Here is the output of journalctl -b -xe
. I limited it to the relevant part, because my message would be too long otherwise.
Aug 03 23:06:35 failsafe systemd[1347]: Started Telegram Desktop.
░░ Subject: A start job for unit UNIT has finished successfully
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished successfully.
░░ The job identifier is 141.
Aug 03 23:06:35 failsafe kwin_x11[1438]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5485, resource id: 29360249, major code: 18 (ChangeProperty), minor code: 0
Aug 03 23:06:35 failsafe kwin_x11[1438]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5490, resource id: 29360250, major code: 18 (ChangeProperty), minor code: 0
Aug 03 23:06:35 failsafe dbus-daemon[1382]: [session uid=1000 pid=1382] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.60' (uid=1000 pid=1833 comm="/usr/bin/telegram-desktop -basegtkintegration :1.5")
Aug 03 23:06:35 failsafe systemd[1347]: Starting Virtual filesystem service...
░░ Subject: A start job for unit UNIT has begun execution
░░ A start job for unit UNIT has begun execution.
░░ The job identifier is 145.
Aug 03 23:06:35 failsafe dbus-daemon[1382]: [session uid=1000 pid=1382] Successfully activated service 'org.gtk.vfs.Daemon'
Aug 03 23:06:35 failsafe systemd[1347]: Started Virtual filesystem service.
Aug 03 23:06:35 failsafe plasmashell[1507]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:381: Unable to assign [undefined] to QString
Aug 03 23:06:35 failsafe dbus-daemon[1382]: [session uid=1000 pid=1382] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.65' (uid=1000 pid=1833 comm="/usr/bin/telegram-desktop -basegtkintegration :1.5")
Aug 03 23:06:35 failsafe systemd[1347]: Starting Accessibility services bus...
░░ The job identifier is 162.
Aug 03 23:06:35 failsafe dbus-daemon[1382]: [session uid=1000 pid=1382] Successfully activated service 'org.a11y.Bus'
Aug 03 23:06:35 failsafe systemd[1347]: Started Accessibility services bus.
Aug 03 23:06:35 failsafe at-spi-bus-launcher[1864]: dbus-daemon[1864]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=1000 pid=1833 comm="/usr/bin/telegram-desktop -basegtkintegration :1.5")
Aug 03 23:06:35 failsafe at-spi-bus-launcher[1864]: dbus-daemon[1864]: Successfully activated service 'org.a11y.atspi.Registry'
Aug 03 23:06:35 failsafe at-spi-bus-launcher[1866]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Aug 03 23:06:35 failsafe dbus-daemon[1382]: [session uid=1000 pid=1382] Activating via systemd: service name='org.freedesktop.portal.Desktop' unit='xdg-desktop-portal.service' requested by ':1.59' (uid=1000 pid=1825 comm="/usr/bin/telegram-desktop -- ")
Aug 03 23:06:35 failsafe systemd[1347]: Starting Portal service...
░░ The job identifier is 179.
Aug 03 23:06:35 failsafe dbus-daemon[1382]: [session uid=1000 pid=1382] Activating via systemd: service name='org.freedesktop.portal.Documents' unit='xdg-document-portal.service' requested by ':1.68' (uid=1000 pid=1869 comm="/usr/lib/xdg-desktop-portal ")
Aug 03 23:06:35 failsafe systemd[1347]: Starting flatpak document portal service...
░░ The job identifier is 196.
Aug 03 23:06:35 failsafe dbus-daemon[1382]: [session uid=1000 pid=1382] Activating via systemd: service name='org.freedesktop.impl.portal.PermissionStore' unit='xdg-permission-store.service' requested by ':1.69' (uid=1000 pid=1873 comm="/usr/lib/xdg-document-portal ")
Aug 03 23:06:35 failsafe systemd[1347]: Starting sandboxed app permission store...
░░ The job identifier is 213.
Aug 03 23:06:35 failsafe dbus-daemon[1382]: [session uid=1000 pid=1382] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
Aug 03 23:06:35 failsafe systemd[1347]: Started sandboxed app permission store.
Aug 03 23:06:35 failsafe dbus-daemon[1382]: [session uid=1000 pid=1382] Successfully activated service 'org.freedesktop.portal.Documents'
Aug 03 23:06:35 failsafe systemd[1347]: Started flatpak document portal service.
