thing, its given me a monster throbbing skull cracker, ill post back when i have results in the a.m. again ty for the lightning fast and patient help
thought i would let you know the problem, it is a bug in the nvidia driver on multiple display specific to the 16xx line of GPU when displaying any of the attached displays in anything other than native resolution, AND another in native resolution it brakes it somehow. the language was beyond my vocabulary and I cant relocate the topic on nvidia dot com it has to do with composition pipelines, and viewport sizing for now the only fix is run all at native. it only effects a small number of chips
so if you are in native everything is ok?
