Taskbar is gone
Hello Manjaro Forum,
I’m at the brink of changing the OS just for one and one reason only:
after a few boots the taskbar is completely missing, no icons, no weather widgets, no start button, nothing not even the blank taskbar itself is visible.
-Is there are way to restore the taskbar ?
-is there a config file somewhere where I can setup a regular backup to at least have the option to restore it after it crashes again ?
you are my last hope, thank you very much!
Right click the desktop, and add panel.
We’re your last hope? :grin:
  • Go to a TTY
  • Log in there
  • Execute
    useradd thepete2
  • exit from the TTY
  • Log in to the new user
  • is the Launcher back there?
:crossed_fingers:
that just brings back the standard panel without my pinned programs, weather widgets and stuff…
that’s actually the problem I don’t want to customize my taskbar every week as it is very time consuming.
thank you for your help!
I tried that but that just brings a blank panel.
Is there some kind of config file for the panel?
What do you mean by “blank panel”: the standard, default panel that works???
:thinking:
yes exactly! It brings back the panel and it’s useable but all of my pinned programs are gone, my custom start button, weather widgets, icons…
OK, good!
  • Now add only your pinned programs
  • tomorrow add the custom start button
  • Day after tomorrow one weather widget
  • etc.
Every day: shut down your machine…
When it stops working yet again that’s the widget that’s causing the problem!
Then:
  • Remove that again
  • File a bug report to its author
:crossed_fingers:
and yes sorry I should have been more clear: bringing it back works and in fact it always has worked.
I don´t even need to switch users to create a new panel.
The problem is just that I my customized panel disappears after a few reboots
