I ran telegram-desktop from a terminal, it appears and I click around a bit and this happens randomly.
[dave@ddocu-web ~]$ telegram-desktop
** (telegram-desktop:1864): WARNING **: 21:52:38.331: Error loading plugin: libvoikko.so.1: cannot open shared object file: No such file or directory
** (telegram-desktop:1864): WARNING **: 21:52:38.336: Error loading plugin: libaspell.so.15: cannot open shared object file: No such file or directory
** (telegram-desktop:1864): WARNING **: 21:52:38.339: Error loading plugin: libnuspell.so.3: cannot open shared object file: No such file or directory
** (telegram-desktop:1864): WARNING **: 21:52:38.347: Error loading plugin: libhspell.so.0: cannot open shared object file: No such file or directory
[swscaler @ 0x7f68083500] No accelerated colorspace conversion found from yuv420p to bgra.
Aborted (core dumped)
I installed official telegram-desktop from the pamac gui.
So, yesterday I was in Telegram setting and you can change the interface scale, I did, to see if it looked better on my TV which is being used as my PI4 Monitor for the moment.
I changed the scale to 125% and nothing much change but I forgot to change the settings back.
I have just changed the Interface scale back to 100%, relaunched and my error reported above has gone away.
OK. Thanks for that, I’ll just view and update posts and leave the rest as default.
I find loads of “not supported on ARM” and the like, but Apple moving to ARM for it macs might start to change all that going forward.
