Terminal: Can no longer login in to NordVPN with sudo
Hello,
not sure if this is the right category, but i give it a shot.
My problem:
I somehow failed three times to enter my password correctly into the terminal.
Since then i can no longer log in with sudo.
The only information the terminal gives me after a attempt is: “Your are not looged in.”
On booting my Manjaro i can still use my password to login. I can use the password also in “Add/Remove Software” to update my machine.
But my Terminal… it seems its Game Over for that.
I already tried to change my Password. But that did nothing.
What can i do :frowning:
moderator edit - removed screenshot of text
Please don’t post pictures of text…just copy and paste the text instead. :slight_smile:
sudo is working, assuming you’re meant to use sudo then the problem is with your VPN or network. I don’t know anything about VPNs so I’ll leave it for those that do.
no sudo needed
if (for example):
nordvpn c France
results in:
You are not logged in.
then … log in:
nordvpn login
this results in a message with a link that you visit, like this:
Continue in the browser: https://api.nordvpn.com/v1/users/oauth/login-redirect?attempt=a-very-long-number
do that and then you are logged in and can connect and disconnect as often and to whatever servers/countries you like.
… that is how I use it - not on Manjaro but on Mint and Debian
The daemon process is always running, even across reboots.
I only need to login after I quit (not just disconnect) the process.
Very very rarely.
Have you seen the Arch Wiki?
NordVPN - ArchWiki
If you use sudo with nordvpn you are telling the application to look in /root for the credentials.
Therefore you should not use sudo - just
nordvpn connect <country>
