Terminal / Spaces
How can i remove this marge on right (space), how can i remove it ??!
Hi @marocdevelop,
AFAIK that space is caused by the theme for you terminal emulator keeping space for your scrollbar. No, I don’t know how to change it, that would depend on the terminal editor you use.
i don t think that is issue terminal issue, because in my capture i share 3 terminal differents