Aug 03 23:06:35 failsafe dbus-daemon[1382]: [session uid=1000 pid=1382] Activating service name='org.freedesktop.impl.portal.desktop.kde' requested by ':1.68' (uid=1000 pid=1869 comm="/usr/lib/xdg-desktop-portal ")
Aug 03 23:06:35 failsafe dbus-daemon[1382]: [session uid=1000 pid=1382] Successfully activated service 'org.freedesktop.impl.portal.desktop.kde'
Aug 03 23:06:35 failsafe xdg-desktop-portal-kde[1891]: xdp-kde: Desktop portal registered successfully
Aug 03 23:06:35 failsafe systemd[1347]: Created slice User Core Session Slice.
░░ The job identifier is 247.
Aug 03 23:06:35 failsafe systemd[1347]: Started Multimedia Service.
░░ The job identifier is 230.
Aug 03 23:06:35 failsafe rtkit-daemon[1550]: Successfully made thread 1897 of process 1897 owned by '1000' high priority at nice level -11.
Aug 03 23:06:35 failsafe rtkit-daemon[1550]: Supervising 4 threads of 2 processes of 1 users.
Aug 03 23:06:35 failsafe rtkit-daemon[1550]: Successfully made thread 1899 of process 1897 owned by '1000' RT at priority 20.
Aug 03 23:06:35 failsafe rtkit-daemon[1550]: Supervising 5 threads of 2 processes of 1 users.
Aug 03 23:06:35 failsafe dbus-daemon[1382]: [session uid=1000 pid=1382] Successfully activated service 'org.freedesktop.portal.Desktop'
Aug 03 23:06:35 failsafe systemd[1347]: Started Portal service.
Aug 03 23:06:35 failsafe kwin_x11[1438]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5968, resource id: 4194310, major code: 18 (ChangeProperty), minor code: 0
Aug 03 23:06:36 failsafe systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
░░ Subject: Unit succeeded
░░ The unit NetworkManager-dispatcher.service has successfully entered the 'dead' state.
Aug 03 23:06:36 failsafe audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 03 23:06:36 failsafe kernel: kauditd_printk_skb: 14 callbacks suppressed
Aug 03 23:06:36 failsafe kernel: audit: type=1131 audit(1628024796.174:104): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 03 23:06:36 failsafe kded5[1434]: Registering ":1.74/StatusNotifierItem" to system tray
Aug 03 23:06:36 failsafe kwin_x11[1438]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6840, resource id: 4194310, major code: 18 (ChangeProperty), minor code: 0
Aug 03 23:06:37 failsafe baloo_file[1505]: 189715036246179328 "/home/sandro/.local/share/kactivitymanagerd/resources/database-wal" renaming "gtkrc-2.0" to "database-wal"
Aug 03 23:06:37 failsafe kwin_x11[1438]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7217, resource id: 4194310, major code: 18 (ChangeProperty), minor code: 0
Aug 03 23:06:37 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=04:d9:f5:f6:03:35:12:d3:da:91:35:7c:08:00 SRC=192.168.178.20 DST=192.168.178.30 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=6109 DF PROTO=TCP SPT=22000 DPT=0 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 03 23:06:37 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=04:d9:f5:f6:03:35:12:d3:da:91:35:7c:86:dd SRC=fe80:0000:0000:0000:10d3:daff:fe91:357c DST=fe80:0000:0000:0000:6e78:b1ea:947a:42b2 LEN=80 TC=0 HOPLIMIT=255 FLOWLBL=261181 PROTO=TCP SPT=22000 DPT=0 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 03 23:06:38 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=04:d9:f5:f6:03:35:12:d3:da:91:35:7c:08:00 SRC=192.168.178.20 DST=192.168.178.30 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=59456 DF PROTO=TCP SPT=41388 DPT=0 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 03 23:06:38 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=04:d9:f5:f6:03:35:12:d3:da:91:35:7c:86:dd SRC=fe80:0000:0000:0000:10d3:daff:fe91:357c DST=fe80:0000:0000:0000:6e78:b1ea:947a:42b2 LEN=80 TC=0 HOPLIMIT=255 FLOWLBL=1043132 PROTO=TCP SPT=48128 DPT=0 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 03 23:06:38 failsafe telegram-desktop[1825]: QPainter::begin: Paint device returned engine == 0, type: 3
