Systemsettings dependencies
Can someone look up in octopi all the dependency packages. I removed the package with dependencies but when installed it again it didn’t install any of them(about 5 i think). Now I don’t know their names. After rebooting the system Plasma isn’t working properly(no panel, have to use console to open programs).
Just open octopi and try removing systemsettings package it will ask you to remove dependencies as well. Screenshot the list of deps and post it here. You don’t have to remove the package it will require password anyway.
… with what command, exactly?
I used Octopi to remove. I didn’t use pacman.
Nevertheless, check your pacman logfiles (/var/log/pacman.log).
PACMAN] Running ‘/usr/bin/pacman -R --noconfirm accountsservice kgamma5 kinfocenter plasma-desktop polkit-kde-agent sddm-kcm systemsettings’
[2021-05-04T09:43:00+0700] [ALPM] running ‘05-etckeeper-pre-install.hook’…
[2021-05-04T09:43:00+0700] [ALPM] transaction started
[2021-05-04T09:43:01+0700] [ALPM] removed sddm-kcm (5.21.4-1)
[2021-05-04T09:43:02+0700] [ALPM] removed plasma-desktop (5.21.4-1)
[2021-05-04T09:43:02+0700] [ALPM] removed polkit-kde-agent (5.21.4-1)
[2021-05-04T09:43:02+0700] [ALPM] removed kinfocenter (5.21.4-1)
[2021-05-04T09:43:02+0700] [ALPM] removed kgamma5 (5.21.4-1)
[2021-05-04T09:43:02+0700] [ALPM] removed systemsettings (5.21.4-1)
[2021-05-04T09:43:02+0700] [ALPM] removed accountsservice (0.6.55-3)
[2021-05-04T09:43:02+0700] [ALPM] transaction completed
Usually Octopi installs dependencies that it removed, not this time though.
Offtopish:
tried installing the packages directly and --asdeps the main issue(lacking panel) persists.
Timeshift restore?
