Hi,
I need to use teams for school. One on one (a call) works, several works as well. When a link is given to join a meeting, I get asked (by chromium, of course) to open xdg-open, I confirm and get this error.
Any ideas?
Thanks
Melissa
Hi,
Any ideas?
Thanks
Melissa
Can you kingly post the output of
cat ~/.config/mimeapps.list | grep teams
Not angrily, kindly.
if all else fails it usually works in the browser
Obviously not in Chromium.
Hi there…
One strong well-meant morning hug for you
Gives nothing back…
However, inquisitive as I am, I dove into the folder head on (with snorkle) and did find the file:
[Added Associations]
application/pdf=okularApplication_pdf.desktop;
application/x-extension-htm=firefox.desktop;
application/x-extension-html=firefox.desktop;
application/x-extension-shtml=firefox.desktop;
application/x-extension-xht=firefox.desktop;
application/x-extension-xhtml=firefox.desktop;
application/xhtml+xml=firefox.desktop;
application/xspf+xml=smplayer.desktop;
image/jpeg=org.kde.gwenview.desktop;
image/png=org.kde.gwenview.desktop;
inode/directory=org.kde.dolphin.desktop;
text/html=firefox.desktop;
x-scheme-handler/chrome=firefox.desktop;
x-scheme-handler/ftp=firefox.desktop;
x-scheme-handler/http=firefox.desktop;chromium.desktop;
x-scheme-handler/https=firefox.desktop;chromium.desktop;
x-scheme-handler/mailto=thunderbird.desktop;
[Default Applications]
text/html=chromium.desktop
I have to use chomium. I did try xdg-open in the console (after I set cromium as default) and I had an error similar to what ff gives…
That is important.
Can you post the output of:
sudo find / -type f -name 'teams.desktop'
Got to make sure it’s there, ya know?
Can you give, PM me if neccessary, an example of the URL?
Happy to learn new things…
And nothing was found…
gladly, let me dig it up…
Thank
Perhaps not for some - but whenever Teams fails on me - it never fails (for me) in Chromium - I would suggest rebuilding the package from AUR. It also seemed that op chose the option to open the App on her computer (possibly from a calendar link) and not the browser version (Run in Browser). But it’s good to see the issue has been resolved.
I’m not using MS Teams at all, so I don’t know if this will be of any help.
If you have installed the package teams-for-linux
from the AUR, try adding this line in your ~/.config/mimeapps.list
file under the [Default Applications] section:
x-scheme-handler/msteams=teams-for-linux.desktop;
If the above doesn’t work right away, try the suggestion in this comment of the AUR page of the said package.
Instead of editing the file /usr/share/applications/teams-for-linux.desktop
, you can copy it in your home directory in ~/.local/share/applications
and edit it there.
If nothing of the above worked, or in case I have misunderstood this thread, revert any changes you made in your system.