Aug 03 23:06:38 failsafe telegram-desktop[1825]: QWidget::render: Cannot render with an inactive painter
Aug 03 23:06:38 failsafe kwin_x11[1438]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7627, resource id: 29360231, major code: 15 (QueryTree), minor code: 0
Aug 03 23:06:38 failsafe kwin_x11[1438]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7709, resource id: 4194310, major code: 18 (ChangeProperty), minor code: 0
Aug 03 23:06:38 failsafe baloo_file[1505]: 189717080650612224 "/home/sandro/.config/khotkeysrc" renaming ".Xauthority" to "khotkeysrc"
Aug 03 23:06:38 failsafe baloo_file[1505]: 189715143620361728 "/home/sandro/.config/gtkrc" renaming "database-wal" to "gtkrc"
Aug 03 23:06:38 failsafe baloo_file[1505]: 189715358368726528 "/home/sandro/.config/gtkrc-2.0" renaming "gtkrc" to "gtkrc-2.0"
Aug 03 23:06:39 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=04:d9:f5:f6:03:35:12:d3:da:91:35:7c:08:00 SRC=192.168.178.20 DST=192.168.178.30 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=59457 DF PROTO=TCP SPT=41388 DPT=0 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 03 23:06:39 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=04:d9:f5:f6:03:35:12:d3:da:91:35:7c:86:dd SRC=fe80:0000:0000:0000:10d3:daff:fe91:357c DST=fe80:0000:0000:0000:6e78:b1ea:947a:42b2 LEN=80 TC=0 HOPLIMIT=255 FLOWLBL=209380 PROTO=TCP SPT=48128 DPT=0 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 03 23:06:39 failsafe baloo_file[1505]: 196023394016230912 "/home/sandro/.local/share/akonadi/db_data/ib_buffer_pool" renaming "ddl_recovery.log" to "ib_buffer_pool"
Aug 03 23:06:39 failsafe baloo_file[1505]: 196024841420209664 "/home/sandro/.local/share/akonadi/db_data/ddl_recovery.log" renaming "ib_buffer_pool" to "ddl_recovery.log"
Aug 03 23:06:41 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=04:d9:f5:f6:03:35:12:d3:da:91:35:7c:86:dd SRC=fe80:0000:0000:0000:10d3:daff:fe91:357c DST=fe80:0000:0000:0000:6e78:b1ea:947a:42b2 LEN=80 TC=0 HOPLIMIT=255 FLOWLBL=877180 PROTO=TCP SPT=48128 DPT=0 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 03 23:06:41 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=04:d9:f5:f6:03:35:12:d3:da:91:35:7c:08:00 SRC=192.168.178.20 DST=192.168.178.30 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=59458 DF PROTO=TCP SPT=41388 DPT=0 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 03 23:06:44 failsafe baloo_file_extractor[1934]: Invalid encoding. Ignoring "/home/sandro/.local/share/akonadi/db_data/ddl_recovery.log"
Aug 03 23:06:44 failsafe kwin_x11[1438]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9008, resource id: 4194310, major code: 18 (ChangeProperty), minor code: 0
Aug 03 23:06:45 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=04:d9:f5:f6:03:35:12:d3:da:91:35:7c:08:00 SRC=192.168.178.20 DST=192.168.178.30 LEN=1280 TOS=0x00 PREC=0x00 TTL=64 ID=49084 DF PROTO=UDP SPT=22000 DPT=22000 LEN=1260
Aug 03 23:06:45 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=04:d9:f5:f6:03:35:12:d3:da:91:35:7c:86:dd SRC=fe80:0000:0000:0000:10d3:daff:fe91:357c DST=fe80:0000:0000:0000:6e78:b1ea:947a:42b2 LEN=1280 TC=0 HOPLIMIT=255 FLOWLBL=864819 PROTO=UDP SPT=22000 DPT=22000 LEN=1240
Aug 03 23:06:45 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=04:d9:f5:f6:03:35:12:d3:da:91:35:7c:08:00 SRC=192.168.178.20 DST=192.168.178.30 LEN=1280 TOS=0x00 PREC=0x00 TTL=64 ID=49102 DF PROTO=UDP SPT=22000 DPT=22000 LEN=1260
Aug 03 23:06:45 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=04:d9:f5:f6:03:35:12:d3:da:91:35:7c:08:00 SRC=192.168.178.20 DST=192.168.178.30 LEN=1280 TOS=0x00 PREC=0x00 TTL=64 ID=49103 DF PROTO=UDP SPT=22000 DPT=22000 LEN=1260
Aug 03 23:06:45 failsafe kwin_x11[1438]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9016, resource id: 4194310, major code: 18 (ChangeProperty), minor code: 0
