For the past few months Telegram won’t scale below 200%.
It is too large and nearly unusable.
It relates to Telegram, QT and DPI I think.
Telegram version:
3.5.2-1 official repo (community)
qtdiag output:
Qt 5.15.3 (x86_64-little_endian-lp64 shared (dynamic) release build; by GCC 11.2.0) on "xcb"
OS: Manjaro Linux [linux version 5.10.105-1-MANJARO]
This is the issue posted on github (not my post).
https://github.com/telegramdesktop/tdesktop/issues/17518
In that github thread the advice given is:
Yeah, now Telegram uses Qt 6 and the scaling works in another way. If you want to choose scaling less than 200%, you should remove
QT_AUTO_SCREEN_SCALE_FACTOR=1
and setQT_ENABLE_HIGHDPI_SCALING=0
in order to disable Qt scaling
I don’t know how or where to change those QT settings mentioned above.
How do I make those changes and fix this issue?
Thanks!
My inxi output below:
Kernel: 5.10.105-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=e9b1a713-9d2b-44ea-90a2-89f6a020c1ea rw
resume=UUID=c34ac68c-a7f7-4949-8b22-9e1f8919cf78
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: H97 Performance
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: P2.60
date: 03/07/2018
RAM: total: 7.72 GiB used: 3 GiB (38.8%)
RAM Report:
Info: model: Intel Core i5-4690 bits: 64 type: MCP arch: Haswell family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 2531 high: 3882 min/max: 800/3900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 942 2: 3211 3: 2091
4: 3882 bogomips: 28012
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts erms est f16c flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep smx
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust
tsc_deadline_timer vme x2apic xsave xsaveopt xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
STIBP: disabled, RSB filling
Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: ASUSTeK driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1380 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 5760x1440 s-dpi: 96 s-size: 1524x381mm (60.00x15.00")
s-diag: 1571mm (61.85")
Monitor-1: DVI-D-0 pos: primary,top-left res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: DVI-D-1 pos: bottom-c res: 1280x1024 hz: 75 dpi: 96
size: 340x270mm (13.39x10.63") diag: 434mm (17.09") modes: N/A
Monitor-3: HDMI-0 pos: middle-r res: 1920x1080 hz: 60 dpi: 305
size: 160x90mm (6.3x3.54") diag: 184mm (7.23") modes: N/A
Message: Unable to show GL data. Required tool glxinfo missing.
Processes: 215 Uptime: 30m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1791 lib: 495
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.15
