Hi,
when I wake up my PC after stand-by, I have a slight sound problem. The issue is that there is a short increase in loudness. It is as if someone turned up the volume by 80% or so for a fraction of a second. It isn’t regularly, but around every 30s or so.
When I plug-in my headset on the front connector the issue is gone. Also after unplugging the issue is gone at first, but after some time it reoccurs.
So very strange after all.
Any clues how to debug this?
Or maybe some command to “reset” sound?
System info
Kernel: 6.9.3-3-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.0.5 Distro: Manjaro Linux
Type: Desktop System: Micro-Star product: MS-7B89 v: 2.0
serial: <superuser required>
Mobo: Micro-Star model: B450M MORTAR TITANIUM (MS-7B89) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.H0
date: 07/27/2022
Info: 8-core model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64
type: MT MCP cache: L2: 4 MiB
Speed (MHz): avg: 3001 min/max: 400/4673 cores: 1: 3776 2: 3034 3: 3031
4: 3744 5: 3034 6: 3035 7: 3034 8: 3032 9: 3756 10: 2993 11: 3034 12: 3014
13: 3017 14: 3087 15: 400 16: 3006
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0 driver: X:
loaded: amdgpu dri: radeonsi gpu: amdgpu resolution: 2560x1440
API: EGL v: 1.5 drivers: radeonsi,swrast platforms: x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.9-manjaro1.1
renderer: AMD Radeon Graphics (radeonsi renoir LLVM 17.0.6 DRM 3.57
6.9.3-3-MANJARO)
API: Vulkan v: 1.3.279 drivers: radv surfaces: xcb,xlib
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
Device-2: AMD Family 17h/19h HD Audio driver: snd_hda_intel
API: ALSA v: k6.9.3-3-MANJARO status: kernel-api
Server-1: PulseAudio v: 17.0 status: active