Aug 03 23:06:45 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=04:d9:f5:f6:03:35:12:d3:da:91:35:7c:08:00 SRC=192.168.178.20 DST=192.168.178.30 LEN=1280 TOS=0x00 PREC=0x00 TTL=64 ID=49140 DF PROTO=UDP SPT=22000 DPT=22000 LEN=1260
Aug 03 23:06:45 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=04:d9:f5:f6:03:35:12:d3:da:91:35:7c:08:00 SRC=192.168.178.20 DST=192.168.178.30 LEN=1280 TOS=0x00 PREC=0x00 TTL=64 ID=49141 DF PROTO=UDP SPT=22000 DPT=22000 LEN=1260
Aug 03 23:06:54 failsafe dbus-daemon[943]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Aug 03 23:06:54 failsafe pulseaudio[1544]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Aug 03 23:06:54 failsafe kded5[1434]: kf.bluezqt: PendingCall Error: "Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)"
Aug 03 23:06:54 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=04:d9:f5:f6:03:35:12:d3:da:91:35:7c:08:00 SRC=192.168.178.20 DST=192.168.178.30 LEN=1280 TOS=0x00 PREC=0x00 TTL=64 ID=50132 DF PROTO=UDP SPT=22000 DPT=22000 LEN=1260
Aug 03 23:06:54 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=04:d9:f5:f6:03:35:12:d3:da:91:35:7c:86:dd SRC=fe80:0000:0000:0000:10d3:daff:fe91:357c DST=fe80:0000:0000:0000:6e78:b1ea:947a:42b2 LEN=1280 TC=0 HOPLIMIT=255 FLOWLBL=864819 PROTO=UDP SPT=22000 DPT=22000 LEN=1240
Aug 03 23:06:55 failsafe systemd-timesyncd[664]: Initial synchronization to time server [2001:1600:4:1::f]:123 (2.manjaro.pool.ntp.org).
Aug 03 23:06:55 failsafe systemd[1]: systemd-hostnamed.service: Deactivated successfully.
░░ The unit systemd-hostnamed.service has successfully entered the 'dead' state.
Aug 03 23:06:55 failsafe audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 03 23:06:55 failsafe kernel: audit: type=1131 audit(1628024815.927:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 03 23:06:56 failsafe audit: BPF prog-id=15 op=UNLOAD
Aug 03 23:06:56 failsafe audit: BPF prog-id=14 op=UNLOAD
Aug 03 23:06:56 failsafe audit: BPF prog-id=13 op=UNLOAD
Aug 03 23:06:56 failsafe kernel: audit: type=1334 audit(1628024816.082:106): prog-id=15 op=UNLOAD
Aug 03 23:06:56 failsafe kernel: audit: type=1334 audit(1628024816.082:107): prog-id=14 op=UNLOAD
Aug 03 23:06:56 failsafe kernel: audit: type=1334 audit(1628024816.082:108): prog-id=13 op=UNLOAD
Aug 03 23:07:05 failsafe xdg-desktop-portal-kde[1891]: xdp-kde-background: GetAppState called: no parameters
Aug 03 23:07:08 failsafe syncthing[1355]: [N3IBJ] INFO: Established secure connection to SJG35PN-WIN2NBT-LYGKCVB-Q5PILAC-F4NC3NL-S5VDCJU-KENWOKH-SXJRPAO at 192.168.178.30:22000-192.168.178.20:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
Aug 03 23:07:08 failsafe syncthing[1355]: [N3IBJ] INFO: Device SJG35PN-WIN2NBT-LYGKCVB-Q5PILAC-F4NC3NL-S5VDCJU-KENWOKH-SXJRPAO client is "syncthing v1.18.0" named "Nokia 8.3 5G" at 192.168.178.30:22000-192.168.178.20:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
Aug 03 23:07:23 failsafe kwin_x11[1438]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9843, resource id: 4194310, major code: 18 (ChangeProperty), minor code: 0
Aug 03 23:07:24 failsafe kwin_x11[1438]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9860, resource id: 4194310, major code: 18 (ChangeProperty), minor code: 0
Aug 03 23:07:35 failsafe xdg-desktop-portal-kde[1891]: xdp-kde-background: GetAppState called: no parameters
Aug 03 23:07:54 failsafe audit[1825]: ANOM_ABEND auid=1000 uid=1000 gid=1001 ses=1 subj==unconfined pid=1825 comm="telegram-deskto" exe="/usr/bin/telegram-desktop" sig=6 res=1
Aug 03 23:07:54 failsafe kernel: audit: type=1701 audit(1628024874.423:109): auid=1000 uid=1000 gid=1001 ses=1 subj==unconfined pid=1825 comm="telegram-deskto" exe="/usr/bin/telegram-desktop" sig=6 res=1
Aug 03 23:07:54 failsafe systemd[1]: Created slice Slice /system/systemd-coredump.
