I want to write a bash script that can create a launcher
in menulibre
and to do this I would need to run a terminal command, but running menulibre
just shows the menulibre
gui. How can I add launchers to my menu
with bash
/terminal command
without having the gui?
These are just text files. Since the filename extension is .desktop, they are usually called Desktop files.
specific user desktop files are stored in ~/.local/share/applications
. System wide desktop files are stored in /usr/share/applications
Use an old as a template. Since it is just a text file it can be created on the fly.
There is also a standard document.
Desktop Entry Specification
Ahh, I didn’t realise they were just files - thats cool! Quick question, when I made an application with menulibre it named the .desktop
as menulibre-*
→ Is that menulibre-
part needed?
also: what does the version mean? is that user inputted?
No, you can name them as you like, just the .desktop
part is important. I would also not use any special characters. Also see File naming
If you create a desktop file yourself, it might take a few seconds to show up in the menu.
See the specification Recognized desktop entry keys
I also want to point out, that DEs usually add there own entry’s. The entry’s from the specification are just the basics that every DE understands.
