I installed recently Manjaro in a new laptop. When hovering over the telegram app, the cursor gets too big.
The following two screenshots show how the cursor size changes.
Normal size:
Over telegram:
I’ve read elsewhere about some disagreement between Wayland and GNOME protocol for handling the cursor size. But I’ve found no solution.
You can try using the environment variable like:
export XCURSOR_SIZE="$(gsettings get org.gnome.desktop.interface cursor-size)"
You probably saw this Applications depending on XCURSOR_SIZE and XCURSOR_THEME don't use the correct cursor size and theme (#5894) · Issues · GNOME / gnome-shell · GitLab
system
Closed
3