░░ Subject: A start job for unit system-systemd\x2dcoredump.slice has finished successfully
░░ A start job for unit system-systemd\x2dcoredump.slice has finished successfully.
░░ The job identifier is 1122.
Aug 03 23:07:54 failsafe audit: BPF prog-id=19 op=LOAD
Aug 03 23:07:54 failsafe kernel: audit: type=1334 audit(1628024874.429:110): prog-id=19 op=LOAD
Aug 03 23:07:54 failsafe audit: BPF prog-id=20 op=LOAD
Aug 03 23:07:54 failsafe audit: BPF prog-id=21 op=LOAD
Aug 03 23:07:54 failsafe systemd[1]: Started Process Core Dump (PID 1975/UID 0).
░░ Subject: A start job for unit systemd-coredump@0-1975-0.service has finished successfully
░░ A start job for unit systemd-coredump@0-1975-0.service has finished successfully.
░░ The job identifier is 1121.
Aug 03 23:07:54 failsafe audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1975-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 03 23:07:54 failsafe kernel: audit: type=1334 audit(1628024874.433:111): prog-id=20 op=LOAD
Aug 03 23:07:54 failsafe kernel: audit: type=1334 audit(1628024874.433:112): prog-id=21 op=LOAD
Aug 03 23:07:54 failsafe kernel: audit: type=1130 audit(1628024874.433:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1975-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 03 23:07:54 failsafe kwin_x11[1438]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10969, resource id: 4194310, major code: 18 (ChangeProperty), minor code: 0
Aug 03 23:07:55 failsafe systemd-coredump[1976]: Process 1825 (telegram-deskto) of user 1000 dumped core.
Stack trace of thread 1825:
#0 0x00007f6b6ad29d22 raise (libc.so.6 + 0x3cd22)
#1 0x00007f6b6ad13862 abort (libc.so.6 + 0x26862)
#2 0x00005562414a4174 n/a (telegram-desktop + 0x6a3174)
#3 0x00005562430cd805 n/a (telegram-desktop + 0x22cc805)
#4 0x00005562430cd855 n/a (telegram-desktop + 0x22cc855)
#5 0x0000556242714797 n/a (telegram-desktop + 0x1913797)
#6 0x00005562426d953e n/a (telegram-desktop + 0x18d853e)
#7 0x00005562426ba7bf n/a (telegram-desktop + 0x18b97bf)
#8 0x00005562426c8f96 n/a (telegram-desktop + 0x18c7f96)
#9 0x0000556242301604 n/a (telegram-desktop + 0x1500604)
#10 0x00005562423187fa n/a (telegram-desktop + 0x15177fa)
#11 0x000055624231e573 n/a (telegram-desktop + 0x151d573)
#12 0x0000556242f63c05 n/a (telegram-desktop + 0x2162c05)
#13 0x0000556242f8eec7 n/a (telegram-desktop + 0x218dec7)
#14 0x0000556242a9b64a n/a (telegram-desktop + 0x1c9a64a)
#15 0x0000556242aa4116 n/a (telegram-desktop + 0x1ca3116)
#16 0x00005562421ba93e n/a (telegram-desktop + 0x13b993e)
#17 0x00005562421bac3f n/a (telegram-desktop + 0x13b9c3f)
#18 0x00007f6b6be8f3aa _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x2b93aa)
#19 0x00007f6b6be924a9 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt5Core.so.5 + 0x2bc4a9)
#20 0x00007f6b6bee89a4 n/a (libQt5Core.so.5 + 0x3129a4)
#21 0x00007f6b6cd1510c g_main_context_dispatch (libglib-2.0.so.0 + 0x5410c)
#22 0x00007f6b6cd68b99 n/a (libglib-2.0.so.0 + 0xa7b99)
#23 0x00007f6b6cd12871 g_main_context_iteration (libglib-2.0.so.0 + 0x51871)
#24 0x00007f6b6bee7fd6 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x311fd6)
