Hello folks,
The Telegram Application Notification Icon is not visible in my System Tray. It is only visible(a grey shade) when I hover over it.
I am using Manjaro Linux KDE ,Kernel version 5.15.28-1, KDE Plasma Version 5.24.3.
Thanks in Advance
Have you tried another icon theme? Because I just tried my Telegram in KDE and it works perfectly.
I use:
and it works just fine!
Hello.
I think it’s related: Tray icon on Linux has changed from white to black · Issue #24009 · telegramdesktop/tdesktop · GitHub
I’m also experiencing this problem, and I don’t have a simple solution to it yet.
Thank you @Mirdarthos for your response, will check out the Candy Icons for sure.
Hello @Knebergish. Fingers-crossed, let us wait for the update.
Hello,
Please make sure your system is updated:
sudo pacman-mirrors -f5 && sudo pacman -Syyu
Empty the ~/.chance
folder content in your home directory and reboot.
The error got corrected in the latest update
