Good morning, I am using openbox and I can’t make the tap to click on the touchpad work. In the menu Mouse and Touchpad there is the option to click it, but when I close it doesn’t save the change. Has someone any ideas?
Thank you
Please see:
I searched and found that both libinput and synaptics are installed. This is the conf /etc/X11/xorg.conf.d
Section "InputClass"
Identifier "tap-by-default"
MatchIsTouchpad "on"
MatchDriver "libinput"
Option "Tapping" "on"
EndSection
Yesterday I tried many thngs, including creating another conf following the arch wiki, but I did something so wrong that I had to reinstall. So before braking it again I decided to ask.
I took a screenshot of the window where I try to enable tap to click.
Beside the Xconfig used you should also provide info on your hardware to help others help you better… (See the link i gave)
Sorry, here it is.
> inxi -Fazy
Kernel: 5.4.85-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=98ced960-7fd2-4e0d-8031-a6adc11d05bd rw quiet udev.log_priority=3
Desktop: Xfce 4.14.4 info: tint2 wm: Openbox 3.6.1 dm: LXDM
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: K53E v: 1.0 serial: <filter>
Mobo: ASUSTeK model: K53E v: 1.0 serial: <filter> BIOS: American Megatrends
v: K53E.219 date: 03/06/2012
ID-1: BAT0 charge: 45.0 Wh condition: 46.3/48.4 Wh (96%) volts: 12.4/11.1
model: ASUSTek K53--52 type: Li-ion serial: N/A status: Unknown
Info: Dual Core model: Intel Core i3-2350M bits: 64 type: MT MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
L2 cache: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18366
Speed: 1389 MHz min/max: 800/2300 MHz Core speeds (MHz): 1: 1389 2: 800
3: 1055 4: 798
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0116
Device-2: IMC Networks UVC VGA Webcam type: USB driver: uvcvideo
bus ID: 1-1.2:4 chip ID: 13d3:5710 serial: <filter>
Display: x11 server: X.Org 1.20.10 driver: intel
unloaded: fbdev,modesetting,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1c20
Sound Server: ALSA v: k5.4.85-1-MANJARO inxi -Fazy
L2 cache: 3 MiB
3: 1055 4: 798
Type: l1tf
diag: 389mm (15.3")
chip ID: 8086:1c20
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: AzureWave
driver: ath9k v: kernel port: e040 bus ID: 02:00.0 chip ID: 168c:0032
Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: ASUSTeK
driver: atl1c v: 1.0.1.1-NAPI port: a000 bus ID: 04:00.0 chip ID: 1969:1083
IF: enp4s0 state: down mac: <filter>
Device-3: IMC Networks Atheros AR3012 Bluetooth 4.0 Adapter type: USB
driver: btusb bus ID: 1-1.1:5 chip ID: 13d3:3362 serial: <filter>
Device-4: KYE Systems (Mouse Systems) GF3000F Ethernet Adapter type: USB
driver: hid-generic,usbhid bus ID: 4-1.2:3 chip ID: 0458:6001
Local Storage: total: 447.13 GiB used: 59.84 GiB (13.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A480G
size: 447.13 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: BBF2
ID-1: / raw size: 447.13 GiB size: 439.11 GiB (98.21%)
used: 59.84 GiB (13.6%) fs: ext4 block size: 4096 B dev: /dev/sda1
maj-min: 8:1
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2200
Processes: 192 Uptime: 28m wakeups: 1 Memory: 7.56 GiB
used: 1.65 GiB (21.8%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 948 lib: 195 Shell: Zsh v: 5.8 running in: sakura inxi: 3.2.01
maj-min: 8:1
file: /swapfile
Take a look in the file ~/.config/openbox/autostart
Check this part and remove the (#) comment - logoff and login
### Required for xfce settings to work
#sleep 0.5; xfsettingsd &
The daemon is not enabled default as xfce components is not present on the minimal edition.
Thank you¡¡¡¡ now it is working
