I install telegram in manjaro kde but not working not lunching
Hello @qus,
you can run telegram from terminal to see if there are some errors shown.
telegram-desktop
thanks
telegram-desktop: error while loading shared libraries: libprotobuf.so.28: cannot open shared object file: No such file or directory
how to fix this problem
What says:
pamac search libprotobuf.so
Just checking: did you install the package from the repositories? Or the Snap/Flatpak?
ok
thanks
protobuf [Installed] 3.17.3-1 extra
Protocol Buffers - Google’s data interchange format
what to do after this
Your system is way out of date. libprotobuf
is at .32 these days.
So update your system.
sudo pacman -Syu
If that says Nothing to do
, then do:
sudo pacman-mirrors -f10
sudo pacman -Syyu
thanks
invalid or corrupted package:
why its not updating
Please post the entire output of the pacman -Syyu
command.
ok
i iwll
