how do i move the icon in the icons-only task manager?
I have succeeded in moving it. but after I open the software, the icon always returns to its place.
i have tried removing all the icons then organizing them. but the results still move.
Does anyone know how to move the icon so that it doesn’t return to its place?
With the disclaimer that I’m not using the icons-only task manager, try right-clicking it and select “More Actions”, and then “Configure Task Manager”.
There is an option there for sorting. It may be set to “alphabetical” or something. Set it to “manual”. And also make sure that “Keep Launchers separate” is not ticked.
I’m not sure but I now seem to remember that there was an issue with the icons-only task manager, and that it was fixed for an upcoming release. It just doesn’t appear to have made it into 5.19.4 yet.
As an alternative ─ in case you really can’t live with this behavior ─ you could install Latte Dock*. But that’s up to you, of course.