#25 0x00007f6b6be8dd1c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2b7d1c)
#26 0x00007f6b6be96284 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2c0284)
#27 0x00005562421b9414 n/a (telegram-desktop + 0x13b8414)
#28 0x00005562421a6b53 n/a (telegram-desktop + 0x13a5b53)
#29 0x00005562421a6e1f n/a (telegram-desktop + 0x13a5e1f)
#30 0x0000556241481c4a n/a (telegram-desktop + 0x680c4a)
#31 0x00007f6b6ad14b25 __libc_start_main (libc.so.6 + 0x27b25)
#32 0x000055624148c7ce n/a (telegram-desktop + 0x68b7ce)
Stack trace of thread 1902:
#0 0x00007f6b6ade0b2f __poll (libc.so.6 + 0xf3b2f)
#1 0x00007f6b6f1cb407 n/a (libopenal.so.1 + 0x80407)
#2 0x00007f6b4d4f39a9 pa_mainloop_poll (libpulse.so.0 + 0x1c9a9)
#3 0x00007f6b4d4fe281 pa_mainloop_iterate (libpulse.so.0 + 0x27281)
#4 0x00007f6b4d4fe331 pa_mainloop_run (libpulse.so.0 + 0x27331)
#5 0x00007f6b6f1cc96e n/a (libopenal.so.1 + 0x8196e)
#6 0x00007f6b6b0ed3c4 execute_native_thread_routine (libstdc++.so.6 + 0xd33c4)
#7 0x00007f6b6d5df259 start_thread (libpthread.so.0 + 0x9259)
#8 0x00007f6b6adeb5e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 1829:
#0 0x00007f6b6d5eb8ca __futex_abstimed_wait_common64 (libpthread.so.0 + 0x158ca)
#1 0x00007f6b6d5e5270 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf270)
#2 0x00007f6b6c9c75e9 n/a (libjemalloc.so.2 + 0x195e9)
#3 0x00007f6b6c9c8531 n/a (libjemalloc.so.2 + 0x1a531)
#4 0x00007f6b6d5df259 start_thread (libpthread.so.0 + 0x9259)
#5 0x00007f6b6adeb5e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 1903:
#1 0x00007f6b6cd68b29 n/a (libglib-2.0.so.0 + 0xa7b29)
#2 0x00007f6b6cd12871 g_main_context_iteration (libglib-2.0.so.0 + 0x51871)
#3 0x00007f6b6bee7fd6 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x311fd6)
#4 0x00007f6b6be8dd1c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2b7d1c)
#5 0x00007f6b6bca2e12 _ZN7QThread4execEv (libQt5Core.so.5 + 0xcce12)
#6 0x00007f6b6bca3fef n/a (libQt5Core.so.5 + 0xcdfef)
Stack trace of thread 1836:
#1 0x00007f6b6cc9e63b n/a (libxcb.so.1 + 0xc63b)
#2 0x00007f6b6cca037b xcb_wait_for_event (libxcb.so.1 + 0xe37b)
#3 0x00007f6b598ecf21 n/a (libQt5XcbQpa.so.5 + 0x61f21)
#4 0x00007f6b6bca3fef n/a (libQt5Core.so.5 + 0xcdfef)
#5 0x00007f6b6d5df259 start_thread (libpthread.so.0 + 0x9259)
#6 0x00007f6b6adeb5e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 1828:
#3 0x00007f6b6cd128c2 n/a (libglib-2.0.so.0 + 0x518c2)
#4 0x00007f6b6cd432c1 n/a (libglib-2.0.so.0 + 0x822c1)
Stack trace of thread 1837:
#1 0x00007f6b6d5e5574 pthread_cond_timedwait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf574)
#2 0x00007f6b6c9c754e n/a (libjemalloc.so.2 + 0x1954e)
Stack trace of thread 1831:
Stack trace of thread 1910:
Stack trace of thread 1830:
#2 0x00007f6b6cd14693 g_main_loop_run (libglib-2.0.so.0 + 0x53693)
#3 0x00007f6b6cf538c8 n/a (libgio-2.0.so.0 + 0x1018c8)
Stack trace of thread 1842:
#6 0x00007f6b6b330ae8 n/a (libQt5DBus.so.5 + 0x15ae8)
#7 0x00007f6b6bca3fef n/a (libQt5Core.so.5 + 0xcdfef)
#8 0x00007f6b6d5df259 start_thread (libpthread.so.0 + 0x9259)
#9 0x00007f6b6adeb5e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 1911:
Stack trace of thread 1967:
