Hi All.
Manjaro KDE user here.
Something has happened, or more likely I’ve done something causing my KDE to always ask for the sudo password, where needed, in a GUI popup box, even when I do something from the command line.
Anyone have any idea why this could be?
Edit:
I just tested again. When running sudo ls / from the command line, it asks for my sudo password on the command line. When running a script, such as pamac install it asks for my sudo password with a GUI popup prompt.
Ideally, I’d like it to ask for the password in its context. I.e.: if the script/program is terminal/CLI/command line based, ask in the tereminal/command line, and if it is a GUI program, then use the GUI prompt.
