TBX mit Smartdaten abgleichen
Hallo!
Ich wollte mal sehen wie der Zustand meiner SSD ( Samsung SSD 860 QVO ) ist.
Sie wird mit 360 TBW angegeben.
Leider finde ich in Gsmart keine Angaben wieviel bereits geschrieben wurde.
Wer kann mir sagen wo ich sie in diesem Datenwust finde.
Meine Gsmartausgabe lautet :
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.1.31-2-MANJARO] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Samsung based SSDs
Device Model:     Samsung SSD 860 QVO 1TB
Serial Number:    S4CZNF0N272985P
LU WWN Device Id: 5 002538 e90230ffb
Firmware Version: RVQ02B6Q
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available, deterministic, zeroed
Device is:        In smartctl database 7.3/5319
ATA Version is:   ACS-4 T13/BSR INCITS 529 revision 5
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Wed Jun  7 17:17:43 2023 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, frozen [SEC2]
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x80)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(    0) seconds.
capabilities: 			 (0x53) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					No Offline surface scan supported.
					Self-test supported.
					No Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 (  85) minutes.
SCT capabilities: 	       (0x003d)	SCT Status supported.
					SCT Error Recovery Control supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    0
  9 Power_On_Hours          -O--CK   097   097   000    -    11320
 12 Power_Cycle_Count       -O--CK   097   097   000    -    2431
177 Wear_Leveling_Count     PO--C-   086   086   000    -    110
179 Used_Rsvd_Blk_Cnt_Tot   PO--C-   100   100   010    -    0
181 Program_Fail_Cnt_Total  -O--CK   100   100   010    -    0
182 Erase_Fail_Count_Total  -O--CK   100   100   010    -    0
183 Runtime_Bad_Block       PO--C-   100   100   010    -    0
187 Uncorrectable_Error_Cnt -O--CK   100   100   000    -    0
190 Airflow_Temperature_Cel -O--CK   065   052   000    -    35
195 ECC_Error_Rate          -O-RC-   200   200   000    -    0
199 CRC_Error_Count         -OSRCK   100   100   000    -    0
235 POR_Recovery_Count      -O--C-   099   099   000    -    225
241 Total_LBAs_Written      -O--CK   099   099   000    -    95082241451
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x13       GPL     R/O      1  SATA NCQ Send and Receive log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa1           SL  VS      16  Device vendor specific log
0xa5           SL  VS      16  Device vendor specific log
0xce           SL  VS      16  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%     11320         -
# 2  Short offline       Completed without error       00%      8948         -
# 3  Extended offline    Completed without error       00%      4211         -
# 4  Short offline       Completed without error       00%      2602         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
  256        0    65535  Read_scanning was never started
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Read SCT Status failed: scsi error badly formed scsi parameters
Write SCT (Get) Error Recovery Control Command failed: scsi error badly formed scsi parameters
SCT (Get) Error Recovery Control command failed
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4            2431  ---  Lifetime Power-On Resets
0x01  0x010  4           11320  ---  Power-on Hours
0x01  0x018  6     95082241451  ---  Logical Sectors Written
0x01  0x020  6       865604355  ---  Number of Write Commands
0x01  0x028  6    210418827370  ---  Logical Sectors Read
0x01  0x030  6      5308268816  ---  Number of Read Commands
0x01  0x038  6         1496000  ---  Date and Time TimeStamp
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              35  ---  Current Temperature
0x05  0x020  1              48  ---  Highest Temperature
0x05  0x028  1              22  ---  Lowest Temperature
0x05  0x058  1              70  ---  Specified Maximum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4             555  ---  Number of Hardware Resets
0x06  0x010  4               0  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0x07  =====  =               =  ===  == Solid State Device Statistics (rev 1) ==
0x07  0x008  1              14  N--  Percentage Used Endurance Indicator
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
Vielen Dank im voraus.
MfG R.Lehmeier
Mit ein bisschen umrechnen sollten das etwa 44,3 TB sein. Und das wären bei 360 TBW etwa 12,3 %. Das entspricht fast
Danke, fürs umrechnen. Ich wußte nur nicht wie.
Wenn ich über 44 TB habe und das in fast 3 Jahren, dann habe ich ja nur noch 18 Jahre bis die SSD aufgibt. :wink:
Bis dahin werde ich hoffentlich einen neuen Rechner haben.
Vielen Dank für die Hilfe
Naja die Lebensdauert hängt nicht komplett von den TBW ab. Die Berechnung ist aber recht einfach.
Einfach die Sektorgröße mit den LSW multiplizieren und dann durch 1000⁴ Teilen um auf TB zu kommen.
Ich habe da übrigens einen Fehler gemacht. Ich habe durch 1024⁴ geteilt und bekomme dann TiB. Da Hersteller runde Zahlen mögen beziehen die immer alles auf TB und nicht TiB.
Daher hast du bisher 48,6 TB oder 44,3 TiB auf die SSD geschrieben. In Prozent wären das 13,5 und damit recht genau der Wer des “Percentage Used Endurance Indicator”.