#2 0x00007f6b6bcaa000 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xd4000)
#3 0x00007f6b6bca74a8 n/a (libQt5Core.so.5 + 0xd14a8)
Stack trace of thread 1971:
Stack trace of thread 1827:
#3 0x00007f6b6c9c87e9 n/a (libjemalloc.so.2 + 0x1a7e9)
Stack trace of thread 1968:
Stack trace of thread 1904:
Stack trace of thread 1843:
Stack trace of thread 1915:
#2 0x00007f6b6b0e6f01 __gthread_cond_wait (libstdc++.so.6 + 0xccf01)
#3 0x0000556241a82c0c n/a (telegram-desktop + 0xc81c0c)
#4 0x00007f6b6b0ed3c4 execute_native_thread_routine (libstdc++.so.6 + 0xd33c4)
Stack trace of thread 1969:
Stack trace of thread 1905:
Stack trace of thread 1970:
░░ Subject: Process 1825 (telegram-deskto) dumped core
░░ Documentation: man:core(5)
░░ Process 1825 (telegram-deskto) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
Aug 03 23:07:55 failsafe systemd[1]: systemd-coredump@0-1975-0.service: Deactivated successfully.
░░ The unit systemd-coredump@0-1975-0.service has successfully entered the 'dead' state.
Aug 03 23:07:55 failsafe kernel: audit: type=1131 audit(1628024875.529:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1975-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 03 23:07:55 failsafe audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1975-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 03 23:07:55 failsafe systemd[1]: systemd-coredump@0-1975-0.service: Consumed 1.034s CPU time.
░░ Subject: Resources consumed by unit runtime
░░ The unit systemd-coredump@0-1975-0.service completed and consumed the indicated resources.
Aug 03 23:07:55 failsafe kded5[1434]: Service ":1.74" unregistered
Aug 03 23:07:55 failsafe kwin_x11[1438]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10970, resource id: 83886086, major code: 15 (QueryTree), minor code: 0
Aug 03 23:07:55 failsafe kwin_x11[1438]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11002, resource id: 29360251, major code: 18 (ChangeProperty), minor code: 0
Aug 03 23:07:55 failsafe systemd[1347]: app-telegramdesktop-5f11c7c0fc144af4a0907f51b5846a8b.scope: Consumed 1.712s CPU time.
░░ The unit UNIT completed and consumed the indicated resources.
Aug 03 23:07:55 failsafe audit: BPF prog-id=21 op=UNLOAD
Aug 03 23:07:55 failsafe audit: BPF prog-id=20 op=UNLOAD
Aug 03 23:07:55 failsafe audit: BPF prog-id=19 op=UNLOAD
Aug 03 23:07:55 failsafe kernel: audit: type=1334 audit(1628024875.666:115): prog-id=21 op=UNLOAD
Aug 03 23:07:55 failsafe kernel: audit: type=1334 audit(1628024875.666:116): prog-id=20 op=UNLOAD
Aug 03 23:07:55 failsafe kernel: audit: type=1334 audit(1628024875.666:117): prog-id=19 op=UNLOAD
Aug 03 23:07:57 failsafe kwin_x11[1438]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11185, resource id: 12582919, major code: 18 (ChangeProperty), minor code: 0
Aug 03 23:07:57 failsafe systemd[1347]: Started Konsole - Terminal.
░░ The job identifier is 248.
Aug 03 23:07:58 failsafe kernel: [UFW BLOCK] IN=enp5s0 OUT= MAC=01:00:5e:00:00:01:2c:91:ab:bd:23:66:08:00 SRC=192.168.178.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=2123 DF PROTO=2
Thanks for your help. Let me know if there is anything I can do or provide from my side.
